Salta al contenuto principale
Introduzione
Use this guide to replace the trackpad. This procedure involves using adhesive remover to remove the battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
iFixit adhesive remover is highly flammable. Perform this procedure in a well-ventilated area. Do not smoke or work near an open flame during this procedure.
To minimize risk of damage, turn on your MacBook and allow the battery to fully discharge before starting this procedure. A charged lithium-ion battery can create a dangerous and uncontrollable fire if accidentally punctured. If your battery is swollen, take extra precautions.
    • Two 2.3 mm Pentalobe screws
    • Eight 3.0 mm Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    For all the screws you use the P5 pentalobe screwdriver?
    Carlos - Replica
    Pentalobe is only for the screws on the bottom cover. The Torx screw driver is for the remainder.
    Fredrik -
    Is the Pentalobe screwdriver mentioned in the tools list? I did not have one so I used a filed down flat blade screwdriver. Not a fantastic idea, but it works.
    Alex Birkett - Replica
    Yes, it's mentioned on the top of this page. P5 Pentalobe to be precise. I didn't have one either, so I bought one from iFixit and that works fantastic. An absolutely precise fit, which is important especially when you might open your MacBook a couple of times during the years you own it. Not using the correct tool might do more harm to the screws than you want! I once had this with a Lenovo Yoga 3 Pro, which has Torx screws (T4 I think) and I used cheap Chinese quality tools, with the result that both the tool and one of the screws are damaged.
    addvariety -
    the macbook in the picture is 2012. does it has the same structure as 2013?
    Edison - Replica
    I never, ever, ever considered using anything but the correct tool on the Pentalobe screws. Too easy to strip and void your warranty (if still in effect), as well as make it almost impossible to get inside later for another upgrade or repair. The Wiha P5 Pentalobe screwdriver fits like a glove and costs only about $11 (a fraction of your drive's price)at Amazon.com. Get it!
    marketing - Replica
    is P5 supposed to be for all 10 screws? it works on the 2x 2.3mm at the top, but not for the 8x others for me. what size screwdriver for the 3mm? thanks
    monsieurescargot - Replica
    Yes, the p5 works for all 10 pentalobe screw heads for bottom cover. The the different size mm reference only refers to the difference in length of the screws, but again both heads are p5.
    Antoine Thornton - Replica
    I followed this exactly and was able to replace my broken trackpad. I did not have to replace the ribbon OR the battery. However I would suggest getting the ribbon since it’s fairly cheap, as for the batteries I was able to do it with a card only. I didn’t use any heat or the liquid but it takes some time. You really have to work the card in there to release the glue. Also you must be very careful not to bend the batteries or damage them, if you do you must replace with new. This took me about 1.5hrs and my computer works like new. Apple cost for this job was around $450, I did it for $120. Big ups to ifixit for this awesome tutorial, tool set and parts!
    On a side note, only use quality tools, the cheap ones will break or strip the screws.
    Dustin Steward - Replica
    Note that the eight 3mm screws have a shoulder under the head, while the two 2.3mm screws are “full thread”, i.e., there is no shoulder under their heads. It’s important to put the two screws with no shoulder at the hinge of the cover.
    All ten screws require a P5 Pentalobe screwdriver, preferably with a magnetized tip to help hold and position the screw.
    All of the screws have blue “Loctite” thread locker compound on their threads. This is to help prevent the screws from working loose and falling out. Don’t attempt to clean the Loctite from the screws — leave it in place, and it will continue to help prevent the re-inserted screws from working loose.
    When replacing the bottom cover, it is a good technique to insert and BEGIN tightening all ten screws BEFORE fully tightening any one screw. After all the screws have been started, then go around and finish tightening all of them. By doing this, you make it easier to feel that each screw has been started properly, and is not “cross-threaded”.
    doubleclutch - Replica
    A good technique for starting to thread the screws when replacing them is to position and align the screw, and with the driver, gently turn the screw in the REMOVAL direction until you feel and hear a slight click. This click happens when the leading thread of the screw drops off of the leading edge of the thread in the hole — this is the point at which the threads are properly positioned for engagement. You can now turn the driver and screw in the TIGHTENING direction. This technique will help prevent accidental “cross-threading” of the screw, which will damage the threads permanently.
    Note that this is a useful technique when installing ANY threaded fastener.
