Cosa ti serve
Afferra la linguetta di plastica fissata all'attacco del cavo dati del display e ruotala verso il lato DC-In del computer.
Tira delicatamente il connettore del cavo dati del display parallelamente alla scheda.
Utilizza l'estremità piatta di uno spudger per sollevare il connettore del subwoofer e dell'altoparlante destro dalla scheda logica.
The first time i tried this on a MBP 13 I broke the connector form the board. It should be noted that you have to be very careful in this step, as the plug fits very tightly and you can easily use too much force to tear the connector from the board. Use a second spudger to hold down the connector at its border and try very gently using a second spudger to move the plug out of the connector upwards.
Tira il connettore del cavo della fotocamera verso l'unità ottica per disconnetterlo dalla scheda logica.
As mentioned, the socket can be easily damaged when re-inserting it. I didn't care enough and one pin was damaged. Wifi was not detected.
Hopefully the pin was not broken (only bent). Putting it back in its correct position, the wifi re-appeared.
Usa un'unghia o la punta di uno spudger per sollevare la linguetta di fissaggio del cavo nel connettore ZIF per il cavo a nastro della tastiera.
Utilizza lo spudger per far scorrere fuori il cavo a nastro della tastiera dal suo connettore.
Sometimes spulger is not the best tool to slide the cable out. If it is difficult to slide, try two toothpicks to pull the cable from two sides simultaneosly.
Toothpicks did the trick, thanks
As Mateo said, replacing the zif cable is NOT easy, and in this case, will leave you with a computer that won't power on- this cable connects the power button. I learned a trick somewhere for dealing with these cables- put a piece of good sticky tape on the cable, and use it to pull it back into the connector. Works every time.
Yeah! The tape trick worked for me. Thanks!
Thank you Steve, it’s works perfectly.
Stacca la piccola striscia di nastro adesivo nero dal connettore del nastro della retroilluminazione della tastiera.
Be very careful while taking this black tape off. I accidentally broke the chip off the motherboard and so my keyboard is not backlit any more.
Utilizza la punta di uno spudger per sollevare la linguetta di fissaggio del cavo nel connettore ZIF per il nastro della retroilluminazione della tastiera.
Utilizza lo spudger per far scorrere fuori il cavo a nastro della retroilluminazione della tastiera dal suo connettore.
Be especially careful as my hole socket detached from the board. It would have helped to vertically press the socket to the board with the tip of a spudger. Thus partially blocking the strap, you can first peel the free end, then change position and peel the rest. Slide the ribbon cable perfectly horizontally.
I had the same issue of trying to get the ZIF cable back in but found that if I used a piece of scotch tape, it worked. I followed this guide. MacBook unibody keyboard ribbon cable won't go in
A reassembly trick that works for me is to use some 3/4" blue painters tape to stick to the very back (lower end) of the ribbon cable so I can pull it up and back before locking the cam. Trying to get a good grip without cutting, or crimping the ribbon means no tweezers or pliers can be used.
Utilizza l'estremità piatta di uno spudger per sollevare il connettore del cavo dell'indicatore della batteria dalla scheda logica.
If you’re swapping top cases, you might need to remove the battery indicator from the case and swap it to the replacement top case. It attaches with three very tiny Phillips screws. I wasn’t aware that my replacement top case didn’t have this part and got confused when reversing the steps to reassemble and I didn’t have this connector. I had to take the battery back out in order to swap the indicator over.
Utilizza la punta di uno spudger per staccare il microfono dall'adesivo che lo tiene attaccato al case superiore.
on the Australian/Asia version speaker cable is located underneath the logic board.
Solleva la scheda logica dal suo bordo sinistro e alzala finché le porte si liberano dal lato del case superiore.
Tira la scheda logica lontano dal lato del case superiore e rimuovila, facendo attenzione alla scheda DC-In che potrebbe incastrarsi.
Be careful while taking the board out, as the heatsink usually is caught by the optic drive.
mid 2012: Careful of the left speaker (on your right because unit is upside down). Gently remove with spudger tool before removing logic board and when reinstalling press firmly back into place with spudger. Install speaker after putting logic board in place but before installing screws.
Per rimontare il tuo dispositivo, segui queste istruzioni in ordine inverso.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
On my system the pad on top of the connector was shifted making the bracket difficult to rotate into the up position. The bracket looks like a handle so my first instinct was to pull it straight up. Big mistake. I ended up popping the brass guard off the connector on the logic board. The instructions could benefit from an arrow indicating the direction to pull and rotation of the bracket.
highnoontoday - Replica
