Salta al contenuto principale
MacBook Neo Right Speaker Replacement
Cosa ti serve
  1. MacBook Neo Right Speaker Replacement, Prepare the MacBook for disassembly: passo 1, immagine 1 di 3 MacBook Neo Right Speaker Replacement, Prepare the MacBook for disassembly: passo 1, immagine 2 di 3 MacBook Neo Right Speaker Replacement, Prepare the MacBook for disassembly: passo 1, immagine 3 di 3
    • Fully shut down the MacBook and close the lid. Keep the lid closed until you've physically disconnected the battery.
    • Disconnect any cables and accessories.
    • Flip the computer upside‑down on a clean work surface.
    Chiedi a FixBot
    Aggiungi Commento
  2. MacBook Neo Right Speaker Replacement, Remove the bottom cover screws: passo 2, immagine 1 di 1
    • Use a P5 pentalobe driver to remove the eight screws securing the bottom cover:
    • Six 4.1 mm‑long screws
    • Two 4.5 mm‑long screws
    • During reassembly, partially install the screws to ensure alignment, then tighten the screws at each corner (like top‑right, bottom‑left, etc.) before the rest.
    Chiedi a FixBot
    Aggiungi Commento
  3. MacBook Neo Right Speaker Replacement, Pry up the bottom cover: passo 3, immagine 1 di 3 MacBook Neo Right Speaker Replacement, Pry up the bottom cover: passo 3, immagine 2 di 3 MacBook Neo Right Speaker Replacement, Pry up the bottom cover: passo 3, immagine 3 di 3
    • The bottom cover is held in place with two clips, one on each side.
    • Use your fingers to lift the top right corner of the bottom cover, near the USB‑C ports, until the clip along the right edge releases.
    • If you're having trouble, use the flat end of a spudger to pry up the corner until you can grab it with your fingers. You can also slide an opening pick down each edge to release the clips.
    • Repeat this process on the left side to release its clip.
    Chiedi a FixBot
    Aggiungi Commento
  4. MacBook Neo Right Speaker Replacement, Remove the bottom cover: passo 4, immagine 1 di 2 MacBook Neo Right Speaker Replacement, Remove the bottom cover: passo 4, immagine 2 di 2
    • Remove the bottom cover.
    • During reassembly, align the bottom cover with its screw holes, then press on the two short sides until the clip on each side snaps into place.
    Chiedi a FixBot
    Aggiungi Commento
  5. MacBook Neo Right Speaker Replacement, Remove the battery connector cover: passo 5, immagine 1 di 1
    • Use a Torx Plus 3IP driver to remove the two 1.7 mm‑long screws securing the battery connector cover.
    • While the MacBook Neo uses Torx Plus screws, standard Torx bits also work (T3 in place of 3IP, for example). Apply constant, downward force to prevent stripping the screw.
    Chiedi a FixBot
    Aggiungi Commento
  6. MacBook Neo Right Speaker Replacement: passo 6, immagine 1 di 2 MacBook Neo Right Speaker Replacement: passo 6, immagine 2 di 2
    • Use tweezers or your fingers to remove the battery connector cover.
    Chiedi a FixBot
    Aggiungi Commento
  7. MacBook Neo Right Speaker Replacement, Disconnect the battery: passo 7, immagine 1 di 2 MacBook Neo Right Speaker Replacement, Disconnect the battery: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the battery press connector.
    • To reconnect, align the connector carefully over its socket and press down—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Chiedi a FixBot
    Aggiungi Commento
  8. MacBook Neo Right Speaker Replacement, Disconnect the right speaker: passo 8, immagine 1 di 3 MacBook Neo Right Speaker Replacement, Disconnect the right speaker: passo 8, immagine 2 di 3 MacBook Neo Right Speaker Replacement, Disconnect the right speaker: passo 8, immagine 3 di 3
    • Insert the point of a spudger beneath the right speaker connector, located on the left side of the logic board directly above the battery, and pry it straight up to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  9. MacBook Neo Right Speaker Replacement, Free the right speaker cable: passo 9, immagine 1 di 3 MacBook Neo Right Speaker Replacement, Free the right speaker cable: passo 9, immagine 2 di 3 MacBook Neo Right Speaker Replacement, Free the right speaker cable: passo 9, immagine 3 di 3
    • Gently lift the right speaker cable out of its channel around the battery.
    Chiedi a FixBot
    Aggiungi Commento
  10. MacBook Neo Right Speaker Replacement, Remove the right speaker screws: passo 10, immagine 1 di 1
    • Use a Torx Plus 5IP driver to remove the four 3.5 mm‑long screws securing the right speaker.
    • During reassembly, press the right speaker against the frame of the MacBook while installing the screws.
    Chiedi a FixBot
    Aggiungi Commento
  11. MacBook Neo Right Speaker Replacement, Remove the right speaker: passo 11, immagine 1 di 3 MacBook Neo Right Speaker Replacement, Remove the right speaker: passo 11, immagine 2 di 3 MacBook Neo Right Speaker Replacement, Remove the right speaker: passo 11, immagine 3 di 3
    • Lift the right speaker to a roughly 45‑degree angle and remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Compare the new replacement part to the original part—you may need to remove plastic liners from the new part before you install it.
To reassemble the MacBook, follow these instructions in reverse order.
Nick Schultz
Membro da: 03/24/24
56.893 Reputazione
321 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 15
Ultimi 30 giorni: 68
Tutti i Tempi: 283
