Introduzione
Remove the lower case to access most of your MacBook Pro's internals.
  1. Remove the following ten screws securing the lower case to the upper case:
      • Three 13.5 mm (14.1 mm) Phillips screws.
      • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Conclusione
Altre 20 persone hanno completato questa guida.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 57
Tutti i Tempi: 11,057
