Salta al contenuto principale
MacBook Neo Bottom Cover Replacement
Cosa ti serve
  1. MacBook Neo Bottom Cover Replacement, Prepare the MacBook for disassembly: passo 1, immagine 1 di 3 MacBook Neo Bottom Cover Replacement, Prepare the MacBook for disassembly: passo 1, immagine 2 di 3 MacBook Neo Bottom Cover Replacement, Prepare the MacBook for disassembly: passo 1, immagine 3 di 3
    • Fully shut down the MacBook and close the lid. Keep the lid closed until you've physically disconnected the battery.
    • Disconnect any cables and accessories.
    • Flip the computer upside‑down on a clean work surface.
    Chiedi a FixBot
    Aggiungi Commento
  2. MacBook Neo Bottom Cover Replacement, Remove the bottom cover screws: passo 2, immagine 1 di 1
    • Use a P5 pentalobe driver to remove the eight screws securing the bottom cover:
    • Six 4.1 mm‑long screws
    • Two 4.5 mm‑long screws
    • During reassembly, partially install the screws to ensure alignment, then tighten the screws at each corner (like top‑right, bottom‑left, etc.) before the rest.
    Chiedi a FixBot
    Aggiungi Commento
  3. MacBook Neo Bottom Cover Replacement, Pry up the bottom cover: passo 3, immagine 1 di 3 MacBook Neo Bottom Cover Replacement, Pry up the bottom cover: passo 3, immagine 2 di 3 MacBook Neo Bottom Cover Replacement, Pry up the bottom cover: passo 3, immagine 3 di 3
    • The bottom cover is held in place with two clips, one on each side.
    • Use your fingers to lift the top right corner of the bottom cover, near the USB‑C ports, until the clip along the right edge releases.
    • If you're having trouble, use the flat end of a spudger to pry up the corner until you can grab it with your fingers. You can also slide an opening pick down each edge to release the clips.
    • Repeat this process on the left side to release its clip.
    Chiedi a FixBot
    Aggiungi Commento
  4. MacBook Neo Bottom Cover Replacement, Remove the bottom cover: passo 4, immagine 1 di 2 MacBook Neo Bottom Cover Replacement, Remove the bottom cover: passo 4, immagine 2 di 2
    • Remove the bottom cover.
    • During reassembly, align the bottom cover with its screw holes, then press on the two short sides until the clip on each side snaps into place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Compare the new replacement part to the original part—you may need to remove plastic liners from the new part before you install it.
To reassemble the MacBook, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Nick Schultz
Membro da: 03/24/24
54.556 Reputazione
305 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 54
Ultimi 30 giorni: 290
Tutti i Tempi: 1,625
