Introduzione
No sound from the right side of your MacBook Pro? Use this guide to replace the subwoofer and right speaker assembly.
Cosa ti serve
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
Use the flat end of a spudger to lift the subwoofer & right speaker connector out of its socket on the logic board.
Altre 18 persone hanno completato questa guida.
3 Commenti
Where can I find the right side speaker for a MacBook Pro 17” (EARLY 2011)
Bonjour, le speaker droit et gauche early 2009 jusqu’a mid 2010 sont-ils identiques ?
J’ai acheté un kit complet early 2009 et mon macbook pro 17 pouces est mi 2010
merci de vos réponses
Good job. Thank you.
