Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If your MagSafe 2 power adapter has been damaged, you can replace it. Use this guide to install a replacement MagSafe DC-In Board.
  1. Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    To remove the back panel there are two different pentalobe screws 2.3mm and 3mm however on the tools list there is only one screwdriver. Will I be able to remove both screws with the same screwdriver?
    lantzero - Replica
    In my case it worked. Don't know if it was a 2,3 or 3 mm screwdriver
    Christian Mohr -
    The 2.0 and 2.3 mm measurements are screw lengths, the screw heads are the same sized P5 pentalobe heads. We include the screw lengths so you don't put the wrong screws in the wrong places and end up with screw heads poking out of your device. Hope that clears up some confusion =)
    Sam Goldheart -
    Yes the same screwdriver will remove both screws, the difference in screws I believe is the length and width but the head is the same.
    Mike -
    Just be careful to store the 2 shorter screws in a seperate space then the other 3mm screws.
    The first time I opened up my Macbook, I put the screws in the wrong order.
    Shahzad Arif -
    will this unit work with the Mid 2012 Macbook Pro Retina's as well?
    drscottgreenwell - Replica
    Same question...anyone know? Damaged my 2012 board and if possible would like to upgrade to this unit
    cloughenough -
    This works for rMBP 2012 late
    iyeori -
    Woohoo, much easier than I thought... Just got confused with the bottom case screw driver but after figure out it was P5 then everything went smooth.... One thing I wanted to upgrade was the wifi to ac and got one on ebay!
    didierma - Replica
    If you have 54 Bit Driver kit, please use Star 5 driver to remove screw for rMBP 2012 Late
    iyeori - Replica
    Where can I find the driver for the MacBook Pro Retina Display 15'4 i7 on your website iFixit please.
    Epifanio - Replica
    It took about 40 minutes due to an extreme measure of caution but I did it! The only real difficulty was reattaching the screen to the base (yes you have to pry the hinges open) and re-connecting the camera wires. After a few tries the camera wires finally came together. I'm hating Apple for all it's frailty and magical screws but I love ifixit!
    floyd - Replica
    Simple guide, but it solved my problem. Was wondering why the top two screws weren't going all the way down. Hadn't realized they were 0.7mm shorter.
    Emilio Mejia - Replica
    I have BootCamp running Win7 on my MBPwRetina15" 2013'Late. I run Visual Studio to build and run my Company's Application which is very CPU & NVidia (specific) intensive. So much so that during a build & run of app I was averaging about 85~95+Celcius!!! And every so often would reach 100Celcius!!! I could not take it anymore so I decided to delve into and re-apply Thermal Paste on the CPU/GPU. I ended up going with CooLaboratory Liquid Pro instead of the traditonal AS5. The original Thermal Paste was pure garbage,,, part of the CPU seemed like it was missing TP. I was scared to do this but it turned out easier than I had imagined. I am currently building the same application and can already observe that the temps average about 75~85 and once in a while will reach 90Celcius. So I am seeing about a 10~15 degree drop in Temps and that makes me very happy!
    Alvaro Suarez - Replica
    Nice to hear that, i was looking for that kind of information. I have a MBPwRetina 15 Mid 2012 and looking to obtain the best performance!
    Jose David Valle -
    Woa! Thanks dude! And you follow some guides here for the thermal paste? My mac 15’’ early 2013 heats up a lot but I’m a bit worried about touching anything
    Bert0ld0 -
    Good to list the bit needed to open the case: P6
    brian - Replica
    Much easier than expected. Sounds like several people had trouble with the backlight. It is possible that they damaged something by not first making sure to power down the computer completely with the “Shut Down” command. This should be step 1 before removing the back cover screws. Also as noted all the back cover screws are Apple Pentelope #5 bit, but 2 of the screws are shorter than the others. This bit is is hard to find in most stores. Buy it on line along with the Tork #5 and #8. 11/21/2017
    Walt Goede - Replica
    Replaced my Magsafe 2 yesterday and it works perfectly on my MBP 15” ea13. However, when I plugged in the charger I heard the startup sound twice and then I got to the login page where I realized the keyboard didn’t respond.
    So I thought I should restart the computer so I clicked ”shut down”. But the keyboard is dead. I can’t start it. I haven’t tried to use a USB-keyboard yet..
    Any ideas what may have caused this to happen and what component ”handles” the keyboard? Thanks
    /JD
    Jakob Dahlin - Replica
    Not sure if this has been listed.
    PRO TIPS from a non-pro:
    1 - Keep screws separated and labeled by step # and size.
    2 - Be very careful to get screws in properly threaded, its VERY easy to strip the ccrew holes and screws. Especially the case. Not that it happened to me…
    3 - It was impossible for me to get all the adhesive off the case from under battery, it left a lot on w/o issue (yet).
    4 - Make sure you have Aluminium Foil before starting!
    5 - Upgrade the SSD or HDD while your in there!
    erin - Replica
    Hi there, about advice no.4 Why should I bring Aluminium Foil? What is the purpose of using Aluminium Foil. Thank you.
    RR J -
    Do we remove the logic board purely to get the speaker enclosures out and away from the acetone? Or does it physically block getting the batteries out? Ie. if I wanted to risk the damage to the speakers, could I jump straight to step 34?
    Obviously I don’t want to melt the speakers, but I’m kinda weighing that risk against losing a screw or breaking a connector…
    Michael Ferenduros - Replica
    So I did take the risk and swapped out the battery without doing the logic-board + speaker removal.
    Before applying the acetone I put tape on the exposed sides of the speaker-enclosures as best I could - I wrapped the tape, sticky side out, around a card, slid it into the gap, and pressed it onto the speakers. And when applying the acetone, I squirted it as gently as possible onto the side of the battery and let it run down the side, which seemed to help avoid getting too much on the speakers.
    The speaker’s plastic turned white in the spots where the acetone touched it, but it looked like surface damage only. Otherwise it was a nice and smooth procedure.
    Your milage may vary, obviously.
    I changed the battery pack as well without removing the logic board etc. It helped, that the batteries already were swollen, thus access to the glue stripes was easier. It works, if you give a little tension, pulling a pack upwards, and then work with a small blade or knife, and cut the glue stripes. It may take a while, but much less time than dismantling the whole macbook. If you don’t hurry, and don’t apply too much force, you will not damage anything. Beside the 10 cover screws you only have to loose 2 screws for the battery connector. After removing the old pack I used Methanol to remove the glue. I prefer this solvent to Acetone, because it’s less or not harmful to plastic (however, no warranty, just my personal experience). I was able to finish the work in 40 minutes, although it was the first time I opened my Macbook. Well, I am an engineer, that helps, but with dismantling all boards it definitely would have taken double the time. And more risks to break a plug or make a mistake while reassembling.
    Heinrich Jung -
    Success. I needed to replace the right speaker. I thought I was ready at step 22 (you are able to replace the left speaker at this point… but but the right) To replace the right I continued thru step 29 but didn’t completely remove the motherboard. I just lifted it enough to remove and replace the right speaker cable.
    Read all of the comments and solved many problems. Thanks to I-fixit, Walter Galen and all who posted comments.
    Will Brecht - 03/02/2019
    Will Brecht - Replica
    1/2
    If you're taking the shortcut (nylon, wire…and no adhesive for battery removal (you'll def need to remove the adhesive once the battery pack is removed) things to note:
    1 The adhesive may still be pretty strong. Mine was and I broke several wires trying to do the cheese cutter move down the back of the middle two batteries
    2 if you're cheese cutting through the adhesive, when you get to the base, don't go too far. I did and severed the battery cell connector… disconcerting puff of smoke.
    Ruairi Kennedy - Replica
    2/2
    3 the you tube video dude was lucky not to have his two Central batteries adhered . Mine were stuck fast.
    4 don't forget about the two small T 5 screws to the left and right of the battery head board, just below the main battery connector.
    5 the Track Pad sits behind the two central batteries. The batteries are adhered to a flat plate that protects the Track Pad which is pretty resilient. You can do the cheese wire trick without cutting through anything you shouldn't. However be careful if you're using a spudger or other tool between the two centre batteries at the top of the T. This is where the Track Pad connector (its very flat and exposed) to the motherboard.
    6 seems obvious when it's written , but you will need the adhesive remover if you are interested in removing the adhesive. It's a work out.
    I just completed this successfully. The guide was great, and I recommend reading each of the steps’ comments, too. It is possible to cut out a majority of the steps outlined here if you’d rather not dismantle most of your laptop. As I’m a novice and this was the first difficult fix I’d ever tried, the idea of taking so many things apart — including removing the logic board — was a little scary. Everyone calculates risk and reward differently, but for me, the risk of removing the logic board for the reward of being able to remove the battery packs with adhesive remover was too great, so I opted to only do steps 1–4, 42–53 and removed the battery with one of the cards from iFixit’s kit. If you go this route, expect it to be a little frustrating & slow going — it took me around 20–30 minutes of slowly chipping away at the adhesive with only the card. There are other techniques out there (wire, fishing line, etc.) and I’d advise looking into them. Keep track of screws: tape, draw out diagrams, label them, etc.
    Jake Thornberry - Replica
    Hi. I got your beautiful guide and I got a toolkit, unfortunately not the ifix it and everything is ready to start the operation. But the P5 seems to be too big for the screws of my late 2013 a1398. Are there more than one types/ sizes of P5?
    Chrysovalantis Lamprianidis - Replica
    I only removed the 10 screws and the back panel, the 5 speaker’s screws (without removing the speakers), and the two battery screws, and managed to remove the battery package without undoing anything else. I used a member card (credit card type) to loosen the adhesives under the batteries.
    To remove the rest of the glue, I soaked it with something called Label Off from Biltema (Nordic). Finally, I used methylated spirit (rødsprit) to clean it all up and let it dry for 5 minutes before assembling the new battery pack.