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
    This takes a bit more effort than you might expect. Put your fingers where shown and lift about 3inches. With enough upwards pressure the plastic holders will “pop free” and the bottom will come off easily.
    hamiltont - Replica
  2. The lower case is connected to the upper case with two plastic clips near its center. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    There are two screws that are shorter-they go to the back near the vent.
    wrbandllm - Replica
    This was already mentioned at the start, it says 2x 2.3mm screws and those are coloured red instead of orange for the other ones in iFixit's image.
    addvariety - Replica
    What is the black vinyl-y sticker on the inside of the case (some sort of shield?). I was forced to slightly puncture it in order to replace the feet on my laptop. Thanks in advance.
    Tommy Huang - Replica
    When I got the back off, I found this piece loose, any idea what it is? about 9mm long frosted plastic
    https://imgur.com/a/tYaxGdG
    Fred Anderson - Replica
    This wording I found quite confusing. They just mean when putting the lid back on that you just removed in the previous step, push here.
    Mmm ttt - Replica
  3. If necessary, remove the plastic cover adhered to the battery contact board.
    • If necessary, remove the plastic cover adhered to the battery contact board.
    Do you know where I can purchase this plastic cover? Mine is missing and no one will work on my computer without it.
    jodieabc - Replica
    There is no point on going near the battery or logic board. I cut out these steps with no issue. It is precautionary but unnecessary.
    Jaime Leonard - Replica
  4. Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board. Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
    I have a friends MacBook Pro that has some water damage that caused the MacBook not to be able to use battery power, but still work when plugged into A/C. Upon further inspection I can see visible corrosion on a few of the 9 cables going from the battery connector to that small circuit board. Is it possible to just replace that circuit board?
    jramsey21 - Replica
    I have the some problem. I was thinking to replace the whole battery but I am not it will solve the problem. Any suggestions?
    salvatorebarbera -
    Sometimes it can be enough to just clean the contacts without having to replace the entire board. Dosent work for complicated IC's like plcc type, where corrosion is underneath the chip. Here you will have to reheat and reapply the IC.
    andrehedegaard -
    Hi,have you find the solution for your battery? I also have same problem, run with plugs but it battery not supporting… as soon the plug of it goes off
    Jewel Rahman -
    Have either of you replaced the battery and/or circuit board to fix the MacBooks with the water damage ? I have the same problem with the MacBook working fine when connected to power but dying immediately when the power cord is removed.
    Steve - Replica
    Hi, Steve. I had the same problem: Macbook Pro 15 retina with coffee damage. And it worked fine when connected to power. I made it working after replacing the whole battery. It seems that circuit connected to the battery becomes disabled to prevent short circuit.
    Vadim Gribanov -
    When placing the battery connector back into the socket on the logic board, check that every part of connector is pressed down. You should hear a soft click when it's back in place.
    Ethan Tarquin - Replica
    Thanks for the comment. My MBP isn’t powering on after I walked through these steps, and I assume it is because the battery connector isn’t fully connected. (I can’t check yet since I borrowed the pentalobe screwdriver)
    Caleb Steinborn -
    +1
    I thought I made sure it was connected but when running the computer it only detected the battery but couldn’t power it. I had to run with power adapter. Also it didn’t charge. I guess some pins were connected but not all. To verify that all were connected I removed the plastic cover, placed it carefully completely flat, and then reattached the plastic cover. After that it worked!
    Jonas Ehrs -
    If I only want to replace the trackpad cable, then which steps should I skip? This step seems unnecessary
    Parth Gudhka - Replica
    Removing the battery connector took a bit of finagling. It wasn’t as easy as one would think. Be very careful when doing this as they warn to not damage it. Otherwise great instructions!!!!
    Peppon - Replica
  5. Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
    If you miss or let this step for later like I did, the power left in the battery even though the computer is completely shut down, will screw up the I/O board cable like I did. I noticed this after I put all the pieces back, turn the computer on and surprise, no wifi hardware is detected. -.-
    sebasgaes - Replica
    I put a small piece of blue painters tape on the battery connector contacts to prevent it from accidentally making a connection and shorting. This helped keep things a bit more protected.
    LaymanLab - Replica
    That’s a great idea!
