Introduzione
Use this guide to replace the Logic Board in your MacBook Pro 15" Retina Display Mid 2015.
Don't forget to clean and re-apply thermal paste if you remove the heat sink. Follow this guide to learn how.
Strumenti
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
Use a T5 Torx driver to remove the following three screws securing the right fan to the logic board:
One 5.0 mm screw with a 2.0 mm long shoulder
One 4.0 mm screw with a wide head
One 4.4 mm screw
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Remove the two 2.2 mm Torx T5 screws securing the touchpad cable connector cover to the logic board.
Remove the cover.
The following steps will detail disconnecting these six connectors. Be sure to read each step, as these connectors come in different styles that disconnect differently.
Microphone cable
Left speaker cable
Keyboard data cable
Right speaker cable
Keyboard backlight cable
Display data cable
Use the tip of a spudger to flip up the metal retaining flap on the HDMI data transfer cable.
Gently pull the HDMI data transfer cable straight out of its socket on the logic board.
Remove the heat sink.
On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
Altre 49 persone hanno completato questa guida.
8 Commenti
Any tips on where to purchase a replacement logic board?
Can i use the mid-2015 logic board to mid-2012?
This logic board is the model whit just one graphic card, in the other model the logic board have one IC close to processor
