Salta al contenuto principale
MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement
Cosa ti serve
  1. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement, Battery: passo 1, immagine 1 di 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement, Memory Door: passo 2, immagine 1 di 1
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
  3. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 3, immagine 1 di 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement, Upper Case: passo 4, immagine 1 di 1
    • Remove the two Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 5, immagine 1 di 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 6, immagine 1 di 1
    • Remove the four Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 7, immagine 1 di 1
    • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 8, immagine 1 di 1
    • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 9, immagine 1 di 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
    • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
  10. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 10, immagine 1 di 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement, Bluetooth Antenna: passo 11, immagine 1 di 1
    • Lift the Bluetooth board out of its slot next to the hard drive and use a spudger to disconnect the Bluetooth antenna cable.
  12. MacBook Pro 15" Core Duo Model A1150 Bluetooth Antenna Replacement: passo 12, immagine 1 di 1
    • Use a spudger to pry the Bluetooth antenna up from its housing in front of the hard drive.
    • Lift the Bluetooth antenna out of the computer.
Conclusione
Altre 6 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 10,771