    David Lilliebridge - Replica
    I used a small piece of paper to prevent the connector from connecting, no need to wrestle with even low-stick adhesive.
    dbrick - Replica
  6. Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
    • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
    At this point it's a good idea to take sheet of printer paper, like A4, and press each screw into the paper roughly in the position it was removed from. When it comes time to reassemble it, you wont get the different lengths mixed up.
    Martin Gray - Replica
    This step was not necessary for me to remove the battery. Perhaps it's a safety precaution? Regardless, skipped the I/O Cable removal (Steps 7, 8, 9, 10) and didn't have any problems replacing the battery.
    barak - Replica
    After this step I continued from step 13, the steps in between were not really necessary in my opinion ( I succeeded the replacement without them). Just be careful not to touch these connectors during replacement.
    driesverfaillie - Replica
    While it may not be necessary to remove the left and right speakers, doing so will make it much easier to get at (and under) the end batteries and their adhesive pads. Also, by removing the speakers, you also get them out of harm’s way while you wrestle with loosening the batteries’ adhesives.
    I recommend removing the speakers and their connectors as described in the iFixit instructions.
  7. Grasp the I/O board cable bracket with a pair of tweezers and remove it from the MacBook.
    • Grasp the I/O board cable bracket with a pair of tweezers and remove it from the MacBook.
  8. Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board. Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  9. Lift the logic board end of the I/O board cable straight up to bend it out of the way. To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
    I removed I/O Board cable completely on both ends using a flat end plastic spudger tool. I did not feel comfortable “bending” it as shown in Pic. Be careful to not damage sockets on either end when removing battery. Extra care to not get any adhesive debris in exposed sockets. I have used the solvent with syringe and that can get rather messy and risk getting liquid onto keyboard/screen/motherboard components etc/. This time I used a plastic “Disposable Putty Knife” from Ace hardware. Speakers where easily removed in subsequent steps. Started pushing in from edges with plastic putty knife and battery cells separated surprisingly easy. This method is clean & much easier than the dental floss struggle!! I used Googone with QTips to remove adhesive remnants.
    lamajr - Replica
  10. Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board. Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
    • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
    Same as my comment on Step 7: This step was not necessary for me to remove the battery. Perhaps it's a safety precaution? Regardless, I skipped the speaker cable removal (Steps 11, 12) and didn't have any problems replacing the battery. Same as my comment on Step 11: This step was not necessary for me to remove the battery. Perhaps it's a safety precaution? Regardless, I skipped the speaker cable removal (Steps 11, 12) and didn't have any problems replacing the battery. ( FYI - I used a heat path method, vs the solvent)
    barak - Replica
    WARNING TO ANYONE WHO DOES THIS STEP! Be very careful to distinguish the cable end from the socket! I just managed to break the entire socket off of the logic board. I may try to solder it back on, but I may not, since it’s only for the speaker… Very disappointing anyway. The instructions should make it more clear just how delicate the socket itself is, especially right where the photo shows you inserting the spudger under the cable end to start dislodging it. It’s really hard to distinguish the cable end from the socket on this side!
    jiclark - Replica
    Put the spudger under the very centre where you see the cutout and be gentle !! It does in fact pry upward the wire itself is very fragile.
    Mmm ttt - Replica
  11. Carefully peel the right speaker cable off the upper case. Carefully peel the right speaker cable off the upper case. Carefully peel the right speaker cable off the upper case.
    • Carefully peel the right speaker cable off the upper case.
  12. Remove the following screws securing the right speaker to the upper case:
    • Remove the following screws securing the right speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  13. Lift the right speaker from the cable end and pull it free from the case. Lift the right speaker from the cable end and pull it free from the case. Lift the right speaker from the cable end and pull it free from the case.
    • Lift the right speaker from the cable end and pull it free from the case.
  14. Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board. Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
    • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
    Same as my comment on Step 11: This step was not necessary for me to remove the battery. Perhaps it's a safety precaution? Regardless, I skipped the speaker cable removal (Steps 11, 12) and didn't have any problems replacing the battery. ( FYI - I used a heat path method, vs the solvent).
    barak - Replica
    Yes, no need to unplug the speakers cable. I used the solent, just put speakers on the motherboard.
