Salta al contenuto principale
MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement
Cosa ti serve
  1. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the screws securing the lower case: passo 1, immagine 1 di 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    If the first thing you do is disconnect the battery, is it really an issue if you don’t (or can’t) disable auto-boot?
    maccentric - Replica
    I agree, why disable Auto-Boot when the lid is closed and the battery is disconnected immediately? – I've never had an issue since 2016 when the feature was introduced.
    stevebsiegel - Replica
    On my machine, the longest two screws were in the corners, while the other two long screws were in the middle. Perhaps previous service in the past had them replaced into the wrong place? In any case, the longest screws do seem to fit in either place. I guess 0.8mm is not very much of a difference. Seems like poor design if they could have used one size of screw.
    johann beda - Replica
    Just did one, and it also had longest screws in the corners.
    maccentric -
    Just did another, and the long ones were in the middle. Definitely poor design and quality control.
    maccentric -
  2. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the lower case: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
    Das geht etwas schwer, da das Unterteil mittig noch von 2 Druckverschlüssen gehalten wird.
    facebook - Replica
    translated and true:
    This is a bit difficult because the lower part is still held in the middle by 2 pressure fasteners.
    Tom - Replica
    Are there any suggestions to removing the pressure fasteners more easily?
    Drea Mastromatteo - Replica
  3. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the battery: passo 3, immagine 1 di 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 4, immagine 1 di 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 4, immagine 2 di 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
    Before the battery can be fully disconnected, the battery disconnect button needs to be held down. There is a gold button just above the battery socket, along with a small LED much like the 12” machines. Once this has been held down and the LED has switched off it is safe to remove the battery.
    Aaron Dalziel - Replica
    This seems like an important step?
    maccentric -
    Also, seems like this should be done after the battery is disconnected, not before? Otherwise, wouldn’t the battery re-charge it?
    maccentric -
    What if the white LED dosent light up after pressing the yellow button again?
    Iron05 -
    I just performed this repair on my late 2018 mac air. I did click the gold button but saw no LED illuminated or otherwise. Question- after reassembly does the button get pressed again to connect the battery? Please clarify if this button is to be pressed and if it needs pressing again after the repair.
    All said - I pressed again after the battery connector clicked, assembled the back and all worked perfectly. The original issue was one dead port (no charge, no communication). The battery charge lightening bold icon was acting funny too. Genuis bar guy in Naperville said it was likely a logic board too. But it was not. The port was apparently confusing the logic board with regards to the charge function. Thanks Adam for saving me $440 and sending my computer back to Apple. I am 71 yrs young - who says an old dog can’t learn new tricks with good training!!
    William Lane - Replica
    I didn't see Aaron's comment before completing the battery replacement. Afterwards, the computer would not turn on despite multiple SMC reset procedures. Upon double-checking the comments I see the importance of pressing the gold button. I pressed the gold button before disconnecting the new battery, then pressed it again after reconnecting for good measure. Computer booted!
    It would be good of iFixit to add this important step as most people probably don't open up every single comment on (seemingly) simple steps.
    Corey Matsumoto - Replica
    Seconding Corey's comment. If paid more attention to the comment section, I would have avoided 15-30 minutes of panic. (BTW I did not notice any LED, but the golden button was easy to find).
    Lorenzo Sorbo -
    Where is the gold button? I replaced my battery and my laptop will not start
    Candace Williams - Replica
  5. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the right speaker: passo 5, immagine 1 di 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the right speaker: passo 5, immagine 2 di 2
    • Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
    This seems unnecessary as you've covered disconnecting and removing the right speaker already. Some clarification would be nice.
    Wesley - Replica
  6. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the audio board: passo 6, immagine 1 di 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Disconnect the audio board: passo 6, immagine 2 di 2
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board cable bracket.
    • Remove the cable bracket.
    For my repair I had to use a T3 here. T4 too big
    Macrepair SF - Replica
  7. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 7, immagine 1 di 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to pry the audio board connector straight up and disconnect it.
  8. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 8, immagine 1 di 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 8, immagine 2 di 2
    • Use the flat end of a spudger to pry the Touch ID sensor connector straight up and disconnect it.
  9. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the audio board: passo 9, immagine 1 di 1
    • Remove the following screws:
    • Two 4.3 mm, T5 Torx screws
    • One 2.4 mm, T3 Torx screw
    In my case, the audio board was mounted with two 4.3 mm T4 screws and one 2.4 mm T3 screw.
    benston - Replica
  10. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 10, immagine 1 di 1
    • Slide the flat end of a spudger underneath the Touch ID sensor cable to slice through the adhesive securing it to the audio board.
  11. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 11, immagine 1 di 1
    • Remove the audio board.
  12. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the Touch ID sensor: passo 12, immagine 1 di 2 MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement, Remove the Touch ID sensor: passo 12, immagine 2 di 2
    • Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
    • Remove the Touch ID bracket.
  13. MacBook Air 13" Retina Display 2019 Touch ID Sensor Replacement: passo 13, immagine 1 di 1
    • Turn the MacBook right-side up and open the display.
    • Lift the Touch ID sensor sensor out of its recess and remove it.
Conclusione
Altre 5 persone hanno completato questa guida.
Adam O'Camb
Membro da: 04/11/15
196.113 Reputazione
416 Guide realizzate
4 Commenti
Hold on so you can replace the touch id but you wont be able to use it? lol kind of redundant if you ask me.
Hamdi Hoxha - Replica
Does one need to replace the adhesive, and if so, what is the adhesive and how is it applied? Thanks.
wadeb - Replica
Can you still use the power button with a touch id replacement?
Nathan Morris - Replica
yes, it will power the machine up!
Bugembe Kenson -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 146
Tutti i Tempi: 7,845
