Introduzione
Is the right side of your MacBook Pro mute? Use this guide to replace the subwoofer & right speaker assembly.
Cosa ti serve
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Attrezzo utilizzato in questo passaggio:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
Use the flat end of a spudger to pry the hard drive/IR sensor cable connector up off the logic board.
Peel the hard drive cable up from the channel within the subwoofer and right speaker.
Altre 7 persone hanno completato questa guida.