    Aleš Smokvina - Replica
    slight touch of glue secures speaker cable to MB. Use steady light presuure with spudger edge to unglue and then disconnect cable from MB
    lamajr - Replica
  15. Remove the following screws securing the left speaker to the upper case:
    • Remove the following screws securing the left speaker to the upper case:
  16. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  17. Lift the corner of the left speaker up and slide it out the battery to remove it from the upper case. Be careful not to snag the speaker cable on the screw hole post in the side of the case. Be careful not to snag the speaker cable on the screw hole post in the side of the case.
    • Lift the corner of the left speaker up and slide it out the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
  18. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    which temperature must be used for heating? Thx
    fbarletta - Replica
    I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
    By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
    Fredrik -
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - Replica
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - Replica
    Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
    Fletcher Carpenter - Replica
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - Replica
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - Replica
    Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
    Esmond Pitt - Replica
    Hi, the microware have multiple power 1 to 9, what must be used ?
    Regards,
    Cedric
    Cedric VINCENT - Replica
    My microwave just died, can i heat it with boiled water?
    Alex COLOMBANI - Replica
    Taping as shown is impractical when using hair dryer method—tape simply comes off in the heat and gets in way of getting out the shards on the sides. If the thing wasn’t shattered, then taping unnecessary.
    B. A. Computer Services - Replica
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - Replica
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - Replica
  19. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
    yamayhuang - Replica
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - Replica
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - Replica
    I don't own a microwave.
    mdanihy - Replica
    Its again waterproof when you change iphone 7 battery?
    Jon - Replica
    I don't have a microwave???
    Joe Blow - Replica
    30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
    Sam Stieg - Replica
    can i use just ordinary microwave???
    juneseok kwon - Replica
    If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
    Mohideen Rifay - Replica
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - Replica
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - Replica
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - Replica
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - Replica
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - Replica
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - Replica
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - Replica
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - Replica
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - Replica
  20. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Will a hair dryer work for heating the glass?
    Me berg - Replica
    Can you use an oven instead?
    Rafael -
    Yes, as does a heat gun.
    anonymous 4602 - Replica
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - Replica
  21. Remove the five 3.7 mm T5 Torx screws securing the battery to the upper case.
    • Remove the five 3.7 mm T5 Torx screws securing the battery to the upper case.
    In my macbook pro retina, these are some kind of plastic screws. I cannot remove them.
    adriendavernas - Replica
    The plastic screws just need to be pulled out with a spudger/finger and you're good to go. I have the same model, there's also a screw on the power board not mentioned in this guide, takes a T5 screwdriver/bit
    alex - Replica
    Question - when putting the new battery back into the case, do we need to remove old glue/add new glue, use no glue at all, or place the battery in and then reheat to melt the old glue so that it will adhere to the new battery? Thanks!
    chal740 - Replica
    What is the part number for this battery, or where can I find it?
    dfreeman110 -
    I wish to ask the same question.
    vbivanov -
    My adhesive didn't have enough tack to hold the battery in. I just reassembled without it and can't hear the batteries moving, but I have the rubber grommets and not screws as MarkB mentioned. Fo future repairers, I'd recommend buying some nonpermanent two sided tape just so you have the option to fasten it in.
    Vince Cipriani -
    I wish they would find another way of securing the battery, this is ridiculous.
    brian whittle - Replica
    On each 'corner' of the frame that surrounds the two centre batteries, rather than 'plastic screws' mentioned by adriendavernas there are 'domed' rubber grommets. These presumably rest against the inside of the bottom cover when it is fitted thus supporting the batteries. As there were no screws underneath in these 4 positions, there is no need to remove these grommets. Agree with alex re: removing the extra T5 screw on the power board.
    MarkB - Replica
    After destroying the adhesive which secures the batteries (bad technique or lack of patience in my effort) what is recommended to secure the batteries when reassembling?
    maxB - Replica
    The iFixit Battery had adhesive pre-applied. plenty of 3M Tissue Tape
    Rhys Goode -
    I only had the single far right screw to remove.
    barak - Replica
    My replacement A1582 battery actually had holes for the screws, though my original A1582 battery only had the 'domed' rubber grommets. Anyways, putting in the OEM A1582 battery without anything in the holes worked ok.
