Salta al contenuto principale
MacBook Air 13" Mid 2013 Upper Case Replacement
Cosa ti serve
  1. MacBook Air 13" Mid 2013 Upper Case Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Compra
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
    Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
    allison - Replica
    Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
    bwgvanderveer - Replica
    I thought I could replace my 256 Gb SSD with 512? regards
    ola m - Replica
    Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
    andrew - Replica
    It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
    Larry Smith - Replica
    tell a model that was not inferior to the speed of the one in the laptop.
    Thank you
    ilyabuhov - Replica
    Do i need to order tools separately to replace the battery i just ordered?
    anne uhlir - Replica
    im looking for a Logic Board for a
    Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
    Any help is appreciated.
    Jamie Comstock - Replica
    P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
    William Skinner - Replica
    I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
    eric -
    Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
    Dennis Eaton - Replica
    My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
    Pennny Beach - Replica
    The supplied kit and instructions worked perfectly!
    Nikolay Andreev - Replica
    Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
    joemoog - Replica
    Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
    Merci pour votre aide.
    chicco33 - Replica
    oui, vous aurez besoin d’un adaptateur, pour completez le changement.
    Dan -
    The tool kit should include tweezers for re-inserting the battery connector.
    Andre Clement - Replica
    P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
    michaelquinnell - Replica
    Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
    Thomas Lewis - Replica
    To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
    Pentalobe 1.2(mm)
    also
    P4 = 0.8
    P6 = 1.5
    Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
    nijafe -
    I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
    Sean Love - Replica
    Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
    John Brennand - Replica
    Just installed on a MacBookAir6,2 (13-inch, Early 2014).
    Was very easy.
    New iFixit battery looks great so far:
    Full Charge Capacity (mAh): 4922 -> 7333
    Jonathan Cross - Replica
    can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
    hawk_lpc -
    Screw P5 Pentalobe 1.2
    Mario Verlent - Replica
    Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
    Joel Sebastian - Replica
    Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
    Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
    Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
    Donald Niamath - Replica
    Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
    Amir Zaidi - Replica
    Thank you very much for the guilde. My MBA2011 had reborn !
    Billy Wong - Replica
    Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
    See great advice: Electrostatic Discharge
    Fletcher Cole - Replica
    … und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
    ... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
    Blatt - Replica
    Fot All People ha ing trouble finding their SSD
    DONT PRESS CMD +R + POWER
    instead press
    OPTION+CMD+R +POWER
    I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
    Albert - Replica
    IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
    This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
    Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
    Good luck. - Eric J.
    ECJohansen - Replica
    On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
    Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
    Rich Garella - Replica
    shrhh - Replica
  2. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
    Jeannie Crowley - Replica
    To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
    nijafe -
    When closing this back up make sure that the antenna cable is tucked away neatly
    Gabriel - Replica
    So this is a legit back cover for MacBook Air?
    ASHANTI SMITH - Replica
    What about disconnecting the battery?
    Luke - Replica
    I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
    Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
    Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
    Lance Berc - Replica
    As noted by others, be a bit careful removing the lower case. There is an oblong black plastic locator very near the center of the lower case. Unless you gently pry the bottom cover pretty much straight up, you will break the ends off of the locater.
    BobY - Replica
    Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
    Nexus - Replica
    The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
    The driver for the screws inside the case are named, as "T5".
    Jim Henderson - Replica
  3. MacBook Air 13" Mid 2013 Upper Case Replacement, Battery Connector: passo 3, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement, Battery Connector: passo 3, immagine 2 di 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
    after disconnect the battery, press and hold 5*10 seconds the powerbutton on your keyboard to unload the capacitors
    Marcel - Replica
    how does a person put the battery connector back in?- that is the only thing i’m afraid of touching after putting new fan in.
    a smith - Replica
    I found it was possible to put the battery connector back in as the last step, however having gone through that and found it to be a little challenging, I would actually recommend attaching the battery connector before screwing back in the bracket. That way you’ll put a lot less stress on the connector cable.
    Kevin Epstein -
    When you are plugging the connector back in, make sure to give it some extra pressure to make sure it is all the way in. It may look like it’s in but needs to be pushed harder!
    Connor Dougherty - Replica
    After disconnecting the power, you may skip directly to step 18. I don’t know why someone would think it necessary to disconnect all the other stuff. There is no need whatsoever to do so. The more things you disconnect, the more things you risk damaging. Many of the parts in steps 4 through 17 are quite delicate, and easy damaged.
    The screw in step 18 is easily accessed without removing even the rubber gasket. Regarding step 18, only remove the screw. (This screw is rather long, with long threads.)
