Salta al contenuto principale
Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015
Cosa ti serve
  1. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Case inferiore: passo 1, immagine 1 di 1
    • Rimuovi le seguenti viti pentalobe P5 che tengono unita la parte inferiore del case al resto del MacBook Pro:
    • Otto da 3,1 mm
    • Due da 2,3 mm
    The number of screws listed here is wrong on my model. I had four of the smaller size.
    anonymous 1286 - Replica
    Just to add to my comment above (I can't edit it because it's anonymous), my MacBook Pro is a mid-2015 15in model 2.8GHz (A1398; EMC2881). For the bottom case it uses six 3.1mm screws, and four 2.3mm screws at the clutch/hinge side of the MacBook Pro. I tried using a 3.1mm screw at the clutch/hinge end, as described in the main article, and they don't fit. It has to be four 2.3mm screws.
    agreed with above 1286...
    I have the Mid 2015/A1398/EMC 2909. the hinge end and two middle side screws used a 1.2x50mm screwdriver while the 'opening' end 4 screws used the T3 screwdriver. I guess different builds used different sized screws!!
    Tj Bennett -
    The instructions below have you basically taking ALL of the guts out of case. I’ve been doing my own apple repairs since before ifixit was a thing and this one is a handful. My battery was swelling and I wanted to remove it before it burst or bent the case so I took it out without having a replacement and it occurs to me that aside from using the solvent (liquid) to remove the adhesive, you could probably do this only taking the trackpad ribbon out. I have mine reassembled now and will research the best battery to buy but I think installation will take about 5 minutes. See if you can slip a plastic gift card under the battery and wag/saw the adhesive out without the solvent before you go through all of this. It might work. Note, don’t bend or put too much stress on the battery and certainly don’t puncture it…
    br1ansk - Replica
    Battery Recall for 15-inch MacBook Pro Retina mid-2015. Check Apple’s site for recalls, and put in your serial number. They replaced my swelling battery for free, regardless of warranty.
    Steve -
    As we are only replacing the battery, you can safely skip steps 6-26 and 28-48, no need to disassemble the computer to pull out the battery. Use nail polisher remover I was able to pull a super bloated battery out, without disassembling my MacBook.
    John Sikking -
    I qualified for the recall. These bloated batteries are dangerous! DO NOT, UNDER ANY CIRCUMSTANCES, PUNCTURE THE BATTERIES!
    Thanks for the heads-up on the recall.
    Datajockeys -
    For battery replacement, I also chose NOT to remove everything, and NOT to use the solvent. I used an iFixit heating tube (from the iPad kits) to soften the adhesive from the keyboard face… NOT the battery itself! Used the iFixit cards. I have four, so the real work is possible BETWEEN two other cards — reduces the chance of puncturing the battery. Worked fine, took a little while, but no problems.
    Steve -
    I’m having a problem trying to get the screws off. I have a set of pentalobe screwdriver set. I found one screwdriver that fits perfectly on one set of screws, but I am unable to unscrew it. I tried using some force pushing the screwdriver into the screw, but nothing happens. Any suggestions?
    henry_k_wong - Replica
    All the screws on mine are the same length for some reason.
    ccfman2004 - Replica
    I would recommend the first step is: Run the battery down to ZERO before doing any next step. This reduces risk to you, people nearby, to the MBP and greatly reduces the risk of fire. Step 2 should be: Double-check that the battery is at zero.
    I like others listed below and on YouTube, disagree with these full tear down 70+ steps being the only focus. I get that I have to be careful not to get the acetone solvent near the speakers. I skipped 25+ steps by: tilting the MBP away from the speakers and using very little acetone solvent. More pressure with the plastic cards and only a few drops of solvent. While giving the full set of instructions is fine it should be very clear that you can (at the user’s own risk) do this.
    Kenneth Schleede - Replica
    As above—I consider full disassembly to be far riskier to fragile cables and connectors than the risk for solvent spillage. I did steps 1-5 and 46-74. No issues. I HIGHLY recommend the iFixit magnetic Project Mat. It’s a white marker board surface gridded into squares and invaluable for labeling part sizes/steps in disassembly.
    philtrit - Replica
    As above too. I benefitted from the advice. From step 51 onwards, I found a easier way using tip from China battery seller. Use a 2” width plastic scraper/plastic paint scraper to poke under the battery. Use moderate strength to poke and avoid rough handling of the battery so as not to puncture it. There is no need to pry the battery to avoid stressing it, just use a firm poking action under the battery and the double sided tape adhesive will yield. After 5 min of such poking, the entire battery pack can be removed without the hassle of pouring the adhesive remover from step 51 onwards. Get a scraper with a stronger handle so that it is more comfortable to poke.
    https://www.aliexpress.com/item/32889670...
    Emma Pn - Replica
    Heads up as you go…we (husband/wife team) had a notebook that when screws/covers were removed, we marked the step # and actually taped the screws into the notebook noted by the step number. This was very helpful on reassembly and we knew we would be using the exact screw into the original screw hole.
    Ann Brainard - Replica
    After replacing the batteries myself, I wouldn’t even consider doing it again. Not that it’s difficult to do—that’s not the issue. The issue is aftermarket batteries. I’ve been using notebooks for well over 30 years, and never had satisfaction with aftermarket batteries.
    Modern lithium batteries are an amazing technological feat, but a dangerous one. So even putting aside that I’ve never found any aftermarket batteries with quality anywhere near original, I learned “cheap” aftermarket lithium batteries are downright dangerous.
    After doing research into what’s involved with manufacturing lithium batteries, I know there are so many corners to cut, you’ll end up with junk regardless of what you pay.
    A week after replacing my batteries with those from iFixit, they showed clear signs of failure. Thank goodness iFixit refunded my money.
    After having Apple replace my batteries, everything is back to like-new. For my $199, I got not only excellent batteries, but a new keyboard and trackpad as well. That’s it’s done!!!
    AnnoniMoose - Replica
    Which of the following companies make their own LiIon cells, Apple, Dell, DeWalt, Milwaukee, Tesla, Trek? Ans: NONE OF THEM. All these companies buy their LiIon cells from companies that will sell to iFixit or any other legitimate company. If you want quality, either do the research or pay through the nose for OEM. And note the Apple battery recall. Apple messes up too.
    Bartwick -
    I found an Apple Support link that said MBP battery replacement was $199, but the 2 Apple Stores near my house would not provide any appointments. Instead, I scheduled an appointment with and “Apple Authorized Service Provider” & that repair center quoted about $750 to replace the battery.
    I refused, went home, & opened a chat with Apple Support.
    After a lengthy & painful chat session where the Apple tech didn’t want to provide a battery replacement quote (he feared other issues with the MBPr), he finally gave me an Apple price of just under $650 to replace the battery.
    Did you go into an Apple store, or mail it in? I’m struggling to reconcile a price of $199 to get a battery + keyboard + trackpad against what I was just quoted 2 weeks ago. The new track pad & keyboard might have been due to repair tech error. i.e. they trashed those repairing your batter & had to toss them in.
    Bartt.Shelton@gmail.com - Replica
    I took mine in after being quoted for a $199 replacement of battery and keyboard, only to have the repair refused as they found a "water sensor" triggered and now I'm left with my AUD$5,000 laptop with messed up keys. Shame on me for not getting this repaired during COVID while under warranty. This is the first time I've truly been disappointed in Apple, but suppose it was bound to happen someday. I was quoted US$ 1479 to replace the battery and keyboard and the sensor (likely the logic board is replaced as well) if I were to send it in to the US repair center. Any chance these sensors can be triggered by humidity?
    C0RT - Replica
    I 1000% recommend watching this video and performing the battery replacement without all these steps from this guide and without using the acetone solvent. https://www.youtube.com/watch?v=ImonCWcc... (15" inch Retina MacBook Pro A1398 Mid 2015 Disassembly Battery Replacement Repair)
    The video is narrated well and the guy goes slow and zooms in where appropriate. Instead of removing all components, he simply removes the track pad cable, battery cable, and unscrews two of the speaker screws on each side. From there, you can lift up the speaker arms where the video guy uses a thin pry tool to push through the sticky tape. No solvent is needed except for residual sticky stuff leftover.
    Instead of the thin pry tool, I just used the plastic cards that came with this ifixit kit. It takes a little force and wiggle/jiggle so take your time using the corner of the card to start.
    This method makes a difficult 2-3hr job into a much easier 1hr job.