    Srini Seetharaman - Replica
    I wanted to put the rubber grommets on the new battery, so I used tweezers to get them back through the holes on the new battery
    Dallin Christensen - Replica
    My battery replacement came with 4 rubber grommets pre-installed, so perhaps this is no longer necessary
    hamiltont -
    Can somebody tell me what kind of screws I would need to secure the new battery? I would like to put screws into the screwholes left open by those rubber grommets.
    thekryz - Replica
    3,7 mm is the lengh I gues. How thick are they?
    Wanna know how I can search for replacement screws cause I lost the originales.
    Chris Shine - Replica
  22. The liquid adhesive remover provided in your iFixit battery replacement kit can affect the antireflective coating on your MacBook Pro's display.
    • The liquid adhesive remover provided in your iFixit battery replacement kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  23. If you have an iFixit battery kit with liquid adhesive remover, it's time to get it prepped. Alternatively, if you are using the hot iOpener method, skip the following three steps.
    • If you have an iFixit battery kit with liquid adhesive remover, it's time to get it prepped.
    • Alternatively, if you are using the hot iOpener method, skip the following three steps.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  24. Pull off the black rubber stopper from your bottle of adhesive remover. Twist to loosen or remove the bottle cap before you cut the applicator tip. This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
    Air can tilted upside down to freeze the adhesive works very well also. I just used this method today to pull a battery.
    aadeshina - Replica
    @aadeshina - That’s an excellent suggestion. I took your advice, and tried it with a can of MG Chemicals “403C Super Cold Spray”, which I had on hand for other electronics work. It worked very well — it froze the adhesive to the point where it was quite easy to work the plastic iFixit cards under the batteries, and pry them loose.
    I like this freeze technique much better than the volatile, flammable, risky solvent approach for removing the batteries. I did however find the solvent useful for softening and removing the residual adhesive remaining in the case after the old batteries were removed.
    There are many brands of aerosol freeze sprays available on Amazon, DigiKey, Mouser, etc.
    As above, Another solution to remove the batteries, (Maybe not environmentally friendly): I removed the Logic board and related components to protect them and took a can of compressed air (the kind you buy at office stores for cleaning printers and such) Invert it and use the included straw to direct the propellant (which is extremely cold under the batteries. The adhesive holding the batteries in becomes brittle and u can just pop them out with medium force using a wide putty knife. Took me 3 min to do.
    JVerdonck - Replica
  25. Apply a few drops of adhesive remover evenly under the edge of the rightmost battery cell.
    • Apply a few drops of adhesive remover evenly under the edge of the rightmost battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    • Use more adhesive remover if needed, but do not apply more than a few drops at a time. Using too much can allow the adhesive remover to make its way to the backside of your keyboard and potentially damage it.
    I managed to remove the battery without the adhesive by using the thread technique. More info in this video: https://www.youtube.com/watch?v=fupkPz55... . Just make sure you have someone to help you and hold the laptop in place for you.
    Thank you very much! This is an absolute win technique
    Денис Медведев -
    I agree that this worked much better. A few suggestions for others:
    - one type of thread that works very well is fishing line. While you can use monofilament (the clear plastic), if you can get the braided fishing line you will find it is extremely thin and super strong and works very well for this
    - string pulled tightly can cut more than just the adhesive, so be careful what you allow the string to rub against while you are pulling it. I can easily cut into another cable or the battery
    - I found that gloves (not latex, big gardening or construction gloves) helped me use string without needing to go “ow” every few seconds from your hand hurting. I have some gloves with nice grip and good hand protection, I would get the string positioned, put on the gloves, and start pulling. It worked fantastically
    I was able to remove the battery easily with the string method, and i did not remove the speakers to do so. However, when I went to seat the new battery I chose to remove the speakers to make it easier to place
    hamiltont -
    For easier removal I used a combination of heat from a hot water bottle and solvent.
    ip_leyland - Replica
    I used waxed dental floss (not sure whether the ‘waxed’ is important), which worked like a charm. I cuts through the tape much easier than seen in the linked YouTube video linked above. Each battery cell was loosened within 5-10 seconds. It worked amazingly well, and taking out the old batteries proved to be no challenge at all.
    Gerd - Replica
    +1 for dental floss - used it too and managed to cut without any effort.
    JX Low -
  26. If you don't have a liquid adhesive remover, you'll be using a hot iOpener to warm and soften a section of the adhesive securing the battery to the upper case, and then carefully prying at that point. Use the hot iOpener to cover half of the two right-most battery cells.
