Introduzione
MacBook Pro 17" Unibody 2.2GHz early 2011 Duo
Vibrating noise from new MacBook Pro ?
Rattling fan ? Overheating ?
Give this a try !
Cosa ti serve
Remove the dust . I am using a vacuum cleaner here with a brush.
Keep your Apple warranty by disconnecting the battery and DO NO TOUCH any electronic parts and chips ! Also touch any metal item to unload the body static.
Keep your Apple warranty and disconnect the battery.
Altre 12 persone hanno completato questa guida.
6 Commenti
Sanzi Gao - you are welcome!
@laomusicarts do you know where I might be able to get an HD-74501 screwdriver. New or Used?
Since my 2008 Macbook Pro has been overheating for a while I tried this. Unfortunately everything inside is quite clean: no dust in the fans or heat-sinks.
The fans run quite well , and get going pretty fast as the device heats up. Any other ideas are welcome, This was a GREAT machine and I miss using it.
Try replacing the thermal paste, did that and my mbp mid 2010 works perfectly! Dosent even have to be expensive paste, I just used some chinesse one and it worked perfectly!
I now see about 78-82C of temperature with the fans making a small amount of noise. Before I saw from 90-98C and the fans were at 100% almost constantly.
Hope this helps!