    It’s helpful to take photographs of this area before removing the screw, so you’ll know what it’s supposed to look like when you put it back together.
    AnnoniMoose - Replica
    There are only 16 steps in this repair process. I wonder whether you are commenting on a different repair.
    rmccord23 -
    What if your battery doesn’t have that clear tab?
    Carla Tisdale - Replica
    Yep, exactly the issue that I have
    Martin Adams -
    Where can i buy the battery connector?
    Bernie-Khay Dabu - Replica
    Macbook air 2015 battery connector where can I purchase?
    Connector socket came off, can I just glue it into place?
    Lisa Mac - Replica
  4. MacBook Air 13" Mid 2013 Upper Case Replacement, I/O Board Cable: passo 4, immagine 1 di 1
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
    When putting this back together, be careful you don’t flip I/O board cable. It will fit, but the computer will not work. You’ll know it’s wrong if it covers the fan.
    Tito Jankowski - Replica
  5. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 5, immagine 1 di 1
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
    the instructions should really indicate you’re only disconnecting one end of the cable. you disconnect the other end in step 6.
    Tom O'Leary - Replica
    Bonjour,quand je retire la nappe de la carte E/S , l’éclairage de l’écran s’affiche mais quand je remets la nappe de la carte E/S ,j’ai un écran noir.J’attends votre réponse.Cordialement.
    Halston Halston - Replica
    I literally did this wrong just like you warned not to! Very easy to do…
    Edward Mills - Replica
    I watched the video twice and went really slowly through steps and it works!!! It was a little scary but we got through it! Thanks so much!!
    Alexae Visel - Replica
    20.00000.000$
    Dewi Oasis - Replica
  6. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 6, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 6, immagine 2 di 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
    pour le remontage
    de mon coté tout c’est bien passé, il faut juste bien vérifier la nappe de la carte E/S soit à l’endroit, car sinon l’ordinateur refuse de démarrer ( se référer à la photo du coup )
    matthiasf40 - Replica
    A client was careless and used a fingernail to pry up the cable in one pull. It pulled the socket right off the logic board.
    w98fxr - Replica
  7. MacBook Air 13" Mid 2013 Upper Case Replacement, Fan: passo 7, immagine 1 di 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    I did not find it necessary to loosed the retainer flap, unplug the ribbon cable from it's socket, or remove the fan. After removing the fan screws in Step 9, the fan was loose enough that it can be slightly moved to the side. I felt that loosening the retaining flap and removing the fan adds unnecessary potential to damage something. To the contrary, if you bump the fan while it's plugged in, you might damage the ribbon cable.
    Michael Kruger - Replica
    My retaining flap broke instantly when lifting up with the spudger. Is that normal or possible to fix?
    Cameron Lawrence - Replica
    Similar problem, but with the microphone flap. Did you manage to fix it or get it back in?
    Edwin -
    I've performed many repairs on 13" MacBook Airs ('MBA's), including two heat sink compound 're-dos' just today (on a 2014 13" and a 2015 13").
    It is not necessary to remove the I/O Board to take out the heatsink. And I've done it both ways - its way easier if you leave the I/O board in place. Here's why: removing the I/O board requires dis -and re-connecting two extremely delicate connectors as well as several cables that are really tricky to get back in place, all critical connections. If you aren't experienced with this kind of work, its taxing.
    Instead, once you remove the flat I/O cable, remove the 3 screws holding in the fan and the two hinge screws securing the antenna cable guide. Now the screw securing the tip of the 'radiator' end of the heat sink will be pretty easy to access. The detached fan can moved (and you don't need /want to move it much!) to disengage the rubber shroud where it goes under the fan and gently guide the 'radiator' out.
    clinton - Replica
  8. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 8, immagine 1 di 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
    In my case the adhesive had already come undone through normal use.
    lol same thing for me.
    h_man08 - Replica
  9. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 9, immagine 1 di 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
    I found it easier to do step 11 before this one.
    maccentric - Replica
    During reassembly don’t forget the ribbon cable.
    Rhiannon Orizaga - Replica
  10. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 10, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 10, immagine 2 di 2
    • Lift the fan from the I/O board side and pull it free from the upper case.
    • Removing the fan will also disconnect the fan ribbon cable. Be careful not to snag it.
    It is a lot easier to insert the flat ribbon in its socket before placing the fan back in place. BUT DO NOT YET FLIP BACK the retaining flap, until you have seated and screwed the fan. This way in case you pull on the fan by mistake, the flat ribbon is free to come out, otherwise you may tear it.