    • If you don't have a liquid adhesive remover, you'll be using a hot iOpener to warm and soften a section of the adhesive securing the battery to the upper case, and then carefully prying at that point.
    • Use the hot iOpener to cover half of the two right-most battery cells.
    • After about a minute, reheat the iOpener and move it to cover the other half of the right-most battery cells.
    I did not have an iOpener. I did not fancy using a heat gun on the batteries either so I used two flat metal spudgers to prise them off the body of the mac book. I hit the spudgers with a small hammer.
    I popped the freaking iopener in the microwave following this instruction. Said to heat for 30 secs put on for a minute then reheat after that minute. Then read on the iopener that I shouldn't heat more the once unless after two minutes. Just wonderful.
    Jennifer Myer - Replica
    I used a sock filled with rice and it worked exactly the same. Microwaved it for 2 minutes (hot enough to barely hold) and set it on the batteries as above for 2 minutes.
    Then I reheated it for a minute and opened up the laptop, and slide my DYI iOpener under so it was directly under the batteries (across the trackpad portion of the laptop). This worked great because the heat went straight thru the aluminum and softened the adhesive. I ended up letting the screen hang over the edge of the table while I pried the batteries out.
    barak - Replica
    This heating with the iOpener took me forever. I tried my fair share of heating followed by nudging slowly with a credit card 1 mm at a time. Finally pried it off after 30 mins.
  27. Push a plastic card between the right-most battery cell and the upper case, cutting the adhesive between the two. Throughout this procedure, be careful not to damage any of the battery cells with your tools. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    • Push a plastic card between the right-most battery cell and the upper case, cutting the adhesive between the two.
    • Throughout this procedure, be careful not to damage any of the battery cells with your tools. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    • When using the hot iOpener method, if you encounter significant resistance to prying, stop and use the iOpener to reheat the section you're working on.
    In addition to using the wheat bag/iOpener to loosen the batteries, I found it useful each time I inserted the plastic card under the batteries to give the card a 'wipe' with isopropyl alcohol to ensure that it didn't stick to the adhesive holding the batteries down. it also presumably eases the glue away from the batteries somewhat.
    MarkB - Replica
    Do the same tools and steps work on a MacBook Pro 15" late 2015 model?
    Sean - Replica
    Heat can be dangerous to Li-Ion batteries, no???
    Alex - Replica
    Excessive heat can be dangerous, but the iOpener is designed to never get hot enough to cause permanent damage. Using a heat gun or hot plate could be dangerous, but the iOpener method is the safest one we know of =)
    Sam Goldheart -
    I found it helpful to use some dental floss to help loosen each cell and then pry the rest off with the card
  28. Use the plastic card to pry the right-most battery cell up from the rear case. Use the plastic card to pry the right-most battery cell up from the rear case.
    • Use the plastic card to pry the right-most battery cell up from the rear case.
  29. Repeat this procedure with the adjacent battery cell: Apply a small amount of liquid adhesive remover under the battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive. Alternatively, re-heat this section with your iOpener if needed.
    • Repeat this procedure with the adjacent battery cell:
    • Apply a small amount of liquid adhesive remover under the battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Alternatively, re-heat this section with your iOpener if needed.
    • Push a plastic card about an inch between the battery cell and the upper case, and slowly pry the cell up to separate all of the adhesive.
  30. Temporarily leave your plastic card underneath the two rightmost battery cells to prevent them from re-adhering to the upper case. If using an iOpener, reheat it and reapply it, this time to the left-most battery cells. Again, leave the iOpener in each position for about a minute, reheating in between, to heat each half of the left-most battery cells.
    • Temporarily leave your plastic card underneath the two rightmost battery cells to prevent them from re-adhering to the upper case.
    • If using an iOpener, reheat it and reapply it, this time to the left-most battery cells.
    • Again, leave the iOpener in each position for about a minute, reheating in between, to heat each half of the left-most battery cells.
  31. Repeat the above procedure to separate the two leftmost battery cells from the upper case. Remember to apply a small amount of adhesive remover to each battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive. Use a second plastic card to separate the two leftmost battery cells from the upper case.
    • Repeat the above procedure to separate the two leftmost battery cells from the upper case.
