Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Things heating up inside your MacBook Pro with Retina Display? Could be trouble with the heat sink. Use this guide to remove the heat sink in the Mid 2015 MacBook Pro 15" with Retina display.
Don't forget to clean and re-apply thermal paste if you remove the heat sink. Follow this guide to learn how.
  1. Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro. Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange). During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips. During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. Peel back the sticker covering the battery connector.
    • Peel back the sticker covering the battery connector.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Gently lift each side of the battery connector to pry the connector out of its socket on the logic board. Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board. Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  7. Peel the rubber cover up off the right fan and fold it out of the way. Peel the rubber cover up off the right fan and fold it out of the way.
    • Peel the rubber cover up off the right fan and fold it out of the way.
  8. Peel the rubber cover up off the left fan and fold it out of the way. Peel the rubber cover up off the left fan and fold it out of the way.
    • Peel the rubber cover up off the left fan and fold it out of the way.
  9. Remove the small rubber cap from the screw at the end of the heat sink. Remove the small rubber cap from the screw at the end of the heat sink.
    • Remove the small rubber cap from the screw at the end of the heat sink.
  10. Remove the following screws securing the heat sink to the logic board:
    • Remove the following screws securing the heat sink to the logic board:
    • One 3.8 mm T5 Torx screw
    • Two 3.4 mm T5 Torx screws
    • When you remove these screws, springy metal brackets securing the heat sink will be released. Take care not to lose these screws when the brackets spring free.
    • One 5.6 mm T5 Torx screw
  11. Flip the two spring clamps out of the way of the heat sink. Remove the heat sink from the MacBook Pro.
    • Flip the two spring clamps out of the way of the heat sink.
    • Remove the heat sink from the MacBook Pro.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
Conclusione
Altre 44 persone hanno completato questa guida.
iFixit Membro di iFixit
Community
125 Membri
11.800 Guide realizzate
On my macbook Pro 2015 it has an extra Square on the heatsink to cover the graphics card. So the Pictures does not look right on this guide. I would share my pictures but it’s not possible in the comments.
Mark Barner - Replica
I don’t have much to add other than that these squares on the GPU and CPU were hindering my ability to completely clean off the previous thermal paste. I actually would like to remove the squares, but would like to hear from folks who might have a sense of how essential it is for thermal transfer (or any other purpose it serves).
Rahul S -
Hey guys when I refreshed the thermal paste on my 2015 15” (top spec) mbp, I noticed four little metallic sponges in that area, one of those came off… I still have it, how critical is it? Should I replace it? If so are there any guides?
Many thanks
AlexMorse - Replica
I have the same issue as well— 2 of mine came off, and I just stuck them back where they were before and let the pressure of the heat sink hold it in place for now. But any expertise on this issue is appreciated!
Rahul S -
Hola el mio tiene un disipador con 4 tornillo para el Chip Grafico a diferencia de este.
vparra - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 59
Ultimi 7 Giorni: 367
Ultimi 30 Giorni: 1,375
Tutti i Tempi: 34,583
