Salta al contenuto principale
Macintosh Powerbook 5300cs Trackpad Replacement
Cosa ti serve
  1. Macintosh Powerbook 5300cs Trackpad Replacement, Battery: passo 1, immagine 1 di 1
    • The battery compartment is located in the front-right side of the laptop.
  2. Macintosh Powerbook 5300cs Trackpad Replacement: passo 2, immagine 1 di 1
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
  3. Macintosh Powerbook 5300cs Trackpad Replacement, Keyboard: passo 3, immagine 1 di 1
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
  4. Macintosh Powerbook 5300cs Trackpad Replacement: passo 4, immagine 1 di 2 Macintosh Powerbook 5300cs Trackpad Replacement: passo 4, immagine 2 di 2
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
  5. Macintosh Powerbook 5300cs Trackpad Replacement: passo 5, immagine 1 di 3 Macintosh Powerbook 5300cs Trackpad Replacement: passo 5, immagine 2 di 3 Macintosh Powerbook 5300cs Trackpad Replacement: passo 5, immagine 3 di 3
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
  6. Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: passo 6, immagine 1 di 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: passo 6, immagine 2 di 3 Macintosh Powerbook 5300cs Trackpad Replacement, Trackpad: passo 6, immagine 3 di 3
    • Remove the front plastic panel of the laptop by carefully lifting it up.
  7. Macintosh Powerbook 5300cs Trackpad Replacement: passo 7, immagine 1 di 1
    • Remove the orange stripped ribbon that connects the trackpad to the rest of the laptop by carefully pulling up.
  8. Macintosh Powerbook 5300cs Trackpad Replacement: passo 8, immagine 1 di 2 Macintosh Powerbook 5300cs Trackpad Replacement: passo 8, immagine 2 di 2
    • With a Torx #9 screwdriver, remove the two .20 in. screws circled in red that are holding the trackpad in place.
    • Then disconnect the ribbon highlighted with the red rectangle connecting the trackpad to the laptop.
  9. Macintosh Powerbook 5300cs Trackpad Replacement: passo 9, immagine 1 di 1
    • The trackpad can now be removed from the laptop.
Conclusione
Ronan
Membro da: 10/10/11
63 Reputazione
4 Guide realizzate
Cal Poly, Team 6-1, Regan Fall 2011 Membro di Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,054