    Andreas H. Parlow - Replica
    WAIT!.. STOP.
    iFixit has had a slew of defective batteries that they will require you take out and return (after gluing them in). Search on: "Battery percentage suddenly drops" here on this site. This process is 50 steps to get the new battery in, and another 50 to put all the parts back. For $199, Apple will do the whole repair, warranty it, and also replace the trackpad and the keyboard (because it's easier for THEM to do).
    Ifixit WILL NOT stand behind defective batteries unless you spend another 4-6 hours swapping in a new one. NOT. WORTH. IT. See posts here (Battery percentage suddenly drops from ~60% to 7%) on frustrated customer’s multiple attempts and class-action lawsuits.
    MFMauceri - Replica
    Hi,
    Do you have to mail in your laptop to get the battery replaced for $199?
    Thanks,
    RB
    Roshanda B -
    Alternative part suggestion(s) that worked for me:
    * Sintech NGFF M.2 nVME SSD Adapter Card for Upgrade 2013-2015 Year Macs(Not Fit Early 2013 MacBook Pro - https://www.amazon.ca/dp/B01CWWAENG
    * Samsung 970 EVO 1TB NVMe M.2 Internal SSD (MZ-V7E1T0BW - https://www.amazon.ca/gp/product/B07BN21...
    The adapter supports many common drives (though not all) and a few minor drawbacks, but otherwise has worked flawlessy for over a year.
    Harvey Thompson - Replica
    I have now replaced the battery and the dc-in board, and I still can’t get the battery to charge. I also bought a new magsafe power adapter. It appears all cables are connected, and the computer runs fine on the battery (until it runs out of juice, then I will be at a complete loss). No clue what to try next. Any suggestions? Thanks!
    matt rogers - Replica
    Why do you need to remove the entire logic board??? Seems like if you detach the appropriate cables, remove the speakers, that that should be enough. Removing the entire board doesn’t seem necessary - what am I missing?
    Sandwah - Replica
    What on earth are you talking about? This has nothing to do with the logic board.
    Trevor Picard -
    The speaker cables are routed under the logic board, or at least the right-side one is. I found that if you can undo the fastenings on one side of the logic board you MIGHT be able to lever it up and work the speaker wire out without taking the entire thing out.
    bobthrollop.redirect -
    MacBook Pro 15“ 2014:
    if the keyboard is connected nothing works. I disconnected the keyboard and the MacBook was starting automatically. An external usb keyboard is not working either. Is something on the logic board defective or is this failure (usb keyboard not working) because of the disconnected keyboard and the system is confused?
    any idea for this?
    ps: the battery is loading
    Pättes - Replica
    MacBook Pro 15” Mid 2012
    I had the exact same symptom upon initial completion. The keyboard ribbon is actually 2 pieces on mine. There is a plastic cover sheet (that I tried to use as the ribbon the first time) and then there is the actual ribbon sheet. The keyboard works perfectly now that I have the actual ribbon sheet inserted into the the ZIF connector.
    It took entirely too long. I was being very careful. Recovery of the keyboard took me less than an hour. I don’t want to admit how long the original work took me.
    I hope you already have yours working. I was very careful due to not having an alternate device for my son to use if the work had failed. The other likely point of failure for the keyboard is damage to the ribbon as it goes under the battery pack. I caught myself almost poking too hard on that spot.
    EEM -
  2. Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    Does anyone noticed that the bottom cover and the bottom case is actually linked with the black plastic near the battery?! After the first time you open the cover, it will be impossible to put it back to the original place. Does the critical?! Thanks a lot for informing
    jamiegan835 - Replica
    I was able to simply push and click those clips back into place before I did the screwing.
    Tim Peat -
    I truly believe this is placebo and the 10*C difference is because in the process the dust was removed from the fan/heat sink rather then the thermal "magic" paste.
    This is a "PC" habit.
    On the other hand, all the cases and protections out there have a bad effect on cooling (not sleeves or pouches) because the whole aluminum body helps dissipate heat.
    I've never had any problems with any mac regarding heat (they do get hot, but it is OK).
    Whenever you feel heat from electronic device means the heat radiates away from it.. which means the cooling is doing a good job :).
    crus - Replica
    Hey,
    Writing about dust and dirt, do you know any cleaning products for the interior of the mac. i mean how do you clean your laptop, pc, etc..
    Regards
    Jose David Valle -
    This is untrue. Over time thermal paste will dry up and crack and not provide good coverage between the device and the cooler. The paste massively improves the thermal transfer between the chip and the heatsink. If you do not believe in the magic paste then you should wipe it all off and apply just a little bit or none at all and then compare temperatures. You will see the paste is responsible for a big reduction in temperature.
    Andrew Fox -
    I was able to remove all screws but lower case is not comming off easly. Is it glued to somthing?
    Thanks for help.
    c4rlosv8 - Replica
    There are two clips in the centre which simply unclip with a little force.
    Tim Peat -
    If you are following this how-to because liquid/coffee splashed in through the back vents, WAIT UNTIL THE END to clean any liquid spills on the bottom panel. Use them as your map for cleaning and QA guide for checking until you are finished with your cleanup of logic board and other items.
    auntialias - Replica
    There are a couple of small rectangular magnets (~ 1/2” long) that are sitting in pockets near the battery warning label. (One is visible in the Step 3 pic.) One of these left its pocket and was stuck to the bottom cover when I lifted it.
    Jon Scott - Replica
  3. Peel back the warning label covering the battery connector.
    • Peel back the warning label covering the battery connector.
    For rMBP 2012 Late, you don't need to remove this sticker.
    iyeori - Replica
    Have laptop charging issues after this. When fully charged and i plug in magsafe it starts with green, then turns red and stays red (like if it was charging). Status bar says NOT charging. If i use battery a little bit (down to 69%) magsafe does the same (green then stay red). Status bar says battery 69% NOT charging. and it seems to be true. Any suggestions?
    g000phy - Replica
    Double check the connection from the battery to the logic board and the logic board socket itself... Might have damaged by disconnect/reconnect.
    max damage -
    Why is this step necessary?
    67b5ebab - Replica
    67b5ebab Good question !
    Why is this necessary ?
    bigb19791979 - Replica
    This step is necessary to prevent any discharging, arcing, friction/static charges from damaging any of the extremely delicate and intricate parts of this (or most any) electrical system. In practice, you should even be wearing an anti-static band or be working on an anti-static bench even with the battery disconnected so your body doesn't create any unintentional charges.
    One of the first things you should learn in electronics repair and and electrical in general is to cut the power source whenever possible before performing any work. Some systems have schedulers/triggers set that will wake the system up (even when closed) to perform updates and other maintenance tasks as to not eat up CPU and RAM during 'peak hours'. The last thing you need is to have your $2,000 laptop turn on while pulling an SSD (which, correct me if wrong, isn't a plug-and-play based device) which could do some serious corruption and/or damage; when all you had to do was peel a sticker and plug.
    Hope that helps!!
    ~the more you know~
    Colin Devenney - Replica
    I did not peel back the sticker. It is probably there to help unplug the battery. You can apply a gentle constant pull while you use spudger to lift the battery connector out of the socket as per the next step. It made this very easy.
    Achilles - Replica
    There is another connector here on mine, just to the left and up above the text on the battery sticker. It is an empty ZIPF socket on all these photos.
    Richard C - Replica
    Let me stop you guys here. You can skip steps 5-35.
    That’s what I did without a problem.
    Go directly to step 35 after the next step. 5-35 is only so you have more room to pry the old battery off.
    If you are not keeping the old battery, then just pry it off with a flathead screwdriver.
    This is not a difficult fix.
    Chris - Replica
    Chris,
    Thank you for providing the advise to skip several steps. I agree that you will have ample space to remove the old battery without removing everything else. I would like to provide a small correction in your directions. You will need to go to step 34 to remove the two screws holding the battery cable versus directly to step 35. You will not be able to completely remove the battery without this step.
    Laurence Rooks -
    which battery do you think is good to insert on your own in this pro?
    elmolcho - Replica
  4. Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board. Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    I ordered the whole kit, but seeing how much tedious effort it was to take out so many parts so they wouldn't be damaged by the solvent, I skipped from here to step 34 and only used the supplied cards (credit-card sized) with patience and persistence to free the battery sections from the backing. Success! Then I used a q-tip to apply the solvent to remove the remnants of the adhesive from the aluminum case. My battery was very swollen, so it was like removing little pillows. I think the swelling may have helped to give me additional access with the cards to free it. Success! My MBP is back up and running, and now the trackpad clicks again and it sits flat on a table!
    Joel Replogle - Replica
    So no need basically to unscrew all the mac
    Bert0ld0 -
    Joel - the purpose of all of the trouble in removing the logic board is to make sure that you don’t damage anything when you start pull out the battery. After this step - it’s true, you have about 12 connectors and dozens of screws to unplug, but I didn’t have any major problems.
    REASSEMBLY - I had to use alot of force to get the official IFIXIT battery connect to push into place to actually connect. I was worried that one of the wires would stress and break. It worked, but it was not super easy this part.
    Jer - Replica
    I also skipped down to step 50. I stuck a piece of 1/2 inch weather stripping across the middle of the top cover of the laptop to maintain a pitch on the unit so the adhesive remover stayed away from the other components. I applied the remover and used a piece of string to cut through the adhesive strips. I owed the plastic tool from the kit to position the string behind the top of each cell and cut through one ata a time. The battery came out in about 15 minutes. The directions were very informative and useful but I thought the risks associated with dismantling the laptop and reassembling it again were greater. I could not have done it without the details presented. Thank you.
