Salta al contenuto principale
MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement
Cosa ti serve
  1. MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement, Access Door: passo 1, immagine 1 di 2 MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement, Access Door: passo 1, immagine 2 di 2
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - Replica
    Citazione da aguib:
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - Replica
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - Replica
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - Replica
    On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - Replica
    Citazione da SHerwood Ball:
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - Replica
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - Replica
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - Replica
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - Replica
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - Replica
  2. MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement: passo 2, immagine 1 di 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement, Battery: passo 3, immagine 1 di 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the translucent plastic tab and pull the battery up and out of the Unibody.
    • If the latch is depressed it will lock the battery in place.
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - Replica
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - Replica
  4. MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement, Lower Case: passo 4, immagine 1 di 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 5.4 mm Phillips screw.
    • Three 14 mm Phillips screws.
    • Four 3.5 mm Phillips screws.
    Hi, My name is Jess I need help asap I accidentally dropped my macbook Pro and i cant find the silver screw for the top left back side, Does any one know if I can replace it with an eye glass screw?? If you can help at all Please e-mail me at Chambliss_jess@yahoo.com thx please help me my bf is going off... ;(
    Jess - Replica
    The fixit PH00 is the wrong screw driver for this entire job. It did not fit in the screws, it was too pointy and caused screws to be rounded off.
    mattrittgers - Replica
  5. MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement: passo 5, immagine 1 di 1
    • Using both hands, lift and remove the lower case off the upper case.
    About midway along each edge is a snap. To release each snap, gently slide the flat edge of a Spudger under the lower case, then lift the lower case away.
    jonathansturges - Replica
  6. MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement, RAM: passo 6, immagine 1 di 1
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. MacBook Pro 15" Unibody Late 2008 and Early 2009 RAM Replacement: passo 7, immagine 1 di 1
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
Conclusione
Altre 187 persone hanno completato questa guida.
10 Commenti
Thank you ifixit. It was a breeze... 8Gb in the house... Best Regards
Bruno Perneta Correia - Replica
Hi Bruno!
Assuming you still have the MBP, I am curious to see what memory you installed to get 8 gigs. I just installed 2 X 4 gigs of Kingston PC3 106000 SODIM and my MBP does not want it. My tech assured me that if anything would do it, it was this memory.
Suggestions?
Thank you!
Ghislain
Ghislain -
As a breeze. Man, was my computer dirty! Now my computer feels like it's on amphetamines! Lol. So happy the pinwheels are gone. I can finally get work done and feel right about charging my clients hourly!
jayalovevibes - Replica
Thanks ifixit ... Easy reward & proud 8GB working power.
Tiny note: I wasn't sure weather or not it is important (or not) to remove the stickers from my 2 x 4GB RAM modules - I left the stickers on and it seems all running happily.
Grit - Replica
Installed 8GB of RAM without problems. :)
Been wondering if this system would support 16GB though, given that appropriate modules seem to be on the market, that it has a 64 bit EFI and that the never versions of OS X, booted in the 64 bit kernel (which has been the default mode for a few years, now) obviously support that and more…
jack - Replica
didn’t work, but it was because i did not had the right ram. so, i put my old ram back in, and it just worked fine. thank you, it worked, but not with my ram.
Jef Kockelbergh - Replica
I understand that you placed 2 ram of 8 gb each?
it worked?
Patricio ILLANES -
Thank you all! i just love this site and all the authors and users.
i got a quick question; MBP 5,1 Late 2008/Early 2009
2.66 Ghz unibody
i want to try 16GB RAM
will it work? has anybody tried it?
Thanks
Wael - Replica
Hello, I have a MacBook Pro 15-inch, late 2008 with a 2.4 Intel Core 2 Duo, 6gb 1067 DDR3, 700GB HD, NVIDIA GeForce 9400M 256 MB running OS X 10.8.5 (12F2560). This thing still runs and looks AMAZING. How much more ram can I load it with? What do you suggest to max it out?
Pedro - Replica
Cual es el módulo uno y el módulo dos? El de arriba o el de abajo?
Marcelo Bernal - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 72
Tutti i Tempi: 102,920
