Introduzione
You can again use ExpressCard accessories by replacing a faulty ExpressCard cage.
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm PH000 Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Use a spudger to disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Altre 5 persone hanno completato questa guida.
