Salta al contenuto principale
Macintosh PowerBook 1400 Series CD-ROM Drive Replacement
  1. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the device upside down and then locate the battery latch near the front of the device.
  2. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 2, immagine 1 di 1
    • Slide the latch to the left to release the battery.
  3. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 3, immagine 1 di 1
    • Continue holding the latch then gently pull the battery out of the device.
    • Place the battery in a safe location.
  4. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement, CD-ROM Drive: passo 4, immagine 1 di 1
    • Locate the CD-ROM Drive latch.
  5. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 5, immagine 1 di 1
    • Slide the latch to the right to release the CD ROM drive.
  6. Macintosh PowerBook 1400 Series CD-ROM Drive Replacement: passo 6, immagine 1 di 1
    • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
    • Place the CD ROM drive in a safe location.
Conclusione
Cal Poly, Team 10-39, Forte Spring 2011 Membro di Cal Poly, Team 10-39, Forte Spring 2011
CPSU-FORTE-S11S10G39
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,824
