Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Use this guide to replace the display assembly.
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    If don’t have one of those neat project mats, then you can use small pieces of flattened blu-tack to hold the screws. If you arrange them in the shape of your mac book cover, and put the screws down methodically, you can get a one-to-one mapping of the screws to the correct screw holes.
    Toby Thurston - Replica
    Or you can use an ice tray where you put the screws and the parts in separate bays in the same order as they come in the instructions.
    timofej.se -
    The colors of the circles marking the locations of the screws are reversed.
    Homer Hegedus - Replica
    On my model A1425 these were all 1.2mm P5 screws. They all looked the same to me.
    bigfish333 - Replica
    This is great! I used a small magnetic white board, and wrote on it to identify the parts as I went. This whole process, from the fast shipment to the great instructions to the complete, high quality, tool kit has been great. I’m typing this comment on my resurrected laptop. Thank you! Sue
    Susan Greer - Replica
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. The lower case is connected to the upper case at the center, with two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. Remove the plastic cover adhered to the battery contact board.
    • Remove the plastic cover adhered to the battery contact board.
    This plastic cover wasn’t included with the new battery so I placed the original one back in. Was it supposed to go back in? This detail wasn’t clear since the original cover didn’t fit exactly over the newer battery connector. Plus any stickiness of adhesive that may have been there was gone.
    arnolfo santoro - Replica
    Hi, any issues with you computer after a year? I didn’t put mine back in either…
    Kevin Burlinson -
    Kevin, I forgot to place mine back in! How is your laptop doing without it?
    Dominic Radcliffe - Replica
    My “on button” isn't working. I was wondering can I just disconnect the battery like this, and plug it in to turn it on? Which is shown possible on earlier models on YouTube.
    carsrcrap - Replica
    Is it ok if I did put the plastic cover back in?
    Sandy Lyon - Replica
    yes, it is okay
    Deniel Alekseev -
  4. Remove the following screws securing the battery connector board to the logic board:
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
    Top screw in this image was not a T6. I found that a T5 bit fit this one.
    Alex Grayson - Replica
    I can not put back top screw holding the plastic part. Help please
    Tatiana Garcia - Replica
    The colors of the circles marking the locations of the screws in the photo are reversed.
    stop abusing
    Deniel Alekseev -
  5. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board. Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
    Is adhered to screw beneath, so lift firmly and slowly.
    Andrew - Replica
  6. Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
    I lost this screw! How important is it? Will it be okay with just the 3 previously removed screws?
    Gerardo Jimenez - Replica
    Check your speakers for the screws. The magnet for the speakers is strong enough to stick to them.
    Jeff M - Replica
  7. APRI TUTTE LE SCHEDE
    Kit espansione RAM per Mac
    Acquista Kit
    Abbastanza RAM
    Per tutte le schede
    Acquista Kit
  8. Carefully lift the battery connector board up off the logic board. It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. Grasp the Interposer with tweezers. An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
    WHy to remove battery contact board? Replace can happen without it also, right.
    Behram Beldagli - Replica
    You don’t want to work on a live system as you could damage parts
    Dan -
    How can I remove interposer I m not able to remove it
    Raunak - Replica
    you must lift it absolutely vertically, or it fouls against the locator pin in the corner- you can easily get the impression that it won’t come over the end of this pin- almost like it’s rivetted in. it isn’t. get a good grip on it with the tweezers in the centre hole & one of the sides, & lift it STRAIGHT up.
    duncan rmi -
    What happens if the Battery Contact Board fails?
    racoon2956 - Replica
    Be extra careful when tightening down on the interposer. When I powered on upon completion, the battery was not connected. When I opened it back up, I saw that one of the little metal nubs holding the interposer in place had snapped off (the one on the side, not the corner). I was able to carefully tighten the wide head screw back in, watching the alignment, and the battery was successfully recognized. Hopefully the connection holds up.
    Doug Krieger - Replica
    So something similar happened to me. One the the metal alignment nubs snapped off, and when I went to screw down the interposer it started emitting a burning smell. Do you guys think I fried the board? There doesn’t look to be any visual damage but the computer wont turn on.
    Geremy C -
    Where can I buy a replacement interposer? I may have lost mine in the process of replacing the battery.
    juan.su - Replica
    земля пухом братан, ты приехал
    Deniel Alekseev -
    I bought an interposer on amazon
    Kris K - Replica
    I think I snapped off the nub as well, and the battery is not recognized . Replacing the interposer did not help, or trying to align it right. will have to try to replace the battery next.
    Kris K - Replica
    I really dont understand why to unplug so many parts if the SSD can be easily removed without all this effort. its not even connected to the battery..
    Gabriel Beolchi - Replica
    I was reassembling and put the interposer back and when the battery contact board touched the interposer, there was a little spark. Should I be worried?
  10. Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board. It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
    This was the hardest part of the repair for me. The iSight cable was really lodged in its socket. "Walking" the connector as the guide suggests -- i.e. pushing on each side alternately at a 45 degree angle (with more force than I expected) -- eventually worked.
