Salta al contenuto principale
MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement, Hard Drive Removal/Installation: passo 1, immagine 1 di 1
    • Turn the computer over and remove all of the screws that holds together the bottom of the case.
    • The bottom left three screws are longer. Set those aside for reassembly
  2. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement: passo 2, immagine 1 di 1
    • Here are the three larger screws. The smaller ones fit the remaining holes
  3. MacBook Pro 17" Unibody Hard Drive Removal/Installation Replacement: passo 3, immagine 1 di 1
    • Delicately lift the case off. The hard drive is visible. There is a bracket with two black screws holding it in place. Remove the bracket and you have access to the hard drive.
    • Remove the interface from the SATA drive and leave the ribbon connected to the mobo.
Conclusione
Altre 19 persone hanno completato questa guida.
jgreenmun
Membro da: 03/05/12
876 Reputazione
1 Guida realizzata
Un commento
do you know if it's posible to upgrade the RAM memory in this particular model ?
Thanks for the guide,
Fons - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 9
Tutti i Tempi: 14,533
