Introduzione
Do you have a cracked screen or see weird vertical lines? Fear not! Use this guide to remove/replace the display assembly if something terrible has happened to the beautiful Retina display of your MacBook Pro.
Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
Eight 3.1 mm
Two 2.3 mm
Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board, and bend them up and out of the way.
Use the tip of a spudger to flip up the display data cable lock and rotate it toward the MagSafe 2 power port side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Altre 92 persone hanno completato questa guida.
32 Commenti
Can the clutch be replaced in the 2015 15" Retina MacBook Pro?
Successfully replaced screen and everything is working great. One mechanical exception - the black clutch cover is loose on one side (the left side looking at the keyboard). i can "lift it" towards myself. it wasn't obvious while i was in there that there was a step to "hook it" into anything. what has it let go from and how do i go about ensuring that it's secure when it's flipped? Anyone know?
Thnaks!
Thank you! These instructions couldn't be better.
Do you have any intention of releasing a guide for the new A1707 2016 pro retina model with touch bar? Thanks for your help.