    Katherine Agnew - Replica
  11. Move the iSight camera cable aside.
    • Move the iSight camera cable aside.
    It is pretty much impossible to do this step before you do the next one as the airport cables are in the way.
    maccentric - Replica
  12. Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the socket closest to the ports.
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the socket closest to the ports.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
    What does the J0, J1 and J2 connections represent on the Airport Card? I had an issue where the wifi and bluetooth went out and said "Not Available" so I replaced the I/O board and the airport card. The Wifi now works but Bluetooth is still showing not available. I wanted to know which connection meant what and to see if I could fix the issue. I have reseated the cables, deleted the Bluetooh.plist file and reset SMC, but bluetooth still appears as Not Available.
    jlhunter2008 - Replica
    The long-sleeved and short-sleeved antenna cables are switched compared to this guide, on my Macbook Pro A1425. Maybe note which order they are in on your machine, since apparently they differ. http://i.imgur.com/r9g9ZXS.jpg
    Will Bradley - Replica
    Be very careful with these, I wasn't and two of the cables detached from the connectors!!
    Felix Waller - Replica
    Likewise, the antenna connectors on my Macbook A1425 Late 2012 Retina were not in the order as described in this guide. From the fan side the connectors should be - no sleeve, long sleeve, short sleeve
    smurad - Replica
    As two other users have mentioned, the long-and short-sleeved cables for my late 2012/early 2013 A1425 were not in the order mentioned in the guide. If the laptop is positioned with fan in the upper left corner, the order (left to right) is short sleeve, long sleeve, no sleeve. If it is positioned as it is in the photo with the fan in the lower right, the order (left to right) is no sleeve, long sleeve, short sleeve.
    I also found my cables were not as described in the guide. They were as @kagnew described.
    Daniel Revier - Replica
    My airport cables on my model A1425 were also as @kagnew described, not as written in the guide.
  13. Move the antenna cables aside, clear of the AirPort board.
    • Move the antenna cables aside, clear of the AirPort board.
    The display assembly has a metal retaining clip attached to the airport cables. I didn’t notice how this was positioned during disassembly, and it wasn’t mentioned in the guide. When I was reassembling the device, I found that it fit perfectly over the Torx T8 screws holding the display to the case. Attaching it here holds the airport cables nicely in place and out of the way.
    https://imgur.com/a/HK8mnOA
  14. Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer. Pull the display data cable straight out of its socket on the logic board. Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    • Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  15. Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges. Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
    • Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
  16. Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge brackets. Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge brackets.
    • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge brackets.
    I ended up stripping one of these out and had to use a T6 and some delicate pressure to get it out. Be careful.
    The T6 and a lot of downward pressure ended up doing the trick for me. YMMV
    This was a P5 screw not a T5 on my model A1425.
  17. Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges. Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
  18. Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case. Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
    • Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
    There is a retainer for the airport cables that goes beneath the left and center screws.
    My screws were covered with a thin tape, much like scotch tape. I used tweezers to remove it.
  19. Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown. While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  20. Grip both halves of the device, one in each hand. Gently push forward on the bottom half of the device to detach it from the display assembly. Carefully set each component aside, making sure to set down the lower half keyboard-side down.
    • Grip both halves of the device, one in each hand.
    • Gently push forward on the bottom half of the device to detach it from the display assembly.
    • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
Conclusione
Altre 29 persone hanno completato questa guida.
Sam Goldheart
Membro da: 18/10/2012
417.956 Reputazione
547 Guide realizzate
iFixit Membro di iFixit
Community
129 Membri
12.526 Guide realizzate
perfect tutorial! I fixed my screen completely destroyed falling down from my hands while a was falling asleep. Bought a new one on eBay (not original but perfect with the exception of the case slightly different in color and "texture".
Thanks iFix IT!
Ciao
Ciro
Ciro - Replica
This walkthrough/guide is PERFECT! I barely tinker with electronics, but the high cost of repair made me want to try to install a new display assembly myself. Bless you, Sam Lionheart!
Virgil - Replica
This worked really well. The only issue I had was uninstalling the camera. The instructions to pull the data display cable parallel to logic board made sense in step 14. Unfortunately I didn't understand the similarities in step 10. Is it possible to repair the camera now that the slot is completely broken?
D Sh - Replica
Walk through worked perfect. Did it twice. The first time was just to make sure that wasn’t anything disconnect or any wires damage. The second time was to replace the screen. Works perfect.
Cody Milliron - Replica
Hi,
can I replace an damaged display of a MacBook Pro 13” late 2013 with a display from the early 2013 version?
I compared the high-def pictures of each cable connection and they seem to be identical, or am I wrong?
Thanks for the help.
Cheers
L
Hans Wurst - Replica
Hi there! Unfortunately as listed on the product page, the Late 2013 13” display is not compatible with the Early 2013, only the Mid 2014.
Sam Goldheart -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 71
Ultimi 30 Giorni: 342
Tutti i Tempi: 47,464
