Introduzione
For the official, updated iFixit guide, click here. This guide is archived for historical purposes.
Cosa ti serve
Use a P5 driver to remove the following screws:
Two 7.6 mm screws (with a 2.7mm collar)
Two 7.1 mm screws
Six 2.3 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Use a T3 torx driver to remove two 2.3mm screws from the battery PCB:
Use a T3 Torx driver to remove the one 1.1 mm screw securing the antenna cable bracket.
Remove the antenna cable bracket.
Insert the point of a spudger under one of the antenna cables close to the connector.
Pry straight up to disconnect the cable.
Repeat for the other antenna cable.
I have had the board side connector come right off when removing the antenna cable. Use something like the spudger or a fine screwdriver tip to put some pressure on the board connector to keep it in place during removal of antenna cable.
Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
Remove the antenna bar.
Use a T9 Torx driver to remove the six 4.7 mm screws securing the display hinges to the upper case.
Altre 2 persone hanno completato questa guida.
2 Commenti
Great guide! Did you encounter any tamper-proof seals? Anything that would make it obvious that the MacBook was disassembled?
No tamper proof seals encountered. Didn’t find anything that would “make it obvious that the MacBook was disassembled”.
