Introduzione
When replacing your hard drive, you must transfer the Torx screws from the old drive to the new one.
Cosa ti serve
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the single Phillips screw securing the hard drive bracket to the upper case.
Remove two T6 Torx screws from each side of the hard drive (four screws total).
Altre 332 persone hanno completato questa guida.
7 Commenti
At step 7, the side screws are very tight. Both T6 Torx and 1.5 Hex keys dont work for me. I fear the screws could get damaged if i try more. How do i unscrew them?
What was your solution to removing the screws? I am having the same isse.
Hello
Sandisk X400 SSD proposed for this macbook works in 3gb/s?
There is a known limitation of nvidia chipset with ssd's who appear to work as sataI instead of sataii.
Thank you
Any news regarding this?
