Introduzione
Use this guide to replace the right fan.
Ricambi
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Altre 31 persone hanno completato questa guida.