    Spencer - Replica
    +1 for this approach! I watched the video that Spencer mentioned. It took me a little over an hour, and it was stress-free. https://youtu.be/ImonCWcc1xk
    Chris Wicklas -
    Another +1 - I followed the video pretty exactly (after having already gone through steps 1-5 here). I'm not sure it's necessary to clean off the adhesive residue as thoroughly as he demonstrates in the video, but the instructions were clear and the end results were good - trackpad still working fine and new battery already charged to 50%.
    Jeff Zinn -
    Glad I read these comments before plunging into the iFixit instructions.
    +1 for skipping the iFixit instructions and using the youtube video linked by Spencer.
    I followed the instructions and had my battery replacement done succesfully.
    Instead of the metal spatula like thing he used - I used the plastic ifixit credit card things that came with my battery kit.
    It took about 15 minutes of wiggling under the battery to free it from the adhesive but it wasn't too bad.
    I did remove the residual adhesive as he indicated with isopropyl alcohol - but after finishing my installation I realized it was completely unnecessary. You can install the new battery over the residual gunk and skip that step.
    picardo -
    Yes! This YouTube tutorial works great and it was really easy to replace the battery. I needed about 75 minutes.
    Perform steps 1-5,
    Then skip to step 41.
    In 41 + 43 do not unscrew the red marked screws.
    In 42 an 45 just lift the speakers, do not remove them.
    Skip 44
    Up from 53, I did not use the glue remover, the plastic cards were enough.
    In step 63 watch out to start from the middle. This prevents you from peeling up the lower „platform“.
    Great job :-)
    weekendiac -
    It’s now February 2024, and the batteries Apple installed have all swelled up just like the originals. Doing a bit of research on the manufacturer, Simplo, I no longer trust them either. Microsoft used Simplo in their tablets, with countless users complaining about bad batteries. A few days ago, I read a post saying Apple now charges $250 instead of the $200 I paid less than three years ago. WOW! Even if Apple would replace my batteries, there’s no way I’m going that route again. Too bad my MacBook won’t boot without batteries. I don’t need them; I don’t want them. I also don’t want a newer MacBook. What to do???
  2. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 2, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 2, immagine 2 di 2
    • Sollevandolo delicatamente dal bordo vicino alla cerniera del monitor, alza il case inferiore dal MacBook Pro.
    If you buy the entire kit, make sure you use the opening tool! I cut both of my index fingers trying to slide it off.
    Catherine Nath - Replica
    Additionally, this is an “opportunity” to clean the cooling fans - and any other obvious dust magnets - with a can of compressed air. On the laptop I worked on, the cooling fans had sufficient dust to not “spin” freely - showing signs of “drag”. After blasting each cooling fan with compressed air (including from the exhaust vent side, as hitting the fins alone wasn’t adequate), they both spin freely now. No obvious signs of battery swelling on mine, but lack of adequate airflow could have been a factor with original battery aging/failure.
    Zathras - Replica
    Good opportunity to give a good clean out. Air duster and small clean paint brush on plastic surfaces to clean up essential vents and fans. You can load fan monitor and control software to see what your your system is doing and how it improves with a clean up.
    Robin Razzell - Replica
  3. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 3, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 3, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 3, immagine 3 di 3
    • Il case inferiore è dotato di due perni di plastica (evidenziati con i rettangoli in rosso) che si inseriscono nelle clip sempre di plastica nella parte superiore del case (evidenziate nella foto con i rettangoli color arancione).
    • Durante il riassemblaggio, spingi delicatamente verso il basso il centro del case inferiore per riattaccarlo alle due clip di plastica.
    pretty hard to put it back, so I just remove the clips on the upper case....
    jamiegan835 - Replica
    The trick to putting it back on is to guide your fingers to the same level as the clips, and then when you put the case down move your hand from the left side of the case to the right side of the case; applying pressure when you reach the area where the clips are.
    Aaron Freidus - Replica
    Impossible to put those peds into the upper case clips! It just does not hold there, it fits but just does the ‘click’ sound and goes back. Is it possible to buy those clips as spare part? Thank you for help.
    Lopez Loku - Replica
    Same for me. It just never clips, regardless of the precision and the amount of force I apply.
    Vadym Borodin - Replica
    I also think I stripped the screws holding the clips in place. Does anyone know what screw characteristics should I look for as a replacement?
    Bloated battery had already popped my clips.
    jecottrell65 - Replica
  4. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Connettore batteria: passo 4, immagine 1 di 1
    • Stacca lo sticker che copre il connettore batteria.
    You only need to remove the tape to the edge of the flap. This is enough to be able to pry the battery connector up.
    +1 to above comment
    Andrew Saunders - Replica
    Note that the photo is taken from the hinge side - the other way to the photo in step 3
    Toby Thurston - Replica
    I chanced it, didnt disconnect the battery and all is well even after giving the insides a good vacuuming before changing the SSD.
    Dermot O Logical - Replica
    It is just the top layer of tape that you want to lift, you need to seperate it from the bottom layer.
    Kelv - Replica
    You don’t actually need to remove the tape or even peel it off at all. Just pull up the battery connector up with the tape still attached.
    AJ Lorenzo - Replica
    pay attention that the macbook in this picture is presented the “wrong side”: if you accidentally remove the tape covering the trackpad cable and thereby also take the trackpad cable out of the zif-socket, your keyboard and trackpad won’t work anymore. putting the trackpad cable back into the (tiny) socket will fix the issue though.
    sam - Replica
  5. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 5, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 5, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 5, immagine 3 di 3
    • Solleva con cautela ogni lato del connettore della batteria per staccare il connettore dal suo zoccolo sulla scheda logica.
    • Piega il connettore indietro verso la batteria, per evitare che possa fare contatto accidentalmente con la scheda logica.
    why is this necessary to remove a hard drive?
    Lawtay - Replica
    @lawrencetaylor On any electronics repair, you need to disconnect all sources of power before you start. It’s a basic safety precaution and also removes the risk of accidentally shorting a connection somewhere (which can potentially kill your MacBook).
    Jeff Suovanen -
    Picture doesn’t match the computer. Hard to tell which connector to disconnect
    James Mitchell - Replica
    Hi James, are you sure you have the correct guide for your machine? Try using our MacBook Identification tool.
    Sam Goldheart -
    Habe den Akkustecker beim putzen abgemacht um keinen Stromschlag zu kriegen, jetzt wieder eingebaut. Nun habe ich folgendes Problem: Akku wird geladen, aber steigt niemals ueber % und manchmal geht er trotz Anschluss an das Stromnetz einfach aus. Hat da jemand eine Idee?
    paul - Replica
    I used the identification tool and can confirm what James is seeing. The picture doesn’t match for this step. There is no piece with visible holes punched in it.
    Joshua McFarland - Replica
    There is an extra piece of plastic on the connector, you might want to peel that off too. It’s not in the pictures.
    Ellie B -
    There is a battery cover with two T5 screws that must be removed before prying on the connector.
    Dennis Newton - Replica
    Hi Dennis,
    Thanks for bringing this up! I’ll work on verifying this and adjust the guide as needed.
    Arthur Shi -
    My battery connector had another layer of plastic on it that I removed first
    Kelv - Replica
    For an A1398, the screws on the adjacent cover were T6, not T5; one of the tips in the battery kit was suitable.
    Zathras - Replica
    I need dis board hw much
    Ebuka Ofodile - Replica
    After separating the battery connector, I took the addd precaution of placing a folded post-it between the connector bank and the socket.
    Matt Fisher - Replica
    You can also use a plastic tool to hold back the battery connector. My connector was under the plastic tab and had no screws. You may need to check the build version as there are a number of A1398 versions.
    When you install the new battery, it may look like the holes in the connector need to be slid on to the connector toward the rear of the mac. I tried bending the cable to make it work. This could damage the cables. You really need only push directly downward on the connector, as you pulled up on it to remove it initially. It will pop into place with a little pressure, just make sure it's lined up properly.
    Jeffrey Andrews - Replica
    I had to use quite a lot of pressure to make the connector on my new battery pop all the way down. I thought it was down already when it was only half way, as I was afraid to use too much force. Maybe it varies between different battery brands, but just make sure that the connector should go all the way down and not have a gap between the two parts.
    Magnus W - Replica
    " …ensuring that the battery connector doesn't accidentally make contact with the logic board."
    You appear to assume that everyone knows which item is the logic board. I can attest that not everyone does. Clarity here would be helpful.
    Mark - Replica
    If you don't know what the/a logic board is, you probably shouldn't be opening devices.