    Thomas Horan - Replica
    Having broken a connector on a logic board in the past, I worried about all the steps. But I understand the disaster that can occur if cleaning fluid contacts the logic board. Weighing costs and benefits, I also did not remove the logic board. I loosened up the speakers (since only two screws could be removed) to give me space to slide the cards under the battery cells. Using the two cards, sometimes sliding one over the other, I was able to remove the battery in 15- 20 minutes. Removing the remaining adhesive was VERY tedious. Eventually I settled on CAREFULLY applying small amounts of remover with the syringe and using the spudger (both pointy and broad ends) to scrape the remainders off. I cleaned the residual with Q-tips dipped in remover (buy a big box of Q-tips), refastened the speakers, installed the new battery, closed the case and voila.
    James Suojanen - Replica
    Question, on the first image above you can read a serial and other information ... The creator of the guide could you confirm if it corresponds exactly to the Apple serial on the box? I wonder why I had the laptop in assistance to replace the GPU, and other problems were born once I returned ... to which removed the cover I saw this sticker and I immediately had doubts about it.
    Antonino Auteri - Replica
    I too found the need to completely teardown the laptop onerous and risky. I’m not certified in anything hardware but I’ve been doing my own repairs for a while. I watched the video referenced above and read the comments there. With some changes, here is what I did, which worked perfectly and minimized the risk, for a whole additional $3 in parts, just myself and in under an hour:
    1. Go to hardware store and get 2 4” bolts ($1 each) and a coil of 20 gauage galvanized wire.
    2. Wrap one end of the wire a few times around one bolt, then tie it off with a knot. Do the same with the other bolt, leaving about 10” of wire between the two.
    3. Follow steps 1-4 in this guide
    4. Slip the wire under one of the outer batteries (use a card or spudger to help get the wire underneath
    5. Grip both bolts with one hand and rock them back and forth, pulling the wire under the battery, using your other hand to hold the case. This should take about 2 seconds (seriously). Repeat for other outer batteries
    (continued)
    steve - Replica
    6. Pull the plastic frames away from the left and right sides of the center batteries.
    7. Repeat steps 4 and 5 for the two center batteries.
    8. Jump to step 55, then reassemble.
    Note: when installing the new battery, ensure the part closest to you is UNDER the two plastic tabs.
    Worked perfectly.
    Link to video: https://www.youtube.com/watch?v=fupkPz55...
    Note: using the nylon thread with that much effort is crazy. Use the wire or fishing line.
    steve - Replica
    cool.
    removed everything and have now 88% after 2 times calibrating and smc reset
    wouldn’t have liked to do everything again, but this seems like a possible solution :)
    Dennis Britsch -
    i just got my Kit and started the procedure, i decided to try if i can get the bulged batteries out with a fishing line, which worked fine. No need to use any solvent and even not too much force was needed to get the line under the batteries. I was able to remove the batteries in about 5min, used another 10min to clean the case from the residue, and put in the new battery. All togehter about 20min of work. I´m very happy with the result, Macbook stays now back on its feet, closes correctly and trackpad works as expected.
    manu - Replica
    Also departed from procedure immediately after STEP # 4 as per JOEL’s recommendation …used a small chunk of fishing line and it worked sans solvent…easily ! Spudger worked quite well to initially position the string /line & the ifixit ( ‘credit’ ) cards were nice for final dislodging of each battery segment from the last bits of residual gooey adhesive , AFTER working the fishing line back & forth down the length of the battery as much as possible. With the old battery out of the way, I used a razor blade to clean out the remaining bits of adhesive gunk. ( Decided NOT to use solvent here, either.) Took me every bit of 1-hour.
    One thing that helped ,too, was a cheap pair of cotton gloves coated on the palm side w/ latex. This kept my fingers comfortable from the pressure of the fishing line & allowed more of a range of force …since I wasn’t wincing from saw-cutting myself !
    John Joslin - Replica
    I skipped steps 5-33. These steps are completely unnecessary. I used the back of a flat tweezers to separate the battery from the case.
    support64 - Replica
    so the only reason they are taking all the stuff off before the battery is because of the solvent?
    I used cards and dental floss and just took the battery out … It was a pain in the butt but i got it out with out using the solvent remover solution.
    GR Verner - Replica
    I skipped steps from 5 to 33 and directlychanged the battery (before disassembling all). Worked fine.
    derdietrich - Replica
    I also skipped all the additional disassembly. I used cards and wire to cut through the adhesive quite easily. I also did not apply any tape on the new battery. The Mid-2014 laptop seems slim and tight enough to keep the cells from moving and the two screws at the power connector area seem to stabilize the connection and battery as a whole. Such STRONG tape seems unwarranted for the amount of squirm room in such a tight compartment.
    P.S. Remember, while you have it open, clean, clean, clean!!!
    jyee - Replica
    Thanks guys for all the tips. I followed the pragmatic way of cutting short and really taking battery out only. Thanks to the cards it worked well and none of the liquid made it to any other part of the computer. Put some efforts in to properly clean the remaining glue after battery was out - but looked good and this message comes from the old mid 2012 15” Retina modell - but with the new battery in - and all is fine. I am happy - thanks to the short cut encouragement.
    Jochen Färber - Replica
    Also skipped steps from 5 to 32. I used the supplied cards and a piece of string, i.e. braided nylon twine, (thickness 24). and used supplied acetone sparingly, mostly to the middle section. It took one and a half hours and another half hour or so for removing the leftover goo. It was demanding but not challenging, just take it slow and steady.
    jkobli - Replica
    Learnt a lot from former comments. Also skipped steps from 5 to 54. Used fishing line to cut through adjective by myself easily, but needed to put on glove to protect hands. I didnt order full package, so used nail polish remover and eraser to clean the base. Looks good and all is fine! Thanks to the short cut method!
    Gerry GU - Replica
    If you decide to skip to Step 34 or 52 or whatever, at least take note of Step 50. This is the only place I saw reference to the thin metal plate protecting the trackpad. I also skipped to just pulling out the batteries, but this plate came out with the them. I had to carefully pry it off the old batteries, reinstall it, and clean the adhesive residue off it.
    Also, YMMV, but I did not bother with delicately removing the old batteries with fishing line, loosening with solvent, or whatever. They’re going in the trash (ahem, recycling) anyway, so I pried them out with a screwdriver, using the neighboring cell as a fulcrum. 98% of the adhesive remained with the batteries, leaving very little residue in the case.
    Jon Scott - Replica
  5. Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
    will this procedure remove my warranty? I have applecare for another 2 years, Laptop was dropped on the side, there is a very small dent on the side of I/O.
    Oleg Babko - Replica
    Yes, this voids your warranty.
    max damage -
    If I am facing the MacBook like I'm surfing or typing, this I/O board is referring to which side of the MacBook? Left or right side? How about replacing the other side of I/O board? The other side I/O port are part of LogicBoard? If I want to replace it, need to replace the whole LogicBoard? TQ.
    Delta - Replica
    These are notoriously difficult to remove. I actually damaged 2/3 of the connector pins during the process. Thankfully i was still able to fit them in place. This step should not be underestimated.
    Alvin Chua - Replica
    If you are not replacing the display case assembly, you can opt to leave all 3 connectors attached and remove the Airport card with them connected. You will need to carefully manage the card and attached cables so as not to damage them(masking tape) as you proceed with disassembly/reassembly. Step 6 will need to be done carefully (camera cable connector). I did it after step 8. I took a picture of routed cables as well before I removed them from channel.
    lamajr -
    I damaged 1/3 of these litte guys, how did you get them back together?!
    is there a way to replace the antenna?
    Fabian Schweinfurth - Replica
    unless you have really tiny fingers, a tweezer helps, just be careful not to damage the wires or the board as your holding each cable in place. Oh and take your time - this is like the most frustrating step in the process, imo.
    Arn Custodio - Replica
    The order of the cables doesn't seem to matter when re-attaching. It also might be helpful to unscrew and eject the airport card. Having it free can give you a better angle.
    joey - Replica
    Definitely the hardest step (when putting it back together). The three pins were on progressively longer plugs, so I put the shortest one on the left and so on. This helps with getting the right angle. I used my fingers and the spudger to guide them back in. It took me easily 10-15 minutes to do this. The pattern that worked eventually was to first adjust the angle of the pin head so that it's x/y/z axes would line up perfectly with the connection if you are able to bring it together just so. If you're off on any of these while you try to bring it together, you won't be able to just click it down at the end. Good luck!
    Thomas Kunjappu - Replica
    Agreed, for some reason, the middle one was stubborn — and I was worried the amount of force I applied to push it back on was going to break something - but it did pop back on.
    Jer -
    I would never remove those tiny plugs unless I absolutely have to. And we do not have to remove them, just the card itself…
    Jurgen -
    After reading so many reviews on ifixit and other sites regarding the difficulty of replacing my MacBook Pro retina screen assembly, I was a bit nervous. Using this walk through made it super easy. Thank you so much for taking the time to create it!
    cabcpa - Replica
    Removing these 3 tiny cables is completely unnecessary. I removed my fan last week to clean and it slips by these cables. For some dumb reason i wanted to follow this "correct" procedure and now one of the gold connections detached from the wire like it was nothing. Seriously, dont do this. I used a spunger and was very delicate putting it back on... And look what happened. SKIP!
    travismlive - Replica
    Yeah, I agree, just leave the airport card attached to the pins and remove the card itself. Then you won’t have to fuss with these connectors.
    Jer -
    @tmm Your right on! Just finished replacing my right fan and your tip saved me from messing with these tiny cables. I totally understand your frustration as I was too just about to stick to the procedure, but if it’s any comfort your tip helped someone… so don’t be surprised being rewarded by some good karma :)
    IT’S UNNECESSARY TO DETACH THE 3 TINY CABLES FROM THE CARD, JUST DETACH THE AIRPORT CARD WITH IT’S CABLES ATTACHED BY GRABING IT FROM BOTH SIDES USING TWO FINGERS AND GENTLY SHAKE IT UNTIL IT DETACHES. THEN MOVE THE WHOLE THING A BIT ASIDE.
