Introduzione
Use this guide to replace the right speaker.
This guide is for the speaker on the right side of your notebook when operating normally, during most of the guide it will be on the left, as your laptop will be upside down.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
Remove the I/O board cable bracket.
Altre 68 persone hanno completato questa guida.
5 Commenti
Il ne faut surement pas plier la nappe de la carte E/S mais dévisser son support afin de ne pas l’endommager. Une fois pliée, elle ne reviendra jamais parfaitement droite. Il y a deux petites vis qui maintiennent le support qu’il faut dévisser, à moins qu’il y ait encore quelque chose de caché !
It is best to always disconnect power from any device you’re working on. Worst case scenario you lay a screw driver down on the device or drop a conductive piece of metal somewhere into the case and it shorts out the board you’re working on. This is the safest way to do repairs.
Will this be back in stock in the UK anytime soon?
