Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide has been updated by iFixit staff! Read the new, official guide here.
  1. Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Red Seven 3 mm Phillips screws.
    • Orange Three 13.5 mm Phillips screws.
  2. Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. Remove the following tri-wing screws securing the battery to the upper case:
    • Remove the following tri-wing screws securing the battery to the upper case:
    • Red One 5.5 mm tri-wing screw
    • Orange One 13.5 mm tri-wing screw.
  4. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  6. Lift the battery out of the upper case
    • Lift the battery out of the upper case
  7. Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board. Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
    • Remove the ribbon cable by releasing it from the ZIF connector on the underside of the trackpad and also from the socket that attaches it to the logic board.
  8. Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad. Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
    • Remove the four 1.2mm #00 Phillips head screws from rear of the trackpad.
Conclusione
Altre 8 persone hanno completato questa guida.
SIMRAN
Membro da: 30/10/2010
6.309 Reputazione
1 Guida realizzata
Master Techs Membro di Master Techs
Community
292 Membri
833 Guide realizzate
I had better luck using the #000 Phillips to get the 1.2mm screws out during step 7.
benchampa - Replica
I accidentally disabled my track pad in the system preferences how do I enable it again when the trackpad wont click?
Nicholas Noriega - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 19,664
