Salta al contenuto principale
MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement
Solo Prerequisita
Questa guida รจ destinata a essere usata solo come prerequisito per altre guide. Da sola รจ incompleta.
Cosa ti serve
  1. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement, AirPort Board Assembly: passo 1, immagine 1 di 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  2. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 2, immagine 1 di 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 2, immagine 2 di 3 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 2, immagine 3 di 3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  3. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 3, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 3, immagine 2 di 2
    • Move the antenna cables aside, clear of the AirPort board.
  4. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 4, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 4, immagine 2 di 2
    • Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board.
    • Gently pry the AirPort board upwards, but do not remove it.
    • Only lift the AirPort board as much as is necessary to get a grip on it. Lifting it too high above the I/O board may damage the board or the socket.
  5. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 5, immagine 1 di 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: passo 5, immagine 2 di 2
    • Pull the AirPort board straight out of its socket on the I/O board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 85
