Introduzione
Use this guide to replace your I/O board data cable.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Grasp the Interposer with tweezers.
Lift the Interposer off the logic board and remove it.
Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
Altre 2 persone hanno completato questa guida.
