Introduzione
Follow this guide to replace a dead hard drive or upgrade your hard drive for more storage capacity.
Cosa ti serve
Panoramica Video
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Remove the four 6.0 mm T6 Torx hard drive retaining posts from the sides of the hard drive.
Transfer the hard drive retaining posts to your new hard drive.
Altre 266 persone hanno completato questa guida.
12 Commenti
Is there any specific order that's best for putting back the screws?
Start with the corners but after that it dose not matter