    • Remember to apply a small amount of adhesive remover to each battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Use a second plastic card to separate the two leftmost battery cells from the upper case.
  32. Leave the second card in the corner between the two left cells.
    • Leave the second card in the corner between the two left cells.
    • In the following steps, you can either use a third card, or the card from the right corner. The right corner adhesive should be dry/cool enough that the cells can easily be pulled up again when needed.
  33. To separate the adhesive securing the final two, middle battery cells, apply a few more drops of liquid adhesive remover (or your iOpener) to each cell. Apply the adhesive remover sparingly, since the trackpad lies beneath this area of the battery.
    • To separate the adhesive securing the final two, middle battery cells, apply a few more drops of liquid adhesive remover (or your iOpener) to each cell.
    • Apply the adhesive remover sparingly, since the trackpad lies beneath this area of the battery.
    • It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
    • Insert the card about an inch between the left-center battery cell and the upper case, separating the adhesive between the cell and the case.
    My laptop had a strip over these center batteries. I had to remove that before getting the center batteries off.
    My plastic cards were hitting a black trackpad backing. I thought this was the adhesive not coming off. I also didn’t want to harm the battery and didn’t bring the card up enough.
    I found out by going through one of the side batteries, but could have just raised the tip of the card very slightly.
    Cameron Malek - Replica
    I recommend you do not use the liquid adhesive remover for the middle battery pods. These do not rest nicely in their own “tray” like the two parts on the left and right. Consequently, it is very easy to apply too much liquid, allowing the excess to run into your trackpad and logic board. Even though the liquid dries quickly, it does leave behind a little residue. The result from my experience was a slightly faulty connection for my screen, causing random pixel flickers in dark spaces on my screen. Use the floss method found elsewhere online. It is much more difficult to get out but does not risk damaging your computer.
    Andrew Jensen - Replica
  34. Pull the card back out and insert it about an inch between the right-center battery cell and the upper case, separating the adhesive between the cell and case. Pull the card back out and insert it about an inch between the right-center battery cell and the upper case, separating the adhesive between the cell and case.
    • Pull the card back out and insert it about an inch between the right-center battery cell and the upper case, separating the adhesive between the cell and case.
  35. By this point, the outer cells should be free, and you should only encounter resistance from the two center cells. If this is not the case, go back and completely loosen the four outer-most cells from the upper case. Pry up on the two center cells to separate the last of the adhesive and lift the battery from the device.
    • By this point, the outer cells should be free, and you should only encounter resistance from the two center cells. If this is not the case, go back and completely loosen the four outer-most cells from the upper case.
    • Pry up on the two center cells to separate the last of the adhesive and lift the battery from the device.
    I found that gentle application from a heat gun works well enough to soften the adhesive. Use a plastic card to help as you go. Use caution not to over heat anything.
    John Lerefebvre - Replica
  36. Remove the battery. Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • Remove the battery.
    • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
    RECOMMENDATION: The battery connector and associated screw are critical when considering battery alignment. Also don’t forget the left and right speaker assemblies when aligning the two small outer cells. I didn’t consider these and had issues.
    Also, keep the transparent top film on the battery to keep the cells aligned with respect to each other, and always support all the cells if handling upside down.
    I agree, if you don’t reinstall the speaker assemblies before installing the battery, they may be impossible to put back in after the battery has adhered
    Anyone reconcile the different instructions for batter calibration? Inside battery package is a business card that says drain below 10% then charge uninterrupted to 100%. That is completely different then above: “Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.”
    ryan - Replica
    The longer calibration method detailed in the guide is correct. I believe the printed cards are due for an update.
    Jeff Suovanen -
  37. Place a reheated iOpener over the trackpad cover plate to soften the adhesive securing it to the upper case.
    • Place a reheated iOpener over the trackpad cover plate to soften the adhesive securing it to the upper case.
    • Be careful not to overheat the iOpener during the repair. Always wait at least two minutes before reheating the iOpener.
  38. Use a plastic opening tool to carefully pry the trackpad cover plate up from the upper case. Go slowly and carefully to avoid putting any visible creases in the plate. Go slowly and carefully to avoid putting any visible creases in the plate.
    • Use a plastic opening tool to carefully pry the trackpad cover plate up from the upper case.
    • Go slowly and carefully to avoid putting any visible creases in the plate.
