Salta al contenuto principale
MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement, Optical Drive: passo 1, immagine 1 di 1
    • For precautionary purposes, we advise that you disconnect the subwoofer connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Remove the soft padding that may be on top and gently pull the connector up out of its socket on the logic board.
  2. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 2, immagine 1 di 1
    • It will be necessary to slide the small clear plastic cable retainer (boxed in red) glued to the logic board out of the way before disconnecting the camera cable. Be careful not to break any components off the board as you slide it away from the camera cable connector.
    • Pull the camera cable connector toward the optical drive to disconnect it from the logic board.
    • This socket is metal and can be easily bent. Be sure to align the connector with its socket on the logic board before mating the two pieces.
  3. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 3, immagine 1 di 1
    • Use the flat end of a spudger to pry the optical drive connector straight up off the logic board.
  4. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 4, immagine 1 di 1
    • Use the flat end of a spudger to pry the hard drive connector straight up off the logic board.
  5. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 5, immagine 1 di 1
    • Remove the following screws securing the subwoofer to the upper case:
    • One 3.8 mm Phillips screw
    • One 5 mm Phillips screw
  6. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 6, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 6, immagine 2 di 2
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  7. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 7, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 7, immagine 2 di 2
    • Remove the two 10 mm Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
    • Lift the camera cable bracket out of the upper case.
  8. MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 8, immagine 1 di 2 MacBook Pro 13" Unibody Mid 2010 Optical Drive Replacement: passo 8, immagine 2 di 2
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
    • Lift the optical drive from its right edge and pull it out of the computer.
Conclusione
Un commento
Bonsoir. Le tuto est très clair, mais je voudrais savoir s’il est applicable sur la version 15” du MBP 10. Amicalement, Marc.
Marc Blériot - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 702