    THIS STEP IS ONLY NECESSARY TO MAKE WAY TO THE FAN CONNECTOR UNDERNEATH.
    There is one thing though I find missing which concerns:
    1)The rubber heat sink cover
    2 The AirPort/Camera cables
    3)The IO board cable
    All these are “glued” to the fan and you need to peel them off gently using the spudger, now while I noticed that some glue remains on each cable so they will kinda stick again, I wonder what kind of glue is this and where one can buy it?
    Itai -
    These individual instructions are re-used across multiple tutorials. If you are replacing the battery, you probably won’t need to remove the three connections from the Airport card; if you are replacing the display, you definitely need to replace them, because they are connected to the display. I just replaced the battery and the display in a single activity, so I pretty much had to remove everything. Also agree with a previous commentor that it’s easier to reconnect the cables before the card is reconnected to the system board.
    ChrisMBP -
    travismlive is right, you do not need to remove these cables or the airport card. Just remove the I/O board cable, undo the screws, and detach the antenna cables from the fan where they are glued with a spudger. Unlock the ZIF-socket and the you can wriggle the fan out. Probably saved my airport card, thanks travismlive!
    Jasper - Replica
    I only successfully reattached 1 of the 3 AirPort cables, I just taped the other two. But the AirPort seems to work fine. Do these also have anything to do with Bluetooth though? I do seem to have trouble with Bluetooth after this operation. In any case, it was worth it... I replaced the screen with a new Apple screen for less than 1/2 the Apple Store wanted! Thanks!
    Douglas Johnston - Replica
    Would soldering them back in place be better than taping? I certainly don't want spare solder on my motherboard, so I figure that'd be a last resort only if I lose AirPort connectivity.
    Assembly is a nightmare. If rightmost cable is not connected, BT will not work.
    Radoslaw Przybyl - Replica
    the hardest step is reconnecting the airport antenna cables. just have patience< and use tweezers, spluger and a q-tip.
    Frederick Rae - Replica
    The three cables have different lengths. The longest should to the farthest pin, medium to middle, short to nearest.
    Sam Jomaa - Replica
    Also, having the right tools will make the job really easy. I used a spudger similar to the one recommended on this web site. But i had ordered a complete kit from amazon.com. I did not have any problem removing or re-attaching the pins.
    Sam Jomaa - Replica
    tweezers to hold the cable and the flat part of the spudger to push down on the connectors is the easiest way to re-assemble
    Jon Ocampo - Replica
    Replacing these were the most difficult step I encountered. I finally determined that it took slight back and forth twisting of the cable (from left to right as viewed from above) to cause the connector on the cable to twist into position so it could be pressed down.
    chuck60 - Replica
    I read your step and you are 100% correct. This helped me tremendously. Thanks!
    Achilles -
    Use leverage with tip of a spudger, it’s not that difficult to pry the cables.
    When you reassemble, use a tweezers to put the connector on the right position and push it down with a finger on the other hand.
    Grab the neck of the cable when using a tweezers.
    eskoo - Replica
    Several of the people above mentioned not disconnecting these three wires. You must remove and replace these if you are replacing the entire display which is what these instructions are about. This is the most difficult step as others have noted. Just be careful and make sure you have the cable level before you start pushing down.
    lamajr - Replica
    Reassembling: What makes this so hard? From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It appears to be circular and therefore not needing to be oriented radially in any particular angle. It doesn’t look hard at all! Does anyone understand what the subtlety is that causes everyone so much grief?
    Chapman Harrison - Replica
    Reassembling: as so many as commented, this is incredibly hard - and inexplicably so. From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It doesn’t look hard at all! But I couldn’t do it.
    Here’s what seems to have worked for me: with my left fingertip on the cable holding the connector directly above the female, I used the spudger to press down the flat back of the connector, initially at the top and then sliding along toward the neck. I used normal pressure, and voila, when I lifted the spudger away the wretched wire didn’t spring up again. It was like it wanted to be rocked, or stroked, once, from top to neck, rather than pressed straight down.
    I skipped to step 34. Just pushed up the speakers so that they don’t touch the body.
    Sascha Gl Richy - Replica
    I totally agree, this step is not tagged contrarely to others while it is the most dedicate !!! 1/ A warning should be added (the 31 comments should have done it…) 2/True it is possible to skip this step. Result for me : 1/3 damaged (the left one). Luckily, everything seems to work airport, bluetooth (so far, I haven’t tried Airdrop yet). Really disappointed by this guide is way below the iFixit’s standard…
    Antochny - Replica
    Can anyone help me? I would like to replace my speakers. Which steps can i skip?
    Manzil Monabber - Replica
    I have completed replacing my speakers and this step was not needed at all.
    I just completed the full screen assembly replacement with 90% success I guess. Like many others noted, this was the hardest step, and one them (leftmost) was extra hard, but I eventually got them all back in. However, I don’t have 5G wifi anymore. 2.4 g works fine, bluetooth works fine, and the screen, camera, and mic are all perfectly functioning. I just can’t connect to 5G wifi. Is there a fix for this?
    Aaron C - Replica
    Absolutely no need to take apart the whole thing, get some strong fishing line and slowly saw the adhesive away. Once the battery is out, (if you are prone to be clumsy just cover/ shield the rest of the computer, than use GOO GONE or the like waiting a couple minutes to scrape out the old adhesive. The only reason they make your take everything out is that they assume you are lazy and will be using the adhesive remover which could damage the rest of the computer if allowed to splatter etc. Just save your self some time and stress, get strong braided fishing line ( works way better than floss or string as it is of a smaller diameter and isn’t smooth and helps the sawing action), and work your way around each cell. This is still way shorter than removing the entire computer and much less likely hood of damaging sensitive connectors.
    Pia Paeh - Replica
    Putting these 3 cables back was a lot of work. I bent the outer side of the middle cable, but was able to fix it with fine tweezers from the repair kit.
    olegpsh - Replica
    I did a screen replacement recently using this guide and the disassembly/assembly was fine - very good instructions. But when I turned on the machine there was a very fine flickering, snow-like interference, especially noticeable on black backgrounds. I assumed it was a faulty replacement screen and continued to use it. Recently, I had to change out the battery so I dissasembled the screen again to see if reconnecting it would fix the problem. Now it is perfect. I think the problem was that the left-most (shortest) airport cable connector was touching the black screw next to it on the board and shorting out. Be careful to position this connector well away from that screw.
    rumblefish - Replica
    I found placing the spunger under the part of the connectors AWAY FROM THE WIRE (top and/or side depending on which of the three you’re finessing), and then rocking them gently from side to side pops them out gently.
    MFMauceri - Replica
    I read the note above and managed to fold the card out of the way. I’d put it in a paper envelope to stop it touching anything as it flaps around. The bag also stops static build up and reminds you it’s there ! The wires on mine were held down with two strips of tape, the pointed spudger? pushed along the length of the wires widened the tape loop when I pushed firmly but carefully. Once widened, tweezers can open it fully .
    Simon Anthony - Replica
    I skipped the step of removing the airport antenna cables and removed the airport card with the cables since so many users said it was extremely hard to get the airport cables back on properly. By skipping the airport cable removal I save a lot of potential headaches and performing this task was not any more difficult to do.
    Timothy McDaniel - Replica
    I skipped steps 5 - 40 and removed the old battery with the plastic card and a palette-knife after heating the adhesive strips cautiously with a hair dryer. After that removing the adhesive strips with the solvent was by far the most time consuming part.
    Martin Zeilinger - Replica
    so what happens if you damage 1 of the 3 connectors because you didn’t read all the comments first? Does it work at all or just diminished wifi reception?
    Can someone at ifixit update the main instruction page to advise removing the airport card instead of the super fragile cables?
    Brandyn McKibben - Replica
    YOU DONT NEED ANY OF THIS!
    it is SO stupidly risky to remove all this. Who the HECK wrote this guide?!? Thank God I checked on youtube and found guys who did NOTHING of these steps and simply removed the battery in under 1 h.
    Silly Billy - Replica
    Steps 5-33 are not really needed if you are careful with the speakers, not to spill the fluid onto them. It saves a lot of time and potential dangerous operations. I did it without any problem.
    Cristian Caprar - Replica
    Please be extremely careful, I just ripped out one of the sockets for the cables. I fixed it with Tesa until I can buy a new Airport-Card.
    Josiah Lauer - Replica
  6. Use the tip of a spudger to push the camera cable connector toward the fan and out of its socket on the logic board.
    • Use the tip of a spudger to push the camera cable connector toward the fan and out of its socket on the logic board.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the connector out of its socket. Do not pry up, or you will damage the socket.
    I've broken camera connection socket, is it repairable?
    Sergey - Replica
    Same for me too just take the socket from your broken screen and cut it off and solder it onto the new screen. It was really hard because it's so small but I did it.
    bhayes9614 -
    This is much easier if you do step 7 first so you can pull lightly on the cable and take the tension off the connection caused by the stiff cable.
    mayer - Replica
    This tip worked for me.
    eskoo -
    If you are removing the right fan it is not necessary to unplug the camera cable. You can slip the fan out underneath the cable.
    noahtfu - Replica
    Hi! Camera flex cable is from MBP Retina Mid 2012 & Early 2013. Not Late 2013 :) Edit it please.
    kramerigor - Replica
    the tip of the middle 3 wire was broken on the replacement screen. I didn't connect it and everything seems to work fine, mac hardware test says everything is fine... Is it possible?
    micheleroger - Replica
    Yes. They are wifi antenna cables. Missing one antenna won't affect much, and won't show up in any hardware test.
    Jason Amri -
    Push on the little wings, from right to left.
