Salta al contenuto principale
MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
Cosa ti serve
  1. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: passo 1, immagine 1 di 3 MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: passo 1, immagine 2 di 3 MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement, Replace LOGO bezel on the screen,替换屏幕底部LOGO挡板: passo 1, immagine 3 di 3
    • heat the logo bezel(用吹风机小心的加热LOGO挡板)
    • use sharp tweezers,carefully insert the screen gap,pull it out(用尖利的镊子或者刀片小心的撬起LOGO挡板,然后把logo挡板拉出来,玻璃材质的很易碎)
  2. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement: passo 2, immagine 1 di 1
    • Put double-sided tape on the back of the bezel(在新的挡板后面贴上双面胶带)
  3. MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement: passo 3, immagine 1 di 1
    • Install the bezel 把挡板安装到原来的位置
Conclusione
当重新组装你的设备时,请按照说明的相反顺序进行操作。
Altre 13 persone hanno completato questa guida.
n0vem
Membro da: 08/26/17
607 Reputazione
1 Guida realizzata
60 Commenti
I didn't manage to get it off without breaking it so had to order a new one. which was a peal and stick.
mayer - Replica
I don’t understand, when do you need to remove this if it’s not broken already? Are there components underneath that can be replaced/fixed?
Ted -
I have a hairline at the logo baffle if i do not replace it will my screen get harmed?
Please reply ASAP?
Honey - Replica
can u upload the photo, than I can tell u
n0vem -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 78
Tutti i Tempi: 36,251