    Art Hackett - Replica
    Art Hackett. Not useful. This guide is for laypeople. Nobody is supposed to know much of anything. That's the point of the guide and the existence of iFixit. You could have used that time to explain what the logic board is for people who are already here anyway.
    Anyway onward and upward. If you don't know what a logic board is and you're here. https://www.google.com/search?q=macbook+...
    There, now you're an expert like Art.
    fixedtit - Replica
  6. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Cavi AirPort/fotocamera: passo 6, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Cavi AirPort/fotocamera: passo 6, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Cavi AirPort/fotocamera: passo 6, immagine 3 di 3
    • Usa uno spudger o delle pinzette per staccare i tre connettori dei cavi dell'antenna AirPort dalle loro sedi sulla scheda AirPort e ripiegali da un lato in modo che non diano fastidio.
    • I connettori dei cavi sono molto fragili. Fai attenzione a sollevare solo i connettori e non i cavi o le prese.
    • Per riconnetterli allinea il connettore in posizione corretta sopra la presa e premi sul connettore con la parte piatta di uno spudger.
    I seriously hate this step - it is pretty much the only difficult part of the job. Reconnecting these microscopic stinkin connectors is a monumental PITA…
    T Rowe - Replica
    Guys, be very carefull with these 3 cables.. If you are not going to replace the whole display, just be careful as much as possible.
    Adi - Replica
    When reconnecting these tiny wires, use one hand to guide and align the connector by holding the wire and the other hand to press them down with a flat end of a spudger. Spent 10 minutes figuring it out and connecting the first one, then only a few seconds on both of the remaining connectors :)
    If you try to do this with one hand, it’s extremely easy to move them out of the alignment while pressing them down.
    Aivar Kavshevich - Replica
    I think there is a better way - where you disconnect the wifi card using the black screw in middle of wire 2 and 3 first and then untie these connectors. I pryed away the connectors but the sockets on the card were all damaged during the process. Ended up having to get a replacement card before reassembly could be completed. So again there are 2 components - connectors which are being pryed away and really fine and delicate socket. Very easy to damage them. Better to take the card off and delicately peel these connectors off. I would not recommend using these pry sticks mentioned here for that.
    Abhishek Kathuria - Replica
    ATTENTION ! Cette étape est grandement sous-estimée, aucune mention de la délicatesse de l’opération contrairement à d’autres étapes bien plus facile… De plus, il semble possible de sauter cette étape en déconnectant seulement la carte comme expliquer sur la version anglophone du guide !!! J’ai endommagé le connecteur le plus proche du ventilateur, pour rien… Heureusement, tout semble fonctionner correctement…
    Antochny - Replica
    AirPort/Camera Cables? not AirPort/Bluetooth Cables?
    Marco Cappelli - Replica
    Je confirme qu’il est plus simple de déconnecter la carte (enlever la vis, et tirer délicatement sur la carte) que d’enlever les trois cables / I confirm that it’s a lot easier to disconnect the Airport card (just remove the screw and pull gently) than removing those 3 wires.
    Maen J - Replica
    Agreed with Abhishek - removing the wifi card first makes this much easier.
    Tammer Saleh - Replica
    How do you know which is which when reassembling?
    Bryan Province - Replica
    I highly suggest against disconnecting these wires. It's very likely that you will damage either sockets or wires. Do as others recommend, just remove the network card. Prying tool is not good for this step. I broke 1 out of 3 sockets. I wish I read all the comments before operating. Now I gotta get another card :(
    Adomas Aleknavičius - Replica
    what size driver does this require? My pentalobe doesnt seem to be the right size.
    jack32878 -
    As many have mentioned, don’t disconnect the wires is reallly a pain in the a… to connect them, it wont be easy and will take a lot of patience….. Better disconnect the card and carefully leave the wires connected.
    ilukewitschalejandro - Replica
    Just finished replacing both speakers using this guide. VERY good. I did not remove the individual wires - just removed the card with wires attached. Seemed to be the safer, easier way to go.
    Dwight Vaughn - Replica
    How? can you explain the procedure?
    Cosimo Soderi -
    I’m attempting taking the card out but leaving the wires attached as mentioned. A Torx T5 worked for me on that screw. I then very slightly lifted up the end of the card where the wires are attached and pulled it straight out of the slot on the opposite side.
    Sean Gabel -
    Just finished replacing my display LVDS Cable with this guide and another one; awesome. I as well just removed the card and left the wires attached. Much easier.
    Alex DeLeon - Replica
    This is one of those skills that you get experience right after you need it.
    I learned these connectors doing RF work. They require a deft touch. Put slight downward pressure while you work to align the pair. Once you get the hang of it, you will know when they are aligned, and they will go back together with a light push and make a slight snap.
    If they don’t immediately pop together with a light push, they’re not aligned quite right. Don’t force them, they have a very limited number of make/break cycles.
    The cables should retain their bent shape well enough to show where each goes. One it too short to go too far off, and one is too long to fit to the nearest connection.
    prreitz - Replica
    I did not bother with the danger of removing cables or cards or logic board. I spent 30 mins removing my battery carefully, using string and CT1 multisolve which isn’t dangerous to plastic.
    i slid my string under the battery and see-saw underneath and sprayed Ct1 Multisolve underneath. I’ve now done both my macbooks. Didn’t destroy any cables or risk it. I put a few paper sheets over my logic board to cover any spray back. Simple see-saw and a palstic card, the blue spludger and the black long spluger.
    T Master. - Replica
    Yes, I did the full board disassembly on my 2012 macbook last year and once I finished I kind of wondered why I didn’t just work on removing the battery. Is there any real obstacle to doing so here? Can I just spend an hour or so carefully removing the battery? What’s the risk of doing that? again, is there any actual obstacle to removing the battery without pulling out the whole board assembly?
    Brian Lamb -
    You can go straight for the battery if you’re confident enough to improvise a little. Removing the board makes sense if you’re trying to protect the speakers from getting chewed up by the solvent. Otherwise, it’s faster and easier to leave the board in place.
    Jeff Suovanen -
    Agreed. Just replaced the battery on my 15” MacBook Pro 2015 and I skipped all instruction between step 6 and 46. I just unplugged the battery and removed the trackpad connection. Used some dental floss to cut through the adhesives and a card to help with carefully prying the batteries up. After the battery was removed I used some isopropanol to clean up from the old glue. Installed new battery, attached the trackpad connection ribbon and connected battery. All in all it took me less than one hour. I would not recommend removing the whole logic board just to replace the battery.
    Mackie72 -
    I’m one of those unfortunate ones that simply followed the iFixit instructions before reading the comments. On successfully reconnecting 2 of the cables and (miserably) failing with the 3rd, I realized the relevance of the comments. I decided to take a gamble and leave the 3rd connector unconnected and fired up my MacBook … strangely enough, everything works fine i.e from the comments, WiFi, Bluetooth, Camera (et al) should be affected but they are all still fully operational (maybe they’ll die with time - I hope not). I don’t like the thought of an unattached cable lying around in my Mac hence I agree with those advocating for alternatives to this step (unhinging the WiFi card as opposed to prying these cables).
    Otim Samuel - Replica
    Diese drei winzigen Stecker wieder aufzusetzen war tatsächlich die größte Herausforderung der ganzen Reparatur! Wichtig ist dabei darauf zu achten, diese waagerecht und passgenau aufzusetzen. Ich habe dazu die Lupe meiner Lötvorrichtung genutzt und zum aufdrücken die flache Seite des Spudgers.
    Werner Hampl - Replica
    These antenna connectors are the worst to reconnect. Depending on the model and what repair you are doing, you may not be able to avoid disconnecting them.
    We took the advice of leaving the wires attached to the card, and unhinging the wifi the card cable. Worked great for us.
    Ditto on just removing the card and leaving the antenna connected. Worked fabulously.
    If you do need to get the cables back on the the card, I have found good results using the tip of a T5 driver to gently push them down (of course while aligning carefully with other finger). It gives a firm, flat & precise surface to press with + we know you have a T5 around!
    Tech Medic - Replica
    Why do these wires/sockets need to be removed at all? They seem like they are pretty faraway from the battery.
    John Sikking - Replica
    Can I replace it with early 2015 monitor? Couldn’t find a cheap mid 2015 one but I found a reasonably priced early 2015 one and I would like to have it ?
    Mohammed - Replica
    If you’re just replacing the battery, after step 5 you can skip everything else except 26-27, 34, and 50, and then continue from step 56 onwards. Instead of needing an adhesive removal, I just used a credit card to separate the battery cells from the casing they’re glued to.
