Introduzione
Use this guide to replace a broken AirPort/Bluetooth board.
Cosa ti serve
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Peel back the piece of EMI tape covering the AirPort/Bluetooth cable connector.
Altre 88 persone hanno completato questa guida.
11 Commenti
Just to say if you only need to replace the cable the from the main logic to the Airport card it is very simple after battery disconnect its just pry up logic board connector carefully then peel back tape at airport card and remove cable.
Thats all there is to the cable replacement and it fixed my No wifi hardware found and intermittent wifi which it would seem is a common fault As always a great guide thank you.
My macbook pro 13 2014 version wifi screen holder and the wifi card bluetooth cables are broken , so i went to repair it by my self and i bought the wrong full screen and the wifi card back to macbook pro 13 2010 version , it was shock so i would to know Can i change the wifi card cables and the screen adopted cable to the new cables of 2014 macbook pro 13 2014 version?
what's the difference between the normal "phillips screws" and the "shouldered phillips screws"?
If you look closely with the screws (my eyes needed a magnifying glass) you will see that some of them have heads that are "stepped". hard to describe in words.
perasso -
I just completed this repair successfully thanks to an excellent instruction and some help from iFixit support due to an error I made. A couple of comments that might help someone else:
1) make sure in step 15 that you TURN THE BOARD OVER and remove the tape from the bottom of the board. I "continued" removing tape from the top and then got completely confused when I couldn't find the screws in the next step. Yeah, it was my mistake because i didn't read the instructions carefully.
2) In step 15, leave the tape attached at the end of the bracket. this will make it much easier to replace the tape when reassembling.
