Introduzione
Outline what you are going to teach someone how to do.
Cosa ti serve
To insert the battery, gently slide it into the compartment until it clicks in place.
To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
Remove the front plastic panel of the laptop by carefully lifting it up.
If they haven’t been broken off (mine just did break as I was doing this) there is a tab on each side attached to the top housing on either side of the keyboard. These tabs are on top of the tabs for the front top panel, so lifting the front end of those side housings is necessary to prevent breakage (and, given how old these suckers are, it might break anyway).
Altre 2 persone hanno completato questa guida.
