Salta al contenuto principale
Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement
Cosa ti serve
  1. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
  2. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 2, immagine 1 di 1
    • Pull the battery toward yourself until it is fully detached.
  3. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement, Input/Output Door: passo 3, immagine 1 di 1
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
  4. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 4, immagine 1 di 1
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
  5. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement, Lower Case: passo 5, immagine 1 di 1
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
  6. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 6, immagine 1 di 1
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
  7. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 7, immagine 1 di 1
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
  8. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 8, immagine 1 di 2 Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 8, immagine 2 di 2
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
  9. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 9, immagine 1 di 2 Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 9, immagine 2 di 2
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
  10. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement, RAM and PSRAM Expansion Card: passo 10, immagine 1 di 2 Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement, RAM and PSRAM Expansion Card: passo 10, immagine 2 di 2
    • Locate and lift ram card directly up until connector releases.
    • Move the card back and forth gently if the connector does not release immediately.
  11. Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 11, immagine 1 di 2 Macintosh PowerBook 165c RAM and PSRAM Expansion Card Replacement: passo 11, immagine 2 di 2
    • Locate and lift the PSRAM expansion card vertically until connector releases.
    • If the PSRAM expansion card is difficult to remove, gently jostle it back and forth as you lift up.
    • The PSRAM expansion card is an optional component, and may not be included in all devices.
Conclusione
Adam
Membro da: 10/12/11
1 Reputazione
4 Guide realizzate
Cal Poly, Team 6-3, Regan Fall 2011 Membro di Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,487
