Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Replace the feet for the early 2011 MacBook Pro 15".
  1. Remove the following ten screws securing the lower case to the upper case:
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. Remove any broken or damaged feet. Remove any pieces from the old foot that may have broken off in the foot hole. Use tweezers to peel up and remove the old adhesive tape from the foot pad.
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. Scrub the foot pad with adhesive remover to remove any remaining adhesive.
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. Peel a replacement foot from the plastic backing.
    • Peel a replacement foot from the plastic backing.
  7. Align the new foot inside the foot pad. Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad. Lay the foot down while keeping it properly aligned.
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
Conclusione
Altre 3 persone hanno completato questa guida.
Arthur Shi
Membro da: 03/01/2018
151.780 Reputazione
401 Guide realizzate
iFixit Membro di iFixit
Community
134 Membri
14.937 Guide realizzate
These are nice rubber feet that are identical to the original in look and feel. Be wary of cheaper versions that are made of hard slippery plastic.
hterlecki - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,720
