Salta al contenuto principale
MacBook Unibody Model A1342 Lower Case Replacement
Cosa ti serve
  1. MacBook Unibody Model A1342 Lower Case Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Lower Case Replacement: passo 2, immagine 1 di 3 MacBook Unibody Model A1342 Lower Case Replacement: passo 2, immagine 2 di 3 MacBook Unibody Model A1342 Lower Case Replacement: passo 2, immagine 3 di 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
Conclusione
Altre 74 persone hanno completato questa guida.
2 Commenti
Apple has a recall on this part, so you can get a replacement for an improved version free and save yourself $149.99. Check out http://www.apple.com/support/macbook-bot...
Shane - Replica
Would the Macbook Pro back cover also fit this?
wow - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 38
Tutti i Tempi: 69,686
