Salta al contenuto principale
MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement
Cosa ti serve
  1. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 3, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 3, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 3, immagine 3 di 3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, Battery Connector: passo 4, immagine 1 di 1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 5, immagine 1 di 1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 6, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 6, immagine 2 di 2
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 8, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 8, immagine 2 di 2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, Battery Contact Board: passo 9, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, Battery Contact Board: passo 9, immagine 2 di 2
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, iSight Camera Cable: passo 10, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, iSight Camera Cable: passo 10, immagine 2 di 2
    • Use the tip of a spudger to push the iSight camera cable connector straight away from its socket on the logic board.
    • It is recommended to carefully push on both sides of the connector to "walk" it out of its socket.
  11. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 11, immagine 1 di 1
    • Move the iSight camera cable aside.
  12. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, AirPort Board Assembly: passo 12, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, AirPort Board Assembly: passo 12, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, AirPort Board Assembly: passo 12, immagine 3 di 3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the socket closest to the ports.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  13. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 13, immagine 1 di 1
    • Move the antenna cables aside, clear of the AirPort board.
  14. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, Display Assembly: passo 14, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, Display Assembly: passo 14, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement, Display Assembly: passo 14, immagine 3 di 3
    • Grab the black pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  15. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 15, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 15, immagine 2 di 2
    • Use a pair of tweezers to lift the rubber hinge covers up off the right and left display hinges.
  16. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 16, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 16, immagine 2 di 2
    • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge brackets.
  17. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 17, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 17, immagine 2 di 2
    • Use a pair of tweezers to lift aluminum hinge brackets off the right and left display hinges.
  18. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 18, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 18, immagine 2 di 2
    • Remove the four inner 5.3 mm T8 Torx screws (two on each side) securing the display to the upper case.
  19. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 19, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 19, immagine 2 di 2
    • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • Remove the last remaining T8 Torx screw securing the display to the upper case.
  20. MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 20, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 20, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2013 Display Assembly Replacement: passo 20, immagine 3 di 3
    • Grip both halves of the device, one in each hand.
    • Gently push forward on the bottom half of the device to detach it from the display assembly.
    • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
Conclusione
Altre 34 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.602 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.718 Guide realizzate
8 Commenti
perfect tutorial! I fixed my screen completely destroyed falling down from my hands while a was falling asleep. Bought a new one on eBay (not original but perfect with the exception of the case slightly different in color and "texture".
Thanks iFix IT!
Ciao
Ciro
Ciro - Replica
This walkthrough/guide is PERFECT! I barely tinker with electronics, but the high cost of repair made me want to try to install a new display assembly myself. Bless you, Sam Lionheart!
Virgil - Replica
This worked really well. The only issue I had was uninstalling the camera. The instructions to pull the data display cable parallel to logic board made sense in step 14. Unfortunately I didn't understand the similarities in step 10. Is it possible to repair the camera now that the slot is completely broken?
D Sh - Replica
Walk through worked perfect. Did it twice. The first time was just to make sure that wasn’t anything disconnect or any wires damage. The second time was to replace the screen. Works perfect.
Cody Milliron - Replica
Hi,
can I replace an damaged display of a MacBook Pro 13” late 2013 with a display from the early 2013 version?
I compared the high-def pictures of each cable connection and they seem to be identical, or am I wrong?
Thanks for the help.
Cheers
L
Hans Wurst - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 69
Tutti i Tempi: 55,777