    Julian Wood - Replica
    This is the hardest part of disassembly! Arguable hardest part of re-assembly too, other than the airport cables
    The instruction is not clear to me at all. Frankly the comments mentioning things make me uneasy about proceeding further.
    Ben Moore - Replica
    This came off for me - now my computer’s fan is running high constantly, and “Kernel_task” is using 500% of the CPU even though nothing else is running - what can I do?
    Ryan Brown - Replica
    Did you ever get the fan to stop? how?
    Cyd Trice -
    It is very important to note here that you are NOT pushing up. You are pulling the cable back toward the fan. Doing step 7 first makes that easier. I misunderstood the instruction here (as others seem to have as well) and broke this part. I’m fine with not having a camera on this computer so I’ll leave it or ask my son to help me solder it later.
    Jen Wells - Replica
    can you give guidance on the soldering? Im new to it and dont want to burn anything / especially the wrong thing!
    Cyd Trice -
    The wing closed to the edge of the chassis is completely stuck. I’ve worked on it for an hour. The other wing moves freely. I’m not sure what to do now.
    Charles Lindauer - Replica
    The connector is very tight - I couldn’t even see the join between cable end and the socket and couldn’t see the “ears” on the end of the socket. And, of course, pulling didn’t help. I eventually used tweezers to start things off, gripping on the metal of the socket right where the invisible join was. What a delight to have the join open enough to see! After that, it was easy.
    jerryl - Replica
    Thank You Jerryl - The tweezers did the trick. They want to pop out so you can use your other hand to apply slight downward pressure to keep them in place. Work both ends of the tweezers gently back and forth and you should start to see the gap get bigger.
    Chuck Barton - Replica
    I used tweezers and the spudger. Take the point of the spudger and push on one side of the “dog ear” while supporting the other side with the closed tweezers on the cable side of the dog ear. (Could use a second spudger) work one side the move to the other repeatedly until the connection disconnects.
    This is allows You to push and support simultaneously and minimize the chance damaging the connector.
    Jonathan Dowling - Replica
    Removed cover (Step 7). Released adhesive. Pulled directly out of socket to the left.
    Pushing out of this connector is ill advised, as no mechanical ledge to push.
    Joseph Gorse - Replica
    The late 2013 Macbook connector is slightly different to the picture, I used tweezers to loosen up first and when the joint appeared used the flat edge of the spludger to push the connector using the gap. Don't rush push this from each side gently till it comes out.
    Lanre O - Replica
    I found this step to be difficult due to the picture and instructions being incorrect for MacBook Late 2013. Unfortunately, I damaged the pins during this step and my camera no longer works. :^( Please update this step.
    Cristina Stoll - Replica
    @xtstoll I looked at two separate Late 2013 units today, and both are indistinguishable from what’s shown in the instructions. Are you sure you’re working on the right model? A photo of what this cable looks like on your laptop would be helpful.
    Jeff Suovanen - Replica
    A MAGNIFYING GLASS really helps on this. The cable’s sheathing may need to be pushed back a tad to find a place to get leverace to work the pin out.
    MFMauceri - Replica
    DO FIRST
    STEP 7 : Untight the rubber heat sink cover on the right fan.
    Lift the cover and flip it back so that you can access the cables underneath.
    STEP 8 : Carefully de-route the cables from the plastic cable guide.
    So you can easily disconnect the connector.
    KRIS - Replica
    Tweezers saved me on this one! Take your time and keep trying (gently) if you're still struggling
    Elizabeth Jolly - Replica
    gently set pointed tweezers at the ears on either side and walk it back toward the fan
    Christa - Replica
  7. Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan. Slide the spudger underneath the length of the cover, releasing the adhesive. Lift the cover and flip it back so that you can access the cables underneath.
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
    Back (case) side of rubber attachment is flimsy-ish, so need to be delicate when peeling rubber back.
    cahcadden - Replica
    assume everything is delicate and needs to be worked gently.
    Christa -
    True @cahcadden.
    Worst case you could accidentally tear it off
    (thank god, that didn’t happen to me, but belive me —> it was a close call)
    Shahzad Arif - Replica
    Very nice article keep it up
    Shahid khan1 - Replica
  8. Use your fingers to pull the AirPort/Camera cables up off the fan. The cables are adhered to the fan, so peel them up carefully to avoid damaging them. Carefully de-route the cables from the plastic cable guide.
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    It's a bit tricky to re-route the cables when you're installing the new display, so pay close attention to how they're originally routed, to make sure you don't pinch them or torque them.
    PriorityMail - Replica
    Do we need to use some adhesive to paste them back?
    Aniket Suryavanshi - Replica
    I used scotch tape to temporarily hold the cables in place until I was ready to reinstall the bottom cover, but I removed the tape at that last step (didn’t want it coming loose later, and possibly obstructing a fan).
    ChrisMBP - Replica
  9. Use the flat end of a spudger to pry the rubber hinge covers up off the left and right hinges. Use the flat end of a spudger to pry the rubber hinge covers up off the left and right hinges.
    • Use the flat end of a spudger to pry the rubber hinge covers up off the left and right hinges.
  10. Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.  On reassembly, connect this end first as it does not flex. In a similar fashion, remove the I/O Board connector from its socket on the I/O Board. Remove the I/O Board cable from the MacBook Pro.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. On reassembly, connect this end first as it does not flex.
    • In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
    Note that the Mac has been rotated 180º between steps 8 & 9
    peteyx - Replica
    When reinstalling the io board cable make sure it is the correct way round as in the photo, it fits the wrong way round as well, which results in the MacBook not starting at all.
    bitmat23 - Replica
    ABSOLUTELY ! I found out the hard way. I took a break, came back to me dead computer and wondered - if - this cable would fit the other way round - and voila ! I wish I had read this note first :-)
    Simon Anthony -
    i did exactly the same mistake! Same procedure as well: keep calm, and start again the tutorial.
    every thing work find now
    Guigui -
    Sockets are ZIF with releasing levers on the top. If you pull up on the top padding, you will reveal silver lever handels facing the rear of the machine. Pry up on the LEVER to release the pressure, then pull the lever straight up to release the connector from the socket. DO NOT pry under the edge of the connector to remove these or you may damage the ZIF socket. They may have changed these connectors between models, otherwise I don’t know how this was overlooked in the guide.
    hybrid - Replica
    Confirming, these are indeed zifs for me too. My padding has notches indicating location of lever needing to be raised. Obviously lever is tiny, look closely. If your padding is a clean rectangle as shown in guide, you may not have zif sockets here
    hamiltont -
    Confirmed; if the foam pieces are not perfectly rectangular, you should be able to pry back the side of the foam with the cut-away. It folds in half. You can see the lever under the foam. Lift the handle with the spudger, then when it’s pointing straight up (it flips up), you can lift up on the lever (straight up). This should be done for both ends.
    Patryk -
    COMEON!! they need to edit this into the real guide or put a big banner saying don’t trust our guides until you read all the notes
    a almost broke my mono not knowing this and trying to replace the cable
    maxslomoff -
    I just did this and there are no silver lever handles. The connectors just pop off when you pry on them.
    edc - Replica
    After freeing each end of the I/O cable, it can be left stuck to the right speaker, and then remove them both together in step 14.
    Paul Clarke - Replica
    leave the cable stuck to the fan
    AES - Replica
  11. Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
    • Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
  12. Grasp the thin sides of the AirPort card and pull parallel to the logic board, removing the AirPort card from the MacBook Pro. Grasp the thin sides of the AirPort card and pull parallel to the logic board, removing the AirPort card from the MacBook Pro.
    • Grasp the thin sides of the AirPort card and pull parallel to the logic board, removing the AirPort card from the MacBook Pro.
    As others have mentioned, it's not necessary to remove the Airport antenna cables. Leave the cables attached and remove the Airport card.
    Swing the card and the attached cables across the fan.
    stvn chng - Replica
    You may lift a little like few degrees then pull parallel when removing.
    eskoo - Replica
    There might be a touch of adhesive, lift first – a gentle touch with the spudger helps.
    Tristan Harward - Replica
    Yes, lift about 5-10 degrees first, then pull out. If you do not release the adhesive, it may be stuck in place and you could damage the card trying to pull it out.
    hybrid - Replica
    I will add to what others have said about lifting the card lightly using a spudger to get the adhesive to let go of the board. Otherwise the card may get damaged.
    jeiboussa - Replica
    Yes. LIFT up slightly on one end to clear retaining pin before tugging.
    MFMauceri - Replica
    Yes. Slight lift to release adhesive and then pull out.
    David Choy - Replica
  13. Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board.
    I was able to flip the retaining flap while removing the damaged fan but accidentally dislodged after installing the replacement fan. Again, be very careful at this stage. Thankfully my new fan appears to function normally.
    My retaining flap just came off. Can you confirm your fan doesn't need it to function??
    Peter Ungacta, Jr. -
    Easier to do while removing fan.
    mayer - Replica
    The second picture and illustration are not clear enough. The text should say "pry underneath the cable" as I almost broke the fan cable following instruction.
    Kitipong Mork - Replica
    ZIF = Ziero Insertion Force. Once the tiny retaining flap is up, it should slide out easily toward the back. There was no adhesive on my machine, so the cable slid out easily. But be careful if yours is glued down.
    Don Steele - Replica
    I don’t know why, but I could pull the connector out & in without flipping up the flap. And fans are working flawlessly.
    eskoo - Replica
    The pictures were confusing to me so let me add some more context. There is a ZIF socket (Zero insertion force) being addressed in the first picture. This socket has a black top that is currently closed down on the socket. Using your tool you need to lift this flap up to release the wire underneath (This release happens in the second step). Hence only pull up on the black flap enough to make it go from horizontal to vertical (Swing flap). Neither picture shows it in the up position. Step 2, Picture 2, Then gliding your flat spudger, you goal is to lift the wire that was in the ZIF socket out by lightly lifting up on both the wire and the rubber cushion on top of it. Make sure you lift both. You are successful when both are lifted up and out and facing vertical instead of horizontal.