    Petr Bela - Replica
    After step 5, I would skip 26-27, 34 and just to 46-50. You need to remove the cable from the battery, so even if you do 26-27 and 34, you'll need to do 46-50.
    I use the solvent to remove the left over glue after the battery has been removed, but have been able to separate the battery by just sliding a card between the battery and case.
    maccentric -
    I'm here to tell you that it is possible to remove and reassemble these wires, despite all the above comments making it seem almost impossible. I was planning to remove the entire card instead, but accidentally popped one of the wires when trying to get the card out. So then I just figured I might as well follow the instructions. Popping them was easy, getting them back on was a bit more tricky. Use a fine tip plier to hold the wire and place the plug in place, then press down (quite firmly!) with a spudge or something flat (I would advise against using a metal tool such as the torx driver, in case you slip and hit something). As long as the plug is directly above the connector and aligned properly, you won't break it. Use a good light source and a magnifying glass if needed. I brought my adjustable desk up to eye level so I could come really close and see what I was doing.
    Magnus W - Replica
    Before removing the wires, I recommend marking each with for example some tape so that you know in which socket to place them when reconnecting them later.
    Lennart Philipp - Replica
    I got to this step and read a few more and was like oh shoot. I cannot be without my laptop if i mess something up and break a cable. The advice was right. I skipped all the extra removal pieces and just removed the battery. I did step 1-5. Then did step 26 and 27. Then steps 33 and 34. The finished with steps 46-51. I didn't have the blocks so i bypassed putting the laptop on a slant. so after step 51 i skipped to 56 and just started prying off the battery with a credit card and other ifix it tools. I do think the adhesive remover would be very helpful. I also wore goggles cause i caused a spark when i accident poked one of the batteries. Laptop is fine but it is very time consuming and difficult. I recommend getting the kit with the battery. Its only 10 bucks more and i think it would have saved me heaps of time!!!
    kyle hansen - Replica
    Just don't do it! Like is says at the beginning, if you use a mild solvent like isopropyl alcohol, you can skip steps 6 - 45. My battery was pretty swollen and had already partially detached itself, so a little alcohol and some working with the plastic cards was all it took to get the battery freed up. Saved a lot of risky work!
    Sandy Trevor - Replica
    This video shows how to remove the battery without all the steps explained here https://www.youtube.com/watch?v=JZ_jB9fR...
    Sam Decrock - Replica
    If you are careful, you can completely skip steps 6-25 and 28-45 and remove the battery pretty easily; I have done this battery replacement several times and did not have to disassemble the entire MacBook to do so.
    Gregg Stanley - Replica
    Holy cow I removed the battery using the linked video’s technique and some patience. The batter is stuck to the chassis with double-sided tape. With care the battery can be removed without dissolving the adhesive or removing all of the parts. It seems to me that the risks of carefully removing the battery from the tape are lower than removing all of the components as presented in these instructions.
    BingoOnTheBall - Replica
    Take the Wifi-card out instead! It's just one screw.
    Johannes Prem - Replica
  7. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 7, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 7, immagine 2 di 2
    • Stacca la copertura destra di gomma dalla ventola e ripiegala verso l'esterno.
  8. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 8, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 8, immagine 2 di 2
    • Usa la punta di uno spudger per spingere il connettore del cavo della fotocamera fuori dal suo zoccolino sulla scheda logica.
    • Accertati di spingere parallelamente alla scheda, prima da un lato e poi dall'altro, per far "camminare" il connettore fuori dalla sua sede.
    This connector is very fragile, the left edge of mine cracked off and ended up in the socket. And during figuring that out the cable or the socket appears to have got damaged because “no camera detected”.
    malhal - Replica
    Yeah, same here.. Not sure what to do now
    Roman Kroupoderov -
    Have you found a solution to this problem ? I have the same issue
    Tim Rault -
    All connectors are incredibly fragile. I damaged the fan connector locking latch just by trying to lock it back in place. Fortunately the cable, by the way it inserts, it’s being pushed in rather than pulled on, however, I do have concerns with it not making a proper connection. Malcolm, I am wondering how you fixed your damaged connector?
    Robert Habib - Replica
    The connector slides into the socket so using the flat end of the Splunger under the cable and gently lifting draws the connector apart.
    Don’t use the flat edge of the spudger. Instead, use the pointed end to gently slide off by the dog ears of the plug. If you look closely you’ll see a notch on each side.
    John Xeno -
    supplied tool does not have a fine enough point here - won’t move at all
    Paul Forgey - Replica
    I used the fine point and also used the tweezers under the plug to relieve some pressure. I was very, very careful and made small moves. I seemed to get it out with no damage.
    Al Moulder - Replica
    I personally used my tweezers and this came out with ease and without issue.
    Metz Jnr - Replica
    Thanks for your comments guys! The ones about the twiners were a BINGO! :-)
    Einstein (not Albert) - Replica
  9. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 9, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 9, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 9, immagine 3 di 3
    • Usa le dita per tirare via dalla ventola i cavi AirPort/fotocamera.
    • I cavi aderiscono alla ventola, quindi staccali con cura per evitare di danneggiarli.
    • Sfila con attenzione i cavi dal passacavo in plastica.
    • In fase di rimontaggio, ci dovrebbe essere ancora abbastanza adesivo su questi cavi per fissarli di nuovo alla ventola.
    Leave them attached. Remove the single screw holding the board in place and gently wiggle the airport card out (see Airport card removal instructions). Fold the card up and towards the rear of the computer. Now follow the instructions for the camera cable removal. Lift the airport card with the three leads attached and the camera cable up and fold the, to the outside of the case.
    George R. O'Connor - Replica
    This video shows how to do it safely: https://www.youtube.com/watch?v=AabLlHT5...
    Undo the 3 cables gently. remove the airport card. gently pry away the cables fro the fan plastic. then the camera cable will slide out easily.
    T Master. - Replica
    I was afraid to just pull on any cables adhered, so I used a spudger edge to very gently “scrape” them up instead.
    It was much easier following the instructions on the YouTube video, thanks! Looks like the process starts around 4:11.
    Darnell Remy - Replica
    why are we completely tearing the computer, just to replace the battery?
    surely tearing it down could do more damage than being careful removing the bloated battery
    Russell G Stewart - Replica
  10. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Cavo scheda I/O (superiore): passo 10, immagine 1 di 1
    • Rimuovi le due viti Torx T5 da 2,2 mm che fissano la copertura del connettore del cavo della scheda I/O.
    why is this needed for upper assembly replacement?
    Andrew Chu - Replica
    My cable connector covers are not screwed down. Mid 2015 15” MBP. That’s the computer in the title of this article so idk.
    Andrew Sauk - Replica
    I’m having trouble breaking the 2.2 mm screws loose and I don’t want to strip the head. I’m using the T5 screwdriver. Does anyone know any tricks or suggestions?
    Madeline Young - Replica
    Ok, so the correct size Torx is the T4, not T5
    Madeline Young -
    Is this really necessary just to replace the LEFT speaker?
    Troy Havard - Replica
    I'm replacing the speakers and one of these 4 screws is longer than the others. unclear of it's size so it helps to pay attention to the size/what they look like when taking them out!!
    Tj Bennett - Replica
  11. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 11, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 11, immagine 2 di 2
    • Rimuovi la copertura del connettore sinistro.
    • Usa l'estremità piatta di uno spudger per sollevare dal suo zoccolino sulla scheda logica l'estremità sinistra del cavo della scheda I/O.
  12. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 12, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 12, immagine 2 di 2
    • Rimuovi la copertura del connettore destro.
    • Usa l'estremità piatta di uno spudger per sollevare dal suo zoccolino sulla scheda logica l'estremità destra del cavo della scheda I/O.
    When re-assembling, the right connector cover is the smaller of the two.
    richardgraham_2000 - Replica
  13. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 13, immagine 1 di 1
    • Stacca il cavo della scheda I/O dall'adesivo che lo fissa alla ventola.
    • Rimuovi il cavo.
    Cable need not be removed.
    mayer - Replica
    Totally agree.
    John Gerdes - Replica
  14. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Ventola destra: passo 14, immagine 1 di 1
    • Usa un cacciavite Torx T5 per rimuovere le seguenti tre viti che fissano la ventola di destra alla scheda logica:
    • Una vite da 5,0 mm con una parte cilindrica lunga 2,0 mm
    • Una vite da 4,0 mm a testa larga
    • Una vite da 4,4 mm
    The orange colour coded one is more mushroom shaped than the other screws (their size is not easy to otherwise tell apart)
    Howard Graff - Replica
  15. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 15, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 15, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 15, immagine 3 di 3
    • Usa la punta di uno spudger per far scattare la linguetta di bloccaggio sullo zoccolo ZIF del cavo piatto della ventola destra.