    This adhesive was extremely strong for me and took quite a while to soften up (longer than batteries). I ended up using my wife's blow dryer after the heat pad struggled with it. Just take your time.
    Vince Cipriani - Replica
  39. Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case. Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case. Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case.
    • Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case.
  40. Gently peel the plate up to remove it. Gently peel the plate up to remove it.
    • Gently peel the plate up to remove it.
  41. If necessary, peel back any tape covering the trackpad cable connector.
    • If necessary, peel back any tape covering the trackpad cable connector.
  42. Use the tip of a spudger to flip the retaining tab on the ZIF connector. Use the tip of a spudger to flip the retaining tab on the ZIF connector.
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  43. Pull the trackpad ribbon cable straight out of its socket on the logic board.
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
    Don't use tweezers for this (???) Pull straight, starting gently and a little firmer until it gives. 2014 doesn't have the retaining tabs
    Mmm ttt - Replica
  44. Wedge the flat end of a spudger underneath the upper case opening where the trackpad ribbon cable passes is routed through. Gently pry the trackpad ribbon cable from the adhesive securing it to the upper case.
    • Wedge the flat end of a spudger underneath the upper case opening where the trackpad ribbon cable passes is routed through.
    • Gently pry the trackpad ribbon cable from the adhesive securing it to the upper case.
  45. Remove the following screws securing the trackpad brackets to the trackpad and upper case.
    • Remove the following screws securing the trackpad brackets to the trackpad and upper case.
    • Four 2.2 mm T5 Torx screws
    • Four 1.7 mm T5 Torx screws
  46. Use tweezers to remove the two trackpad mounting brackets from the upper case. Use tweezers to remove the two trackpad mounting brackets from the upper case.
    • Use tweezers to remove the two trackpad mounting brackets from the upper case.
  47. To avoid scratching the display, open the computer about 90º and set it on end. Carefully guide the trackpad ribbon cable through the slot cut in the upper case.
    • To avoid scratching the display, open the computer about 90º and set it on end.
    • Carefully guide the trackpad ribbon cable through the slot cut in the upper case.
    • This will push the trackpad up out of its recess in the top of the upper case.
    • Guide the trackpad out of the upper casewith your other hand, so it doesn't fall.
  48. Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable. Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable. Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable.
    • Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable.
    Regarding the re-assembly once the trackpad is back in place, be careful when re-fitting the batteries; the adhesive which takes so long to separate may not hold the batteries to the chassis upon re-fitting. It may be necessary to use thin double-sided foam tape to ensure that the batteries are held firmly in place once again so that vibration does not cause the connections between the batteries to fail.
    MarkB - Replica
    If your new trackpad won't fit into place, loosen the screw at the bottom, center of the case (you can see it in the step 36 pic). Don't forget to tighten it back up. This screw affects the amount of play and click in the mouse, so fine tune it until the pad clicks to your liking.
    Make sure you have a good fettle with the trackpad before sticking the battery back in, the brackets in 42 and 43 can move slightly and affect the position and function of the trackpad. Ensure you are happy with it all and fasten it in place before you think about the battery. Took me a while to get it sitting just right and true.
    Phil Taylor - Replica
Conclusione
Altre 25 persone hanno completato questa guida.
Sam Goldheart
Membro da: 18/10/2012
378.851 Reputazione
543 Guide realizzate
iFixit Membro di iFixit
Community
99 Membri
9.282 Guide realizzate
It's also worth mentioning that if your new trackpad doesn't click - there is a T6 torx adjustment screw located dead center of the bottom frame, below the battery (but not underneath it, so battery removal isn't required).
Turning this screw counterclockwise or clockwise will increase or decrease the travel of the trackpad clicking action. When i installed my replacement pad, it was not clicking at all - but turning this screw a bit counterclockwise fixed that problem!
Diver Dave - Replica
Anyone ever noticed problems with keyboard after changing the trackpad?
javdvoort - Replica
Is it possible to replace just the ribbon cable that connects the trackpad to the motherboard?
Alisio - Replica
This is fantastic. Thanks, I was able to replace the trackpad for about $50; the authorized Apple shop in my area wanted $500.
billrolfes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 28
Ultimi 7 Giorni: 182
Ultimi 30 Giorni: 651
Tutti i Tempi: 44,910