    Frank D - Replica
    Great clarification, thank you.
    Hunter Gallagher -
    Can anyone advise what to do if the ZIF socket pulls up from the logic board? I was gentle with it, but it pulled up anyway. The fan and ribbon are fine, but I’m worried this will require an expensive logic board repair.
    Jaysmi - Replica
    To really see which part of the ZIF socket has to be lifted up you should compare the pictures of step 10 and of step 12, preferably in its original size.
    Then you can see that the inner part of the ZIF has to be moved up, away from the batteries.
    Stephan Yaraghchi - Replica
    I managed to broke the side, thought this was pulling on sides mechanism to release, not just upwards. Luckily I managed to attach it and the fan is working.
    Josip Ricov - Replica
    Here is video how to open the ZIF socket. https://youtu.be/MQbqpWkCz94?t=360
    Ketut Sandiarsa - Replica
    Many thanks Ketut, that vid clip really helped!
    Paul Clarke -
    very appreciated!
    Alexis Quintana -
    Thank you… that vid is crisp!
    Erich Hentschel -
    Incredibly poor instructions!!! Thanks to the incorrect wording, I have just ruined the fan connector. There is NO lever. The cable gently slid out, after I borked it. I’m done with IFIXIT and the $@$*!& information. How about a little video clip inserted here. You guys can do better!
    Lorne Shantz - Replica
    Can anyone share how to put the retaining flap back onto the connector? Has anyone’s fan worked without it? My hinged retaining flap just slid off and it's extremely difficult to place it back on.
    Peter Ungacta, Jr. - Replica
    I found it easier to slide the flat end of the spudger tool in from the left side of the cable, near the 90 degree bend.
    Aimee Ness - Replica
  14. Remove the following three screws securing the right fan to the logic board:
    • Remove the following three screws securing the right fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 3.9 mm T5 Wide Head Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar
    With most parts, its easier to leave the screws in the holes parts they come off with, and have small containers or a layout to do this with so each major part does not get mixed up - too many similar but different screws!
    AES - Replica
    What I did to separate the different screws, is to take the top of the ifixit essentials-kit (which has lots of small spaces to hold screws) and picked a row of these spaces, which I marked for the cooling-fan screws. So basically I just sort them by lenth: The 5 mm on the top space, underneath it the 4,4mm, and at last the 3,9mm. That way I didn’t loose track, because I was working in tandem with this instruction.
    Just a heads up in case anyone else gets confused - in this photo, the cable from the previous step (12) is still connected. It should be free from the board so that fan can actually be removed.
    In my case, the 3.9mm screw was connected to a spacer that sat flush to the motherboard. I misplaced this spacer and had to take the computer apart twice to find it… Make sure not to lose it if you have one!
    Daniel Kirk - Replica
    I was able to stop at this step and jump ahead to removing the battery. I did this based on the fact that the batteries were extremely swollen and I could see that the adhesive strips below were already separated from the bottom quite a bit. In retrospect my wife had complained that the computer ran very hot in the vicinity of the batteries (not sure why) but that heat apparently diminished the adhesive properties and allowed me to slowly pry the cells up while using a spudger to push between the case and batteries. Saved twenty some odd steps by doing it that way. If the batteries weren’t swollen I could not have done it this way. NOTE: When ordering just the battery adhesive remover is NOT included. I did not order it because I have acetone here and felt I did not need the iFixit remover.
    Terry Angelli - Replica
  15. Lift and remove the right fan out from the MacBook Pro.
    • Lift and remove the right fan out from the MacBook Pro.
    • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
    Do I need to use thermal paste when installing new fan?
    1 0 - Replica
  16. Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
    • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
    This came of super easy as the glue seemed to have dried up or something of that nature; anyone know if this is an issue?
    Also it seemed like there are clips on sides of the rubber heat sink which I couldn't work out how to clip it back on, so I placed it back where it was after and it seems to be ok; maybe it isn't meant to clip on hard and rather just to be a security measure. Anyone else had this?
    RT0 - Replica
    I had the same experience as you this was super easy to remove as well.
    spearson - Replica
    Glue was long gone. It just flops over by itself.
    Jer - Replica
    I have this feeling that my “noisi fan” was actually the loose end of this rubber cover. So verify that you insert rubber clips back to its slots on under the edge of the sink.
    Albert Stein - Replica
  17. Remove the following three screws securing the left fan to the logic board:
    • Remove the following three screws securing the left fan to the logic board:
    • One 5.0 mm T5 Torx screw with 2 mm collar.
    check if screw marking here is right
    Oleg - Replica
    what exactly do you mean by wide head torx screw? Is that another torx screw i should buy?
    best regards,
    Seth
    sethroot - Replica
    “Wide Head” just refers to the head of the screw being a bit wider than the others. It shouldn’t affect the size of the tool needed. That said, I also was unable to remove this screw with a T5. The screw on mine looked corroded. I ended up using Vampliers (great tool).
    maccentric -
    seems like T5 is the wrong screwdriver for the "3.9 mm T5 Wide Head Torx screw"
    ryanbraganza - Replica
    T4 seems to have worked for me
    jonathaniscarroll - Replica
    i tried unscrewing the screw with a yellow circle around it but it is not unscrewing i think it is stripped
    Habib Sy - Replica
  18. Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
    • Lift the left fan out of the device.
    a question out of curiosity is it possible to remove that left fan completely and use and external fan instead of it?
    and what is that fan for? is it for CPU or VGA? i noticed someone was referring to that fan as vga's fan.
    Albert Einstein - Replica
    I can't imagine any scenario why one might want to do that Einstein. An external fan on a laptop? Seriously?
    maccentric - Replica
    be nice, silly
    Richard RUNGE - Replica
    I would say that my cable was permanently adhered, or at least requires chemistry to remove the adhesive. Definitely check if fan parts are in stock before attempting to remove the cable that doesn't seem to be coming loose from the motherboard.
    orders - Replica
    Couldn’t manage to “flip up the retaining flap on the left fan ribbon cable ZIF socket.”, in fact think I may may broken a piece off. In the end just pulled out the cable by sliding it down and out (maybe I did manage to loosen it after all). Cable didn’t appear to be glued down thankfully.
    Chris McKay - Replica
    Holes on the new fan did not exactly match up and ribbon cable has more tension as a result -
    I had to cut the loop on the mount for the 4.4 mm T5 Torx screw. Not ideal.
    Scott Evans - Replica
    So, what do I do if I break the connector on the board? Serious question, yes I did it. Now, how do I get the replacement part?
    Amin Shah Gilani - Replica
    The retaining flat is super fragile. And I doubt there’s any practical way to replace it. Don’t know if the connector still works ok without the flap.
    Steven DeRose - Replica
    After I exchanged the fan it‘s super noisy. I ordered at the ifixit shop and it seems it works but it‘s just super noisy. Does anyone know why?
    Thanks
    Karsten Hullebeck - Replica
    I have the same issue with my newly replaced fan…sounds worse than the broken one - will need to check with the ifixit team…
    Markus Meßerschmidt -
    reported this to the support team and got a replacement within one day. The new part works fine - no noise at all, old one is on the way back. Thank you iFixit!
    Left fan was 400% harder to remove due to adhesive. Use the opening tool to gently pry the cable little by little and eventually it will come up. The adhesive pad is the same size and position as the foam pad so concentrate your efforts there
    Aleksis G Williams - Replica
  19. Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
    When I got to this step I realized the screw was stripped. I'm unsure if it was stripped by my efforts -- I used the prescribed P5 screwdriver that was also used for the other screws, and the screwdriver still works when putting the lid back on.
    So to extract the stripped screw in Step 5 I've ordered iFixit's Precision Screw Extractor Set.
    Now I'm wondering if I also need to find a replacement screw since I probably won't be able to use the stripped one again after it's been extracted? The screw is called: 3.1 mm T5 Torx screw as per this guide .. the best I can find on eBay are screws called: 1,4 X 3,1 mm Torx T5 or 1,5 X 3,1 mm Torx T5 ... will one of these work? Would I be able to just go to a hardware store and find the proper screw or is it a specialty item?
    Lorte Messenger - Replica
    I'm sure you've long since figured it out, but for the benefit of anyone else reading this, a P5 is not a T5. It's a different screwdriver. The driver for the screws on the outside of the case will not work on the screw holding the SSD. I'm not sure why they left it off in the list of tools at the top.
    Dave Miller -
    The screws on the outside of the case are Pentalobe.
    The screw for the SSD is Torx.
    Both drivers are (now) on the list of required tools.
    (However, my devices both have a T6 head, not T5. May have been after-market.)
    jkgarrett17 -
    For the Macbook Pro Retina 15" Late 2013 models, I've heard the SSD is soldered to the logic board. This guide is for that model, but it doesn't address the soldering issue. Have I just been misinformed on this issue? Has anyone tried it with the late 2013 model yet?
    Elaine - Replica
    The SSD is not soldered to the board. You maybe thinking of the RAM which is soldered. (thank you apple) *dripping sarcasm*
    Ryan Tucker -
    I was needing to send my mid 2014 15" MacBook Pro in for a keyboard repair, and my company IT department shipped me a loaner of the same model except that it had a smaller SSD in it than mine, and said I should swap the SSDs between the two and then send mine back with the smaller drive in it to get fixed. I've been unable to swap the drives because neither mine nor the loaner (which are both the same model) appear to have a T5 screw holding the SSD in place. Both of them appear to have a T4, not a T5 (whatever it is is smaller than a T5 anyway, so I'm guessing it's a T4). So now I'm on hold until I can find a T4 screwdriver.
