Salta al contenuto principale
MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement
Cosa ti serve
  1. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 3, immagine 1 di 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 3, immagine 2 di 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 3, immagine 3 di 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement, Battery Connector: passo 4, immagine 1 di 1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 5, immagine 1 di 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 6, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 6, immagine 2 di 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 7, immagine 1 di 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 8, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 8, immagine 2 di 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement, AirPort Board Assembly: passo 9, immagine 1 di 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  10. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 10, immagine 1 di 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 10, immagine 2 di 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 10, immagine 3 di 3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  11. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 11, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 11, immagine 2 di 2
    • Move the antenna cables aside, clear of the AirPort board.
  12. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 12, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 12, immagine 2 di 2
    • Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board.
    • Gently pry the AirPort board upwards, but do not remove it.
    • Only lift the AirPort board as much as is necessary to get a grip on it. Lifting it too high above the I/O board may damage the board or the socket.
  13. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 13, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement: passo 13, immagine 2 di 2
    • Pull the AirPort board straight out of its socket on the I/O board.
  14. MacBook Pro 13" Retina Display Late 2012 AirPort Board Replacement, AirPort Board: passo 14, immagine 1 di 1
    • AirPort board remains.
Conclusione
Altre 17 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 54
Tutti i Tempi: 16,375
