Introduzione
Use this guide to replace a broken optical drive in your MacBook Pro 15" Unibody Mid 2012.
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Disconnect the camera cable connector from its socket on the logic board.
Pull the optical drive cable out of the optical drive.
Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
Altre 32 persone hanno completato questa guida.