    Dave Miller - Replica
    OK, got the new tool set, and yes, it really is actually a T5 screw, you just need a really sharp driver. My existing T5 driver was getting a little dull on the tip. So make sure you have a really new/precision T5 driver/bit to use (and again I'll point out that ifixit failed to list this tool in the list of needed tools at the top).
    Dave Miller -
    It's definitely a T5, just takes more control vs only strength. I went left and right in small increments while pushing down to let the screwdriver dig in before slowly being able to loosen it up.
    Toan Tran - Replica
    Both of my A1398 computers (Mid-2012 Retina 15” and Late 2013 Retina 15”) have a screw that my T6 bit fits perfectly. If using a T5 screwdriver/bit makes your screw seem stripped, try the T6.
    (The 2012 was purchased second-hand, and the 2013 was purchased from a dealer known for unauthorized upgrades; it is possible my screws were swapped.)
    jkgarrett17 - Replica
    I’m pretty certain this screw is a tiny bit larger diameter than the others — I mixed it up and tried to use it elsewhere, and it wouldn’t fit, so IO swapped in another and set this one aside. Later when I got to this point, other screws were too small and wouldn’t grab. So I tried the one I had set aside earlier, and it fit perfectly. That might explain why this one seemed “stripped” to another commentator.
  20. Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board. Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
    I thought the 2014 retina 15” MacBook Pro hard drive needed an adapter?
    Andrew Last - Replica
    … This is the 2013 Retina Macbook Pro. Not 2014.
    Jonathan M. -
    where can I buy a 1 or 2 TB SSD? I think it isn’t possible using a SSD like I build in my MacBook Pro mid 2012?
    Christian Rieckmann - Replica
    You can get 1TB or 2TB SSD from OWC macsales.com
    https://eshop.macsales.com/shop/ssd/owc/...
    lamajr -
  21. Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer. Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    This is a difficult step. A few images for the removal of the cable would be good/better
    Robert Jan Lebbink - Replica
    Yes, a few more detailed pics here would help. Indeed, general pics explaining HOW ALL the plugs and sockets fit would be VERY handy :-)
    Simon Anthony -
    I helped me to use the pliers both to get underneath the canble lock and then push on the wings of the cable.
    Calvin Truong - Replica
    Used fingers on the cable lock.
    gently use tips of tweezers at either side to walk it out
    Christa - Replica
  22. Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board. Carefully lift the I/O board and remove it from the lower case.
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • Carefully lift the I/O board and remove it from the lower case.
    This did not want to come out. The bottom was really wedged in there good. I had to pry up the bottom part with a screw driver. The funny thing was it was really easy to put back in. *shrug*
    Jer - Replica
    it actually has an extra screw that needs to be removed.
    Reid Rankin - Replica
    Thank you. Removing the screw by the heat sink really helped get this board removed.
    Christopher Hofmann -
    It helped me to push the IO board further into the casing and then lifting.
    i/o cable was much easier to remove after freeing the i/o board & slightly lifting it. SK
    Stefan Kirchanski - Replica
    I believe, the IO Board can stay where it is, for logic board replacement..?
    smirgle - Replica
    Yes, I replace motherboard without touch IO Board
    Александр Гращенков -
    On a 2014.5 design, these instructions should be revised on this process. The heat pipe needs to be removed first if one were to remove the I/O CCA, Reason being, the CCA is installed first into the case and then the heat pipe contact tab lays atop the CCA under the plastic injection molded part. This injection molded piece part secures the tab to the CCA to ensure optimal contact thus, ensuring heat is wicked away from the CCA.
    So when I see comments regarding how it is easier to install than remove, that is an indicator that the user was unaware of how to correctly assemble this component thus, the CCA top side substrate is sitting below the heat pipe tab vs. the other way around.
    This will induce a thermal issue on the I/O CCA and also, possibly short out the board when the conformal coating and painted surface of the heat pipe wears off due to vibration when cables are connected.
    While I like these instructions, I would overhaul them and revise them.
    Christopher McKenna - Replica
    Yes, removing the screw near the heat sink really did make it come out easily!
  23. Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board. Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
    At this point, it should be noted that the author is using two different logic boards through the procedure. Here, for the first time is the difference between a 2.3 GHz board and the 2.6 GHz board. The audio out socket is integral to the 2.3 GHz board. The 2.6 GHz board has a discrete audio out jack that plugs into the logic board. As the disassembly proceeds, the 2.6 board’s audio outlet is unplugged (Step 26/27 pictures note this, but the author doesn’t. So, as I hoped, the 2.3 GHz board can be replaced by a 2.6 GHz board, IF you don’t want an audio out jack!
    David White - Replica
    Correction. The two boards are NOT compatible. The battery connector and others do not align. A faulty 2.3 GHz logic board is no excuse to get a faster board.
    Note that you should SLIDE not pull these out. Just broke one of them.
    andershegelund - Replica
    On this model they should be pried straight up from the board as instructed. If your connector looks different from what’s shown in the photos, proceed with caution, verify your model number and make sure you’re following the corresponding guide.
    Jeff Suovanen -
    I totally missed the pry STRAIGHT UP instruction. I tried to slide one out and it sheared from the board, taking one copper trace with it. Poop!
    Peter Kaczkowski - Replica
    On MID-2014 Retina, they definitely lift up and out.
    MFMauceri - Replica
    On LATE-2013 Retina, they definitely lift up and out
    KRIS - Replica
    This really was helpfully! Thanks!
    Jan Dreyer -
    Yes. This is tricky. Be VERY CAREFUL. I damaged it. I’m afraid this MacBook is RIP.
    Richard Cacciato - Replica
    This was tricky. I pried up from where the cable enters the connector with a very small flat headed screwdriver - no spudgers to hand!
    aaron.sarginson - Replica
    I can confirm. you LIFT UP on Mid-2014.
    Costantino - Replica
  24. Peel back the tape covering the top of the keyboard ribbon cable connector. Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Peel back the tape covering the top of the keyboard ribbon cable connector.
    • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Use the flat end of a spudger to push the keyboard ribbon cable out of its socket.
    I can't fit the ribbon cable back in the slot. It was hard to take out a well. Any tips? I'm going crazy
    Jennifer McAuliffe - Replica
    The trick is to align it so that it slides in perfectly straight and level with the surface of the logic board. It's made more difficult by the way the ribbon cable bends around the edge of the logic board, which puts tension on it and makes it harder to align. I usually position it with a finger on each side and then press gently on the top with a spudger or other tool to help level it out. It should slide into place reasonably easily at that point. Good luck!
    Jeff Suovanen -
    For me the angle of this picture was kind of confusing. Just to make sure it is clear, to anyone else (and they don’t break off the protective plastic piece for the pins like I did), the hinged flap is at the opposite end from the ribbon cable. Where the spudger is in the second picture kind of looks like the middle of the part, but no. From the angle these pictures are taken, it is the plastic piece closest to you. I don’t know why it took me so long to figure this out, and I feel like a bit of an idiot for not doing so more quickly. But hey, maybe reading this comment will help someone not make the mistake I did.
    Parker Young - Replica
    For my MacBook Pro mid 2014, the socket type was a lever. Looking at the battery, carefully lift it so it makes an angle of 90 degrees, then the cable was easily removable.
    Mike Bachman - Replica
    the tape actually helps remove the cable. Just hold the tape and pull it back towards the battery. The ribbon cable will slide right out. Easy. No tools needed.
    Pranav Singanapalli - Replica
    I’m so curious about the connector besides it, to the left. It wasn’t used at all, and what was the purpose of it?
    Anders thomasen - Replica
    This is a complete guess on my part, but I think it’s there for test purposes, before the logic board is actually installed. Given that it’s right next to the keyboard connector, it might be an easy/fast way for a test jig to connect a keyboard simulator without messing with the keyboard connector that is causing so much trouble for all of us… :-)
    yeliab -
    Same as in
    STEP 12
    the right fan ribbon - disconnect cable ZIF socket.
    Remark :
    Ketut Sandiarsa
    KRIS - Replica
  25. Use the flat end of a spudger to pry the trackpad ribbon cable connector up out of its socket.
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up out of its socket.
    After this step I think the author must add a connector that is not mentioned (visible on step 18 and 19), between de SSD connector and the GPU (I suppose)
    Quique García - Replica
    The only connector I see at that location is the speaker connector—scroll up two steps from here and you’ll find instructions for disconnecting it.
    Jeff Suovanen -
    I agree with Quique…there’s another connector, running toward the battery, visible in slide 19. 6-wire, immediately adjacent to SSD connector.
    Joel Black - Replica
  26. Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
    • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
    macbook has been rotated 180 degrees here
  27. Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket.
  28. Use the tip of a spudger to flip up the display data cable lock and rotate it toward the DC-In side of the computer. Pull the display data cable straight out of its socket on the logic board.
    • Use the tip of a spudger to flip up the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    Be extremely careful in this step as the pins of this cable are EXTREMELY fragile. The leftmost pin bent over the neighboring one and its tip broke which lead the display to not work at all!
    Thanks God, I could realign it again and the display got on again :)
    When removing this cable pull it backwards by holding the hinge from its middle. DO NOT WALK THE CABLE FROM THE SIDES as this leads to breaking the terminal pins like what happened with me. When the cable has never been removed before, it behaves like something glued so when you try to walk it from one side, it seems to not move, which leads you to automatically push harder causing the pins on the terminals to bend or even break.
    Michael Azer - Replica
  29. Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
    • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
    This may be a matter of a 2.3GHz vs a 2.6GHz board, but on mine the raised-head screw - and the rubber cover - are on the other side of the black metal whatever it is, about centered relative to the cable connector to its left.
    jerryl - Replica
    same thing for me too.
