Introduzione
Replace a faulty fan to keep temperatures down.
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Use the flat end of a spudger to disconnect the left fan connector from the logic board.
Altre 70 persone hanno completato questa guida.
