Salta al contenuto principale
Panoramica Video
Questo smontaggio non è una guida di riparazione. Per riparare il tuo MacBook Pro 14" Late 2023 (M3 Pro and M3 Max), usa il nostro manuale di assistenza.
  1. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 1: passo 1, immagine 1 di 2 MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 1: passo 1, immagine 2 di 2
    • Apple APL1203/339S01320 M3 Pro 12-core applications processor w/ 18 GB memory
    • Apple APL109H/343S00652 power management
    • Apple APL109H/343S00653 power management
    • Kioxia K5A3U08299 128 GB NAND flash
    • Texas Instruments SN25A12 USB type-C controller
    • Likely Parade Technologies PS190 DisplayPort-to-HDMI converter
    • Likely Apple U0KSS1-L2 ThunderBolt controller
  2. MacBook Pro 14" Late 2023 M3 Pro Chip ID: passo 2, immagine 1 di 1
    • Genesys Logic GL9755A card reader controller
    • Apple 338S00600-A0 power management
    • GigaDevice GD25Q80E 1 MB serial NOR flash memory
    • Winbond W25Q80DVUXIE 1 MB serial NOR flash memory
    • Renesas RAA225702B DC-DC converter
    • Analog Devices LT8642EV-1 10 A / 18 V synchronous step-down regulator
    • Texas Instruments TPS62180 6 A synchronous buck converter
  3. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2: passo 3, immagine 1 di 2 MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2: passo 3, immagine 2 di 2
    • Renesas RAA489901A5 battery charger
    • Texas Instruments SN012776B0 audio amplifier
    • Kioxia K5A3UN0975 128 GB NAND flash
    • Apple APL109G/343S00649 power management
    • Apple APL109G/343S00650 power management
    • Cirrus Logic CS42L84A audio codec
  4. MacBook Pro 14" Late 2023 M3 Pro Chip ID: passo 4, immagine 1 di 1
    • Winbond W25Q64NEXGIG 8 MB serial NOR flash memory
    • Winbond W25X40CLUXIG 4 Mb serial NOR flash memory
    • Texas Instruments LP8548B1 LED backlight driver
    • Renesas RAA209100B1 DC-DC converter
    • Renesas RAAxxx501C DC-DC converter
    • Texas Instruments REF3325 2.5 V voltage reference
  5. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2 - Connectivity: passo 5, immagine 1 di 1
    • Likely USI 339S01093 WiFi/Bluetooth module
  6. MacBook Pro 14" Late 2023 M3 Pro Chip ID, Main Board Side 2 - Sensors: passo 6, immagine 1 di 1
    • Likely Bosch Sensortec accelerometer and gyroscope
2Commenti sulla guida
Is this article for M2 or for the M3? Most of the text makes it sound like it's for the M3 but then there's this little bit near the beginning: "Here you'll find the chip identification summary for the 14" M2 Pro MacBook Pro." I'm guessing it's M3, especially due to this line "Apple APL1203/339S01320 M3 Pro 12-core applications processor w/ 18 GB memory". Thanks much for the interesting, helpful content in any case!
David - Replica
Thanks for catching that! This chip ID is for the M3 and the text has been corrected to reflect this.
Shahram Mokhtari -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 257
Tutti i Tempi: 15,234