    • Poni attenzione a far leva sulla linguetta di bloccaggio incernierata e non sullo zoccolo stesso.
    A note about these ZIF sockets - the retaining flap is just held in place by the small amount of friction, and on reassembly they can separate. I learned to push them down with my finger when possible, or else with a flat end, carefully walking them down side by side to keep it as even as possible. If the flap separates all is not lost ! It’s quite difficult (I did almost everything in this guide with tweezers under magnifiers) but if you remove the cable first, you can get the plastic “comb” back under the pins and up into it’s original position, then replace the cable and try again.
    I was gonna comment that I broke the retaining flap off the connector, but per Matt’s comment above I guess it just separated off.
    Anyways while holding the flap part in a pair of needle nose tweezers the tweezers closed and shot the flap off like a bullet somewhere in my living room lol. So be careful if it does separate on you haha.
    Robert Perez - Replica
    These plugs are HORRIBLE. Make sure you only pull the ribbon. All three of my ribbons came off with the plastic clip, and they are impossible to put back on. I broke all three of these the same way. (Both fans and the mic) Everything else was pretty easy. Anyone need a door stop?
    Fernando Segura - Replica
  16. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 16, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 16, immagine 2 di 2
    • Solleva la ventola e spingi la con cautela verso il bordo posteriore del MacBook per liberare il cavo della ventola dal suo zoccolino.
    • Il cavo della ventola potrebbe aderire alla scheda logica: in questo caso, per evitare di stirarlo, staccalo con attenzione mentre sollevi la ventola.
    • Rimuovi la ventola.
    I recommend pushing the cable connector away with a spudger instead of using the fan to pull it away…there seems to be too much stress put on the cable using the method proposed here.
    Bill Klemme - Replica
    Using a spudger does help alleviate stress on the cable. I also used it to help get the cable up from being adhered to the logic board.
    Joshua McMillan - Replica
    Adding to the other comments, the fan is very light and has no resistance lifting out of the place it sits in.
    I carefully lifted the fan just before there was any tension on the cable.
    With the fan held in my right hand and spudger in my left, I moved the spudger under the fan approaching from the left side.
    This allowed me to easily place the flat end of the spudger under the cable where the thicker plastic sits and gently pry the cable up until the cable broke away from the body.
    I then used the pointed part of the spudger to gently pry the connector part of the cable away from the socket while gently pulling the fan away until the cable was disconnected and the entire fan was free.
    David Carroll - Replica
    Terrible instructions on this one. I thought I was supposed to pull the cable off the bottom of the fan! Not photos showing the final result. Finally the cable on the right came away from the board and out of the socket with the flap lifted up. Please make this clearer or damage to the cable can take place.
    peter - Replica
    Instructions are faulty. After removing fan screws and lifting the retaining flap, lift the fan with one hand while gently pushing the connector with the flat side of a spudge toward the back of the chassis. It should slide off.
    codyking411 - Replica
    I definitely needed to use the spudger to gently lift the cable from the board while holding the fan with one hand. The cable was stuck on the board pretty well. Once I broke the seal it was a simple case of pushing it out of the connector.
  17. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Ventola sinistra: passo 17, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Ventola sinistra: passo 17, immagine 2 di 2
    • Stacca la copertura in gomma di sinistra dalla ventola e richiedere in modo che non dia fastidio.
  18. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 18, immagine 1 di 1
    • Rimuovi le seguenti tre viti che fissano la ventola di sinistra alla scheda logica:
    • Una vite Torx T5 da 3,6 mm a testa larga
    • Una vite Torx T5 da 5,0 mm con una parte cilindrica lunga 2,0 mm
    • Una vite Torx T5 da 4,4 mm
    the yellow one may not go back in during reassembly unless the board is perfect. Stripped mine in the effort - put back together without this screw :(
    I ran in a similar misalignment so had to bend the top left loop a bit to make it fit.
    Not a big issue, but better to lay it in and check the alignment of all screw holes (and adapt if necessary) before putting the screws in.
    I saw my replacement part had already a bit of paint missing at the top left and bottom right holes, so I assume it is a refurbished or sourced part, so a bit of tweaking may be necessary. BTW, the fan works perfectly, no more annoying clicking noises.
    Maarten S - Replica
    The red-coded one is the most mushroom-shaped screw this time. (biggest, flattest screw head)
  19. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 19, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 19, immagine 2 di 2
    • Usa la punta di uno spudger per far scattare la linguetta di bloccaggio sul lo zoccolino ZIF del cavo piatto della ventola sinistra.
    • Poni attenzione a far leva sulla linguetta di bloccaggio incernierata e non sullo zoccolino stesso.
  20. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 20, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 20, immagine 2 di 2
  21. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, SSD: passo 21, immagine 1 di 1
    • Rimuovi la singola vite Torx T5 da 2,9 mm che fissa l'SSD alla scheda logica.
  22. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 22, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 22, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 22, immagine 3 di 3
    • Solleva il lato dell'SSD quanto basta perché superi in altezza l'altoparlante che si trova subito dietro.
    • Non sollevare troppo l'SSD perché potresti danneggiare i contatti con lo zoccolino.
    • Tira l'SSD fuori dal suo zoccolino sulla scheda logica.
  23. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 23, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 23, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 23, immagine 3 di 3
    • Usa la punta di uno spudger per sbloccare il meccanismo di fissaggio del connettore della scheda I/O.
    • Gira lo spudger e usa l'estremità piatta per far scorrere il cavo I/O fuori dalla sua sede.
    • Spingere sul meccanismo aperto di sblocco è un modo semplice per far scivolare fuori dal suo connettore il cavo I/O. In questo modo si evitano danni accidentale il cavo o i contatti del connettore.
    Oh, you rotated the computer while I wasn’t watching.
    prreitz - Replica
    That's really tight on this connector. I found it slightly easier to reconnect with the expansion board not in place..
    Alan Dike - Replica
    The locking-bail is on the the cable part of the connector.
    Richard Bugg - Replica
    I think it would be easier to understand if there was a picture showing how the connector slides out
    Owen Smith - Replica
  24. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 24, immagine 1 di 1
    • Rimuovi le due viti Torx T5 da 3,1 mm dalla scheda I/O.
    Remove the screw holding the heat pipe, it blocks the I/O board from coming out
    Gert Cuykens - Replica
    It's interesting that you had to remove the heat pipe screw. This didn't seem to be in the way for me. The I/O board came out quite easily without any issues.
    But… it could be different for others as it was for you. I just thought I'd share my experience.
    David Carroll -
    Thanks for the tip! I also had to remove that screw to get the board out.
    maccentric -
    The board was not coming out for me until I removed that heat pipe screw. Thanks for the tip!
    Al Moulder -
    Also make sure the I/O cable removed on previous step is out of the way before screwing this down
    Keith Kern - Replica
    Me too. The heat pipe screw overlapped the I/O board slightly, but very securely held it down on mine. Had to be removed.
    Patrick Nance - Replica
  25. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 25, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 25, immagine 2 di 2
    • Solleva lievemente il bordo interno della scheda I/O e spingi la scheda stessa verso il centro del MacBook, lontano dal bordo laterale.
    • Rimuovi la scheda I/O.
    You do not need to undo all the screws, just the thin strip over the battery and the battery connection to the motherboard. I used isopropyl alcohol and a metal business card to slide under the battery and worked my way from left to right. Cover the leading edge of the metal business card with isopropyl and it will be easier, it deteriorates the glue and eases the process. Took 5-7 minutes. Tried to add photos to show it was possible, but this site wouldn't let me.
    Johan Angjellari - Replica
  26. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Gruppo scheda logica: passo 26, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Gruppo scheda logica: passo 26, immagine 2 di 2
    • Rimuovi le due viti Torx T5 da 2,2 mm che fissano la copertura del connettore del cavo del touchpad sulla scheda logica.
    • Rimuovi la copertura.
    I'm confused why it's necessary to remove the entire logic board to replace the right speaker?
    Don't you just need to remove the I/O board for the right speaker?
    Steve Rieck - Replica
  27. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 27, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 27, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 27, immagine 3 di 3
    • Usa l'estremità piatta di uno spudger per disconnettere il connettore del cavo del touchpad dal suo zoccolo sulla scheda logica.
