Introduzione
Replacing the optical drive.
Strumenti
Ricambi
Nessuna parte specificata.
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Quasi finito!
Conclusione