    William Corwin - Replica
  30. Remove the following six screws securing the logic board to to the upper case:
    • Remove the following six screws securing the logic board to to the upper case:
    • One 3.1 mm T5 Torx screw
    • One 2.5 mm T5 Torx screw
    • One 5.5 mm silver, raised-head T5 Torx screw
    • Two 5.7 mm T5 Torx screws
    • One 3.8 mm silver T5 Torx screw
    There is another screw near the yellow one, the 5.5 mm silver, raised-head T5 Torx screw. I had to remove that too rather than force things.
    On this process step, there are two fasteners on the Mag-Safe already removed but not listed in the procedure. The two Mag-Safe fasteners securing the CCA to the chassis must also be removed as this is wired to the logic board underneath. If the user isn’t instructed to remove these fasteners and attempts to flip the CCA, damage may incur to the interconnects.
    On a 2014.5 model, the board cannot flip up as shown. One must grab the CCA opposite of the Mag-Safe end and walk the logic board CCA up while sliding it to free the connectors from chassis.
  31. Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro. You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
    • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
    • You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
    • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
    • Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board, and then remove the logic board and MagSafe board together.
    I wasn't able to get the magsafe connector off easily; it was easier to just remove the 2 screws holding the magsafe port in place, then disconnect it after the the logic board was removed.
    Derek Gelormini - Replica
    Completely agree. I just did the same.
    ChrisMBP -
    Same here. Removing the MagSafe screws should also be included.
    Agreed, after reading your comment I also simply removed the magsafe connector.
    Bruno Essmann -
    Hello, i did it the same, and it was more easy after that.
    SebioJazz -
    Agree, just did the same. It is safer.
    Pantelidis Pantelis - Replica
    100% agree, recommend updating this article to suggest removing the mag safe connector at the same time and save the hassle and potential damage trying to remove the connect from the logic board. far easier and safer to simple remove the two screws and lift out the mag safe connector at the same time as the logic board.
    calum.h - Replica
    Confirmed, I removed the screws of the magboard so the whole magboard was removed together with the logic board at the same time (MacBook Pro mid 2014).
    My logic board is stuck on the audio, USB, and TB connectors and the chassis. Turned out it was connectors near the battery connector catching the logic board.
    There’s one more connect next to the SSD socket, that I can’t find mentioned, and is hard to disconnect.
    Yes… @StevenDeRose! I had a really hard time getting that connector off because I couldn’t figure out the release mechanism. I ended up prying the connector off the board. %#*@. I guess it’s a speaker connector!!!! Major flaw in the instructions….!!!
    Rather important note: I have this model (Retina, 15”, Mid-2014, MacBookPro11,3) and the entire guide worked up until this step. What failed? Somehow, my 2014 model had the 2015’s headphone jack. Mid-cycle update, perhaps?
    So rather than lift the logic board out as shown, I had to lift the right edge and pull it away from the left edge (backing the headphone/USB/TB/MagSafe ports out of their bays, if you will). And just like in the photos from the 2015 guide, the headphone port came along, attached to the logic board, unlike how this guide seems to show the headphone port remaining behind.
    Hope this helps anyone else confused! If you get here and can’t seem to lift/rotate the logic board out as shown, try popping over to the 2015 guide and scroll down to that respective section, then pop back here once the board is out!
    Justin - Replica
    weird… same thing here…
    Gabriel Lage -
    Thanks for this tip. Super helpful!
    Jackie Malling -
    I found it tricky to reinstall the logic board to its proper position. Make sure no cables get clamped, e.g. the keyboard backlight cable which I oversaw the first time.
    It also helps to pay attention to exact alignment of the headphone jack, and to all screw positions.
    Karl Müller - Replica
    I found I had to lift the logic board like 15 degrees to unhook the thunderbolt ports from the case. Justin is right, go look at the 2015 one and then come back!
    Maxfield Feigelman - Replica
  32. Remove the logic board assembly from the MacBook Pro. When reinstalling the motherboard, make sure all cables are visible and not trapped under the motherboard. Clockwise from top: battery, right speaker, keyboard backlight, AirPort/camera, display, microphone, left speaker, keyboard, and trackpad.
    • Remove the logic board assembly from the MacBook Pro.
    • When reinstalling the motherboard, make sure all cables are visible and not trapped under the motherboard.
    • Clockwise from top: battery, right speaker, keyboard backlight, AirPort/camera, display, microphone, left speaker, keyboard, and trackpad.
    A little “scotch tape” can be used to hold the various cables out of the way. Then the replacement board almost falls into place.
    Now that I’m done re-assembly, I wish I had paid attention to the second image where all the cables that need to come above the logic board are highlighted in red. I took me three tries of screwing in the logic board in before I properly accounted for all of them
    I’d not even seen that pic until I came here to add my comments. Very good point !
    Simon Anthony -
    Careful: The picture shows nine red boxes, but if you just count, you might miss a cable, because there actually are ten of them. The I/O board data cable may not be at risk of getting stuck under the board, so it’s entirely logical to not put a box around it, but if you simply count loose cables before putting the screws back in, you will easily count it while missing another less prominent cable (like the keyboard backlight connector, which can be easy to overlook).
    Lars - Replica
    When re-inserting the board it is important to make sure that the tiny clips on the USB and DVI ports are on top of the aluminum housing lip. If they are under it, then it is not possible to move the board over toward the DVI port side….
    Jurgen - Replica
    When putting the board back in, double check that tape that covers the keyboard ribbon cable. I thought I had it over the board but it was just the tape over the board, not the cable.
    Austin Hodges - Replica
    I did the same thing.
    Shane -
  33. Rotate the device 180 degrees to more easily access the rest of the internal components. Remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • Rotate the device 180 degrees to more easily access the rest of the internal components.
    • Remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • Slide the MagSafe DC-In board towards the right to free it from its recess within the upper case.
    • Lift and remove the MagSafe DC-In board out of the upper case assembly.
Conclusione
Altre 19 persone hanno completato questa guida.
iFixit Membro di iFixit
Community
135 Membri
14.994 Guide realizzate
I have a 820-3332 logic board (late 2013 MBP 15" Retina, same as this how-to) ) that is missing the socket on the underside of the logic board the magsafe board's wired connection slides into on the underside of the logic board as shown in the final steps. I can't find any mention of a new one anywhere. Looks like it was glued on at the factory. So I'm sitting here with a brand new magsafe 2 board with no way to attach it to the logic board. I though of soldering it directly to the pins that the socket mounts up against on the logic board but there are six pins on the logic board and five wires going to five connection points inside the connector that slides into the socket on the board. Looking at the six pin holes in the new magsafe 2 board connector from the top I see three wires, an empty pin hole and then two wires so I wouldn't even know which pins to attach to which board.
Anyone have any suggestions for this mess?
Any suggestions?
mikeandres2003 - Replica
Wow! Somewhat complicated to get that DC board out. Wondering if I should even attempt this.
I have a liquid-damaged (coffee) MBP of this vintage. If I plug in the power adapter, the machine boots and runs fine; however, it shows the battery is "not available" in the battery menu and, when I unplug the magsafe adapter, the machine immediately powers off. As the logic board seems to work fine when plugged in, what do you think about attempting to stick in a DC board? Or is that battery "not available" message an indicator that the battery is also hosed? I don't see any obvious damage to the battery (but...).
Thanks for any advice.
barryjaylevine - Replica
This guide is very good and simple to follow. It may seem tricky but it really isn’t, just take your time to unscrew everything and place them in labeled bins, so you can remember where each screw goes.
I had a bit of trouble with the logic board, after everything was unscrewed it took some fiddling around to finally get the logic board to release and lift up.
Great tutorial.
Thomas Egelund - Replica
Great guide! Easier than it looked at first glance!
sorenlund - Replica
Great, thank you. I got a 20 euro MagSafe board and it works perfectly.
The guide is accurate, and it is indeed easier than I expected.
For reassembly though I had to take out the logic board twice again because one of the small connectors ‘stayed behind’ the logic board and I only discovered later.
So a tip is to count the connectors you removed, and count again to make sure all are in place to connect and didn't stay in an unreachable place before you reattach the logic board.
Also as another tip, for easier reassembly, I put all the screws (and some parts) on the adhesive tape so they stayed in place and I could spatially fix them. I glued the tape to a paper sheet so I could take notes at which step the screws belonged and also other notes.
Thanks. This repair took me 1:20 (80 minutes).
Have this:
1. Clean workspace and 1.5 hours uninterrupted.
2. Instructions in front of you (on another computer maybe).
3. Spudger and the two screwdriver sizes. Maybe tweezers. (I bought the “Essential Electronics Toolkit”, overkill).
Do this: Stay organized and methodical. Place screws in a safe spot, (with whatever they held down, and spatially the same way the screws were removed).
Misc.
Sometimes the instructions say pull a connector “straight out.” That does not mean straight up. It means straight back out, toward the ribbon cable, in a plane parallel to your desk)
To summarize this repair, to get to the Magsafe 2 board, you have to get to the underside of the main board. So you have to disconnect all the cables from the main board so you can temporarily flip it over (and remove it for a minute or two). The fans have to go, and two other small boards also.
It’s not too bad—it just takes 33 steps (in forward then reverse)
jason deats - Replica
Great instruction. I must have done something wrong. MagSafe replaced and plug light on but MacBook dead. Totally…
daniel - Replica
Why so complicated?
1. remove the back panel
2. remove Battery Connector
3. remove Display Connector
4. Remove some Screws around the MagSafe
5. Carefully push in the MagSafe Connection from outside
6. Very carefully raise on the LogicBoard
7. Now you can remove the MagSafe Connector
8. Carefully put in the connector of the new MagSafe
9. Finish
Don’t forget the Display Connector and Battery!
I did it for the first time in a few minutes and it works.
Why I can’t post some pictures here?
matthias.brabec - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 183
Tutti i Tempi: 11,165
