Salta al contenuto principale
MacBook Pro 13" Retina Display Mid 2014 Feet Replacement
Cosa ti serve
  1. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 3, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 3, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 3, immagine 3 di 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement, Feet: passo 4, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Feet Replacement, Feet: passo 4, immagine 2 di 2
    • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
    • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
  5. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 5, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 5, immagine 2 di 2
    • Remove any broken or damaged feet.
    • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
    • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
  6. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 6, immagine 1 di 1
    • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
  7. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 7, immagine 1 di 1
    • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
  8. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 8, immagine 1 di 1
    • Peel a replacement foot from the plastic backing.
    • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
  9. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 9, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 9, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 9, immagine 3 di 3
    • Align the new foot inside the cavity.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • You may want to use a pencil to lightly mark where the alignment nub is located. Be careful not to scratch the lower case with your pencil.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
  10. MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 10, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Feet Replacement: passo 10, immagine 2 di 2
    • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
    • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Repeat the last seven steps for any remaining broken or worn feet.
Conclusione
Altre 27 persone hanno completato questa guida.
Taylor Dixon
Membro da: 06/26/18
67.033 Reputazione
94 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 75
Tutti i Tempi: 10,430