    • Torcere lievemente l'estremità piatta di uno spudger è un modo facile per staccare il connettore del cavo da questo tipo di zoccoli.
    • Attenzione a far leva solo sul connettore e non sullo zoccolo della scheda logica.
  28. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 28, immagine 1 di 1
    • Rimuovi il piccolo coperchio di gomma della vite all'estremità del dissipatore.
  29. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 29, immagine 1 di 1
    • Rimuovi le seguenti sei viti che fissano il gruppo della scheda logica al case superiore.
    • Una vite Torx T5 da 3,8 mm
    • Due viti Torx T5 da 5,7 mm
    • Una vite Torx T5 da 5,6 mm (color argento e con una testa più alta rispetto alle altre)
    • Una vite Torx T5 da 2,6 mm
    • Una vite Torx T5 da 3,2 mm
    • In fase di rimontaggio, sistema tutte e sei le viti ma aspetta a fermarle la scheda logica finché tutte le viti sono centrate nei loro fori e le porte esterne sono allineate con le loro aperture sul lato del case superiore. A questo punto blocca tutte le viti.
    Top left and right screw (red, yellow) are silver, the other ones black.
    Peter G - Replica
    Screw with blue circle was in a slightly different position on my logic board; the gold plating surrounding it is the giveaway.
    prreitz - Replica
    This step is really best done after all the cables are removed (Step 40).
    maccentric - Replica
    On the other hand, when reassembling, keep the screws until this step 29
    The red screw above is the same one I had to remove to remove the I/O board back in step 24
    You should really do this colorblind-proof...
    Alessandro Arnone - Replica
  30. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 30, immagine 1 di 1
    • I passi seguenti illustrano in dettaglio la disconnessione di questi sei connettori. Accertati di leggere ogni passo, perché questi connettori sono di tipi diversi e si staccano in modo differente tra loro.
    • Cavo microfono
    • Cavo altoparlante sinistro
    • Cavo dati tastiera
    • Cavo altoparlante destro
    • Cavo retroilluminazione tastiera
    • In fase di riassemblaggio, assicurati di aver ricollegato tutti questi connettori e che siano completamente in posizione nelle loro sedi.
    • Inserisci qui la traduzione
    Save this step until you get to step 40
    I would wait until after step 39 to remove these screws. Once they are removed, the logic board jiggles around and makes disconnecting the various cables in 31-39 more difficult.
    Daniel Christie - Replica
    Bild/Schritt 30: Bitte beide Wörter "Lüfters” durch “Lautsprechers” ersetzen
    Norbert - Replica
    Agree with Daniel Christie. Wait until step 39.
  31. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 31, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 31, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 31, immagine 3 di 3
    • Usa l'estremità di uno spudger per sbloccare la linguetta di fissaggio sullo zoccolo ZIF del cavo a nastro del microfono.
    • Tira fuori dal suo zoccolo, in direzione parallela alla scheda logica, il cavo a nastro del microfono.
    This cable was pretty hard to remove at first. I had to gently wiggle it from side-to-side in the socket before it would let go.
    Jamie Flournoy - Replica
    I had the same issue. This was the hardest cable to remove imo. i was afraid i was going to tear it which as hard as i needed to pull it. I ended up leaving this cable inserted until the logic board was fully unscrewed to give me a bit more wiggle room.
    Joseph Dale -
  32. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 32, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 32, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 32, immagine 3 di 3
    • Usa l'estremità piatta di uno spudger per sollevare il connettore dell'altoparlante sinistro e staccarlo dal suo zoccolo sulla scheda logica.
    • Accertati di far leva sul connettore del cavo e non sul suo zoccolo sulla scheda logica. Far leva sullo zoccolo può portare al suo distacco dalla scheda logica.
    • Piega con delicatezza il cavo per allontanarlo dalla scheda logica.
    this cable was stuck down, so I had to wiggle the spudger under the cable first to separate the adhesive. Then it came away easily.
    Pete Bagnall - Replica
    Same here, the cable was stuck down pretty. Thanks Pete, your advice helped a lot.
    Al Moulder -
  33. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 33, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 33, immagine 2 di 2
    • Stacca il nastro adesivo che copre il connettore del cavo dati della tastiera.
    I wasn’t able to re-stick my tape during reassembly, not sure if that will cause issues but I’m not sure how to fix it.
    aBrightBlur - Replica
  34. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 34, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 34, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 34, immagine 3 di 3
    • Usa la punta di uno spudger per sganciare la linguetta di bloccaggio sullo zoccolo ZIF del cavo dati della tastiera.
    • Accertati di far leva sulla linguetta di bloccaggio incernierata e non sullo zoccolo.
    • Tira fuori dal suo zoccolo il cavo dati della tastiera. Attenzione, devi tirare in direzione parallela alla scheda logica e non verso l'alto.
    The retaining flap broke on me during reassembly. I was careful, but it kind of got stuck. Pay extra attention and if it doesn’t give, don’t force it.
    vincentdrummer - Replica
    Same thing happened to me. Didn’t really put much pressure either.
    meadowsd -
    Same there here.. I ended up using some tape to ensure the cable stayed seated upo nreassembly
    Alan Dike -
    hey its not a kick, take it easy on it. after replacing my battery my keyboard (and not Richards keyboard) and track pad are non responsive, Russell Stewart old neighbour .
    Russell G Stewart -
    The last picture doesn’t show it but my cable had blue plastic material on both top and bottom, which I had not noticed during disassembly. It slid in nicely but now not sure if it is an insulating material of some kind that should have been set aside?
    I can confirm blue colour of cable tip.
    Mighty Sashiman -
    The retaining flap broke off on us during reassembly also…we (husband/wife team) were very careful, but the center piece just broke out when we applied pressure. the blue material did fit under the cable socket (like a smooth blue ribbon), but without the retaining lock, was unsure it would stay in position. We pulled the tape over it and hoped all would work. Everything seems to be working fine for us.
    The retaining flap broke on me as well and caused a near panic. I actually managed to fix it by careful inspection under magnifier and some trial and error with tweezers. The retaining flap itself is comb shaped - a solid edge and then combs that come out between the wires., and apparently just held in by the tiniest of detents. After trying unsuccessfully to push it back down between the wires, I surmised that the gaps in the “comb” side for the wires were sealed loop and that the wires it sat on were open ended. So I eventually ended up lining the flap up as if it were closed, and then carefully nudging it up onto the top wires, which was succesful, and then pushing it back into the open position to get the detents in place. Then to close it after reinserting the cable I walked it down bit by bit by pushing forward and *downward* on each side to help it maintain it’s ‘hinging’ effect. I think frankly you’re better off pushing larger ones like these down with your finger instead of a tool.
    To close my retainer during reassembly I ended up using the side of the iFixit spudger. I pressed against the entire length of the retainer in order to apply equal pressure along the whole thing. It seemed to work well.
  35. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 35, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 35, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 35, immagine 3 di 3
    • Usa la punta di uno spudger per staccare il connettore dell'altoparlante di destra, sollevandolo dal suo zoccolo sulla scheda logica.
    There's not much space here to work with. I found it helpful to remove the screws holding down the battery board, which allowed it to be lifted out a bit for easier access to this connector.
    I used the tweezers on this and that was very effective in popping this cable out.
  36. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 36, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 36, immagine 2 di 2
    • Usa la punta di uno spudger per sollevare il connettore della retroilluminazione della tastiera dal suo zoccolo sulla scheda logica.
    On reassembly it would be great to have some tips on how to properly locate this connector…it’s kind of fussy.
    Thanks for calling this out. I took a picture of the socket after disconnecting. I can see why it might have been less obvious on reassembly.
    David Carroll -
    Also on reassembly - when putting in the logic board make sure this connector is not underneath. Once you have the logic board in, double check and if needed you can slightly lift up the logic board (like to take it out) and use the spudger to scoop it out.
    Jason Joyner - Replica
    I found that this was actually really easy to get back on by using my finger instead of a tool, as I could just wiggle it back and forth slightly until I felt it seat. Hopefully using your fingers isn’t verboten - I was strapped in at the time and everything worked out in the end.
    the picture is mirrored
    Daniel Luescher - Replica
    The picture is not mirrored if you see the heat sink that curves to the up and left it is not mirrored.
    Will Greider -
    Ensure the board is completely lined up when reassembling. The cable is incredibly fragile, and I unfortunately ripped mine when trying to line it up. Avoidable error.
