Introduzione
Charges battery and connects battery to logic board.
Cosa ti serve
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the white plastic tab and pull the battery up and out of the Unibody.
Great tutorial ! great step !
Remove the following eight screws securing the lower case to the chassis:
One 3 mm Phillips screw.
Three 13.5 mm Phillips screws.
Four 3.5 mm Phillips screws.
Make sure you have a good quality Phillips screwdriver. Mine had removable tips and had a small play at the connection. As a result I didn't have a good feel and damaged my screws (those securing the fan and the top left in step 23). Game over for me installing new thermal paste...
Be very carefull with your screws! Especially those on the inside.
You can get away with a Phillips #00 for many of the screws involved but the 4 at the bottom case split are likely to strip if you donโt use a JIS #00 or, in a pinch, a Phillips #000.
I used the Phillips #00 tip from my Pro Tech Toolkit, and it worked well enough. But yes, maybe #000 might have been better on the lower row of screws. Note to myself: Always read the comments first.
When replacing these screws, the order to replace them in is as follows:
1, Top left
2. Top right
3. Top center-left
4. Top center-right
5. Bottom center-right
6. Bottom center-left
7. Bottom right
8. Bottom left
I hope this information is helpful.
I followed my usual process of putting in all the screws loosely, then tightening them gradually in distributed pattern, to help ensure that the panel settles in place evenly. But maybe some orders are better.
Using both hands, lift and remove the lower case off the upper case.
Thanks for the guide!
It's implicit in the two photos, but worth mentioning because it blocked my progress in this step for a bit: You have to put the release latch back into its horizontal, closed position before you can lift off the lower-case panel.
Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
Remove the following screws securing the battery connector cover to the upper case:
One 2.5 mm Phillips screw.
Two 1.5 mm Phillips screws.
Using a spudger, pry the battery level indicator cable connector straight up off the logic board.
Altre 13 persone hanno completato questa guida.
Un commento
When reinstalling the battery connector/cable, placement of the connector is critical. If the connector isn't positioned accurately, contact with the battery terminals won't be completed. The battery connector cover will help you align the connector, but there will still be a little leeway as you screw the cover down. Position the battery first, to adjust the connector's position; then remove the battery and tighten the cover screws down. You may even want to try plugging the computer into the AC charger before completing the cover attachment, to ensure that battery is charging and the connector is correctly positioned.
This is not a a1278 unibody MacBook Pro. A1278 MacBooks backs are one solid metal piece not two separate pieces. This guide is for a different MacBook Pro.
Brad Burgeson - Replica
This guide isnโt for a pro; itโs a MacBook unibody.
Nicholas -
So, it turns out that Apple used the model code A1278 for quite a few different Mac models, including both Pro and non-Pro versions! This guide is for the non-Pro Macbooks. Thereโs also one for the Pro models with the same A1278 identifier.
tempelmann - Replica
