Salta al contenuto principale
MacBook Unibody Model A1342 Rear Speaker Assembly Replacement
Solo Prerequisita
Questa guida รจ destinata a essere usata solo come prerequisito per altre guide. Da sola รจ incompleta.
Cosa ti serve
  1. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement, Rear Speaker Assembly: passo 1, immagine 1 di 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  2. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the following screws securing the right speaker assembly to the upper case:
    • One 12 mm Phillips screw.
    • One 3 mm Phillips screw.
  3. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  4. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 4, immagine 1 di 2 MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 4, immagine 2 di 2
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
    • De-route the long antenna from its channel in the rear speaker housing.
  5. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 5, immagine 1 di 1
    • Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
  6. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 6, immagine 1 di 1
    • Remove the rear speaker assembly from the upper case.
  7. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 7, immagine 1 di 2 MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 7, immagine 2 di 2
    • Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
  8. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 8, immagine 1 di 1
    • Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
  9. MacBook Unibody Model A1342 Rear Speaker Assembly Replacement: passo 9, immagine 1 di 1
    • Lift the AirPort/Bluetooth board up off the rear speaker assembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 706