    Metz Jnr - Replica
  37. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 37, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 37, immagine 2 di 2
    • Usa la punta di uno spudger per sganciare il blocco del cavo dati del display e ruotalo verso il lato della porta di alimentazione MagSafe2 del computer.
    +(mit dem schwarzen Klebeband zusammen)
    Verwende die Spitze eines Spudgers, um den Verschluss des Displaydatenkabels nach oben zu klappen (mit dem schwarzen Klebeband zusammen) und ihn in Richtung MagSafe 2-Powerport zu drehen.
    Mihály Plajner - Replica
    My mid-2015 has a flexible plastic tape on the cable lock bar, pulling the tape up with tweezers easily rotated the locking bar.
    prreitz - Replica
  38. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 38, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 38, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 38, immagine 3 di 3
    • Tira fuori dal suo zoccolino sulla scheda logica il cavo dati del display.
    • Non sollevare verso l'alto il cavo dati del display, perché il suo zoccolo è molto fragile. Tira il cavo parallelamente alla superficie della scheda logica.
    • Non toccare con le mani o altri strumenti i contatti sul connettore dati o sul suo alloggiamento, perché potresti sporcare o danneggiare i pin.
    • Con delicatezza piega il cavo dati del display verso la cerniera del display, per rendere accessibili le viti sulla scheda MagSafe2.
    The wording of the instruction: “Pull the display data cable STRAIGHT OUT of its socket on the logic board” could lead to errors. It almost happened to me.
    Instead you should word it: “Pull the display data cable parallel to the face of the logic board being careful to keep it straight and NOT LIFT UP on the cable”.
    I realize you mention it later in the warning immediately below, however, by first saying “pull the cable straight out” leads to confusion and could lead the user to attempt to interpret “PULL STRAIGHT OUT” as “PULL UP” unsuccesfully only to later notice, maybe after breaking it, that there was a warning.
    Wording it properly the first time will make the warning unnecessary.
    I had the same thought as I almost proceeded without noticing the red text warning.
    I especially think the second warning about not touching the contacts on the data connectors should be listed before the instructions on removing it.
    David Carroll -
    Agree with Robert. Suggest “SLIDE the display cable to the right, out of its socket…” would be less misleading.
    prreitz - Replica
    I think it bears repeating just how fragile this connector is, particularly on reinsertion. The problem isn’t just technicians touching the connector end; you can damage the pins simply by inserting it slightly out of alignment, or at an angle, because the outermost pins are VERY close to the edge and are very fragile. They have the appearance of being embedded in the connector but they’re actually spring traces just lying on top of it. I managed to bend the southmost pin upwards reinserting it; luckily it flattened out again and worked, but if it had not been possible to do that it’d have been a whole new screen assembly.
    Jerome - Replica
    I’m pretty sure I inadvertently touched the connectors. Would this cause immediate errors or obscure, difficult-to-diagnose problems later in life ? Also strongly suggest using magnification when disconnecting and reconnecting this connector and others to ensure proper alignment. As Jerome said these are some of the most fragile parts of the system.
    I'm jumping on the bandwagon here and saying that yes, pull the cable out towards the right (where the MagSafe connector) and not up. I also found using the tweezers made this easier.
    Big fan of the tweezers.
    I can't stress this enough - again: This connector is extremely fragile. After changing the right speaker and putting everything in place my display went black. Gone. Tried with the display data connector's"out an in again" very carefully - nothing. The professional technician at the service shop I asked told me he wouldn't touch that particular connector ever again.
    I mean, why the logic board disassembly? Only because the speaker's cable is placed under the logic board? Why not cutting the old cable without removing the logic board and putting the new speaker in, placing the cable on top of the logic board? To avoid the necessity of disconnecting the display data connector at all costs?
    Thomas - Replica
  39. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 39, immagine 1 di 1
    • Rimuovi le due viti Torx T5 da 4,0 mm dalla scheda MagSafe2.
    I didn’t take these out - just lifted the mainboard away and set it to the back while I removed and replaced the left speaker.
    on my Mid 2015 MBP the MagSafe 2 board is wired to the logic board on the underside (keyboard side) so the screws had to come out. The following photo showing the logic board coming out does not show the MagSafe 2 board, so there is clearly some variation between these models.
    Richard, mine too.
    prreitz - Replica
  40. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 40, immagine 1 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 40, immagine 2 di 3 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 40, immagine 3 di 3
    • Solleva e tira fuori dalla parete interna del case superiore l'intero gruppo della scheda logica.
    • In fase di rimontaggio, accertati di allineare le varie porte con le rispettive cavità nel case superiore.
    When reassembling, be careful not to leave any cables (such as keyboard backlight connector, step 36) under the board.
    Andrey Pirozhenko - Replica
    I had to tape most of the cables out of the way while reinstalling the logic board, because they kept returning to their plugged-in shape under the logic board as I tried to position it properly.
    Jamie Flournoy -
    Also, make sure to align the right (and left) I/O properly, making sure the tabs on each port are underneath the lip of the aluminum frame. In my case, I couldn’t push the logic board far enough to align the screws until I had done this.
    Alek Curless - Replica
    Yes. This step is crucial. Thanks for pointing it out!
    jonvdez -
    I was struggling to align it and was beginning to get frustrated. I had to look back at photos to make sure the tabs had to go under the lip of the aluminum frame. Unfortunately I read your comment after the fact. Thank you.
    Robert Habib -
    if you’re only removing the right speaker, no need to remove the logic board. Simply lift the edge of the logic board to remove the speaker cable.
    Gareth Jones - Replica
    I had to remove one of the screws from the battery board before the logic board had enough clearance to lift up.
    Jim Guyton - Replica
    We (husband/wife team) just slid the logic board out to right, and did not entirely remove. For reassembly, we reviewed all the cables and made sure they were positioned out of the way, or taped back, before repositioning the logic board back into position. Worth it to review before getting it back into position.
    Ann Brainard - Replica
    There are 2 more screws to be removed before the motherboard comes out. One were SSD was and one at 40 Degree position to right fan. It has a golden base ring. Easy to spot
    anupraje - Replica
    Yes, I missed those two screws from Step 29 -- funny that we both missed that!
    kevin -
    Does the logic board prevent us from removing the battery? I’m trying to figure out why we are removing it.
    I agree John, tearing everything out is more of a risk then could be done ungluing the battery
    Russell G Stewart -
    Because the acetone can damage the board and connections -- in case of accident ;)
    kevin -
    why is the heatsink still attached?
    patjmccarthy - Replica
  41. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015, Altoparlante destro: passo 41, immagine 1 di 1
    • Rimuovi le seguenti viti che fissano l'altoparlante destro al case superiore:
    • Una vite Torx T5 da 2,7 mm
    • Una vite Torx T5 da 6,9 mm (con bordo da 4,5 mm)
  42. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 42, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 42, immagine 2 di 2
    • Il cavo dell'altoparlante destro aderisce debolmente al case superiore.
    • Stacca il cavo dell'altoparlante destro per liberarlo dal case superiore.
    • In fase di rimontaggio, forza lievemente il cavo contro il telaio di alluminio sopra alla batteria.
    Small comment on starting the reassembly, make sure to check picture on step 30 so that all connectors are exposed and not covered by logic board, I wasted some time putting the logic board back in and then having to remove it again to expose some of the connectors I missed.
    Rafael Lüder - Replica
    note that it’s possible (even easy) to destroy the right speaker during installation - there’s a metal boss sticking up (when case is upside down) that will hit the speaker.
    mine came back from apple damaged last week and I just swapped that speaker to fix it.
    keen - Replica
    I had some 2mm two sided 3M 300LSE repair tape left from a previous cell phone repair Perfect for re-affixing the speaker cable to the inside of the case.
    Richard Brooks - Replica
    When the instructions say "above the battery" they don't mean physically above, they mean in front of -- very important, so that the cable ends up underneath the logic board (but not the connector, the connector needs to be out of the way so that the logic board goes above the cable but underneath the connector. Hope that's clear (I had to remove the logic board to get the cable back underneath the logic board)
    kevin - Replica
  43. Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 43, immagine 1 di 2 Sostituzione altoparlante destro MacBook Pro 15" Retina Display versione metà 2015: passo 43, immagine 2 di 2
    • Rimuovi l'altoparlante destro tirandolo lievemente fuori in direzione opposta al lato del case superiore e quindi sfilandolo da sotto la linguetta di alluminio che lo blocca.
    If you are replacing the LH speaker as well this can be done at this point using steps similar to 41 to 43
    Jaap Van den Berg - Replica
    Unbelievable how much teardown is required to replace a speaker.
    If you just need to expose the speaker, rather than replace it (e.g. to clean it of dust), you don't have to do steps 17-42. You can just leave the cables connected and hold it up
    Ben Leggiero - Replica
Conclusione
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Altre 112 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
iFixit Membro di iFixit
Staff
135 Membri
16.732 Guide realizzate
36 Commenti
My Mac book pro 15” Mid 2015 got the right side speaker issue. I have ordered the speaker from iFixit and I am able to replace the speaker by following the steps given above. Thanks to iFixit.
KRISHNA PRASAD PSR - Replica
Is there any way replace right speaker without remove the mainboard? Can we cut off the cable socket of fail speaker to get speaker out without remove the mainboard, and then when reassembling, we put the cable wire lie on the mainboard?
Thank you!
Tai Le.
Tai Le - Replica
I know this is 2 years too late probably, but you can by removing just the IO board and a few screws from the right side of the motherboard. You should be able to flex it enough without damaging it to gently pull the speaker cable out from under the board.
Zach -
thanks zach. was super easy this way.
Chris J -
Excellent. Successfully replaced RH speaker in my 2015 retina MBP. Took about 3 hours.
Tricky bit: Before screwing main board back into case I forgot to first make sure the left speaker wire, keyboard light cable, etc were all poking above the board (rather than squidged underneath), so had to retrace some steps…. i.e., make sure that none of the connectors are stuck under the board.
My tips:
1. use correct screwdrivers which are also magnetic (to hold screws), and also to use a plastic spudger where shown in instructions.
2. Get a couple little bowls (like might hold sauce) and place screws for case in one, and some other bits in another.
3. Use couple of upturned post-it notes and stick the little screws on the tacky strip while noting with pen underneath what size, and what for.
4. For some bits (cable end cover plates, logic board, etc) rather than try to keep track of all these different screws I immediately loosely placed them back in the chassis mounting holes for safekeeping, after removing each part.
Ray Lowe - Replica
Insane how many steps need to be done for such simple device
Rombout Versluijs - Replica
This guide was awesome. 2 hardest parts where reinstalling the logic board without any ribbon cables under it, and reconnecting the antenna lines.
Joseph Dale - Replica
I lost all my love for APPLE / MAC after JOBS passed away. This company and its product are going to sh&t. Been a MACINTOSH user since 1992.
Mark Lugo - Replica
U ok? Like sure I get that this is a pretty complicated repair for one small speaker part but like why post this here. If you don’t like apple anymore then fine sure, but these comments should be about comments for the repair, not speaking about the “good ol’ days” before Steve Jobs died. Also why are so many things capitalized? “APPLE” “MAC” and “MACINTOSH” do not need to be capitalized, and they even then they don’t add anything to the comment like if you were to act like you were shouting. Same with the JOBS part. Sorry for correcting, just kinda had to. This is also prob a good year late but here we are. :) Have a nice day.
Ohhi There -
do you think there’s a way to to install the speakers from the 2018 15” MacBook Pro into this model with some modifications to the speaker case? Its about the only thing I really miss from the newer model
thebook55555 - Replica
Whole process took about 3 hours but went well as I had all required tools and some prior experience.
Agree that most difficult part is ensuring that all ribbon cables and connectors are outside logic board
and not underneath it during reinstallation….the antenna connectors were also a bit tricky - I use a binocular
magnifier on my reading glasses and strong work light. Also had air duster can on hand and isopropyl alcohol and cotton buds to clean
up interior of mac along the way - quite a lot of dust inside. Although mac sounds better now with replacement right
speaker it is still not perfect…I wonder whether audio drivers are also implicated in my original problem (fuzzy distortion
on right speaker especially of lower frequencies)…..
Richard Cox - Replica
I stopped after step 29 and then finagled the speaker cable out, and replaced it pretty easily. I just pulled up the motherboard a bit
Chase Lambert - Replica
Is it worth replacing the battery while doing this fix?
David Kim - Replica
I just did this and yes, its almost the same (time-consuming) steps to get to the battery as to get to the speakers.
martin froehlich -
good and comprehensive guide. if only the replacement parts were of the same quality.
martin froehlich - Replica
Ive done screen replacements on iPhone 4 and 6 with the instructions with these people and now both speaker replacements on my wifes Mac…. Always awesome detail, always complete… Thank you again!!!
This is the first time I am disassembling a macbook. Thanks to the author, i was able to replace both the speakers:)
S/O V S Pakianathan Pavithren - Replica
I could not have done my speaker replacement without this. Many thanks! Went to YouTube first and found a lot of dumb stuff. This is perfect! I agree with Ray Lowe about making sure all the connectors are sticking out before fastening the big board.
I had a piece of paper for each step that had parts/screws, drew a diagram and stuck each screw into it’s own little hole in the diagram.
Great guide. I replaced the battery last week (speaker went bad a couple of days before battery was replaced). I didn’t remove all the components to replace the battery - used the string/floss/fishing line and pry method to remove old swollen battery. Having done that, I was ready to tackle the speakers. The iFixit video for battery replacement shows pretty much this whole process as well, but much easier to scroll through this guide.
Is this a manufacture fault in “RIGHT SPEAKER” in “MBP 15in, 2015 min”.. Where so many complaints even a complete tutorial about that.
Mine got issue too. with noise…
Muhammad Farooqi - Replica
Great instructions.
I replaced both right and left speakers by following these instructions.
The only gotcha was that I had a couple of the ribbon wires stuck underneath the logic board at first during reassembly, so as you slide it in make sure to count that all the wires are on top, otherwise you may need to rewind a step or two.
I was worried that this was going to take a very long time when I started, but I was done with everything in roughly an hour.
Metin Ufuk Ergener - Replica
Im curious if anyone here had an issue with the right speaker blowing after an SSD upgrade using a NVME replacement.
I had no issues with my speaker until I did the swap.
Dj Neff - Replica
I just finished replacing the right speaker on my MackBook Pro and I have to say that I felt very comfortable doing it. Thank you so much for putting these instructions together!! These step by step instructions were better than any of the videos I found on YouTube.
DJ Boldillo - Replica
Thanks! Followed this and fixed the computer in about 45 minutes!
bryguy211 - Replica
Wow. Thanks for this guide. I’ve never worked on a computer before and successfully completed the speaker replacement. Took me a bit under two hours.
CARL MARTIN - Replica
grazie, guida utilissima e ben fatta
linus1506 - Replica
I’d rather connect the output to an external speaker. ;)
Too much work. 43 ways to screw up your computer.
JORGE BARREIRO - Replica
I have disassembled the mid-2011 many times. However, this is kind of crazy. You have 43 ways to screw up and ruin your MBP. I think I’ll keep using the output and connect it to some external speakers. Anyway, the internal speakers are almost useless. Poor quality.
Thank you so much. I replaced both speakers in about an hour and a half. Scary but straightforward with such good instructions. Everything still works and sound is back as good as new. Thanks
Andy F - Replica
Perfect tutorial, thanks for that, it worked like a charm! It is also nice to know that with this tutorial you can also change the left speaker, if you replace both, like I did.
Mario Weidler - Replica
This was an extremely helpful guide. Gave me an opportunity to clean the insides with IPA and blow out the dust from the fans. All in all, took about 2.5 hours to complete! Assembling everything was a lot faster than disassembling - every time I disconnected a flex-cable, I had a mini heart attack. Thank you so much for putting this together!
Akshar Jain - Replica
Great guide. Thanks for the detail; the pictures; the warnings. I used the awesome iFixit toolkit with the 24 small compartments in the lid, and scribbled out a little graph with the step numbers each of the screws came out of. No mistakes!
This seems to be done on purpose that this side of speaker is breaking down, its the hidden cage. What a lie! And that the wire is beneath the logic X umm board. Also a lie! Aware read what I am saying mr Indian guru! I think apples designs stink to !&&* lately! They are fooling the customers in all ways! Using them without knowledge of the customers!
Liedefender - Replica
Both speakers on mine are blown. I've replaced things on my MacBook before, but this looks daunting. 40 steps. 80 to put it back together. Ugh. Maybe I'll just wear headphones.
Ivan Übermensch - Replica
Awesome guide. Great parts. There is a reason ifixit is the best. 1 hour, start to finish. Easy peazy.
Pete Moss - Replica
Took about 90 minutes and took careful notes on where the various piles of screws originated.
Vicpylon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 54
Ultimi 7 Giorni: 267
Ultimi 30 Giorni: 1,259
Tutti i Tempi: 124,122