    Rany - Replica
    I did not find it necessary to remove the fan or unplug the ribbon cable from it's socket. After removing the fan screws, the fan was loose enough that it can be slightly moved to the side. I felt that loosening the retaining flap and removing the fan adds unnecessary potential to damage something. To the contrary, if you bump the fan while it's plugged in, you might damage the ribbon cable.
    If you are careful with the ribbon cable, there is no need to remove it, the fan will swing out of the way enough. I applied a small amount of sticky tape over the connector to keep it in place, just in case!
    Damian Holland - Replica
  11. MacBook Air 13" Mid 2013 Upper Case Replacement, I/O Board: passo 11, immagine 1 di 1
    • Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
    It requires a somewhat concerning amount of force. I mean, be careful, but I pulled just slightly more than I was comfortable with (for the first time)
    Elijah Kennedy - Replica
  12. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 12, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
    Steps 12 through 16 are not really necessary; you can easily de-route the necessary cables without removing the I/O board. Likewise with reassembly.
  13. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 13, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 13, immagine 2 di 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    When following these steps in the reverse order to reassemble the machine, I found it much easier to insert the ribbon cable before inserting the I/O board into it's place and installing the screw (Step 14). This adds potential for any sudden movement to damage the ribbon cable, so gentle care must be exercised.
    Tried doing both ways when reassembling but the ribbon cable is so crimped that it won’t feed through the socket anymore. Not sure how to get it through else replace cable or run without a microphone.
    Reynold Gonsalves - Replica
    I managed to get the little flap out when trying to push it back in. Now I can’t get the microphone to work…
    Edwin - Replica
    I removed it And I can’t get it to stay connected now that I am putting it back together? How does it stick to the gold part???
    jelainec1 - Replica
    This was an extremely sensitive part to remove. The sticky bit didn’t seem to want to let go, and there isn’t really anywhere to ‘grab’ the cable from the ZIF socket. Ended up using the sticky ‘cover’ portion. Just be carefully wiggling and cajoling the cable free. (2013 model)
    Thomas Keats - Replica
  14. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 14, immagine 1 di 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    I also noticed that the ribbon cable has a “tab” of extra ribbon above it that was hard to see in the pictures.
    This comment was extremely helpful as the connection on the cable end is difficult to see. The tab is for pulling the connector into place.
    jheller105 -
  15. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 15, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 15, immagine 2 di 2
    • Gently de-route the camera cable from its notch on the I/O board and push it out of the way with the tip of a spudger.
  16. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 16, immagine 1 di 1
    • Lift the I/O board from the logic board side and pull it free from the upper case.
    • Removing the I/O board will also disconnect the microphone ribbon cable. Be careful not to snag it.
    I didn't actually need to remove the IO board, it's enough to remove the screw to let it loose. Therefore also step 12 and 13 are useless.
    Emilio - Replica
    THANK YOU. Was able to push the camera cable under the io board without removing it.
    samdaman91 -
    OAT YEAH! Followed this guide to replace my Macbook Air 2014 I/O board step-by-step (thx Jeff Suovanen and contributors) with no probs…workie workie now! FYI it had stopped charging…I tried a new charger, new battery, and finally this I/O board…
    Just take your time and make sure you have the torx screw + adapter bits and spudger as they do not come with the I/O board (I had them leftover from a previous iFixit battery swap).
    Kent O - Replica
    When replacing the I/O board, be careful to gently lift the microphone ribbon cable out of the way. If you forget, you’ll have to remove the I/O board to get at it again…
    VikingShips - Replica
  17. MacBook Air 13" Mid 2013 Upper Case Replacement, Battery: passo 17, immagine 1 di 1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  18. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 18, immagine 1 di 1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  19. MacBook Air 13" Mid 2013 Upper Case Replacement, Logic Board Assembly: passo 19, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement, Logic Board Assembly: passo 19, immagine 2 di 2
    • Grab the plastic pull tab secured to the display data cable lock and rotate it towards the top side of the computer.
  20. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 20, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 20, immagine 2 di 2
    • Pull the display data cable connector straight away from its socket.
    • Make sure to pull the connector parallel to the logic board, do not lift straight up from its socket.
  21. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 21, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 21, immagine 2 di 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
    One of my terminals is broken. What solutions do you recommend me
    Omar Lopez - Replica
    You’re actually pushing the connector from side to side toward the front of the case (or towards the track pad). It’s not a vertical motion at all.
    Jay Quilty - Replica
    I’d also mention to be careful taking these off and putting them back on. I also accidentally pulled a terminal off it’a cable.
    Jean-Pierre Bazinet - Replica
    If the process is taken to replace the top case, you can leave the AirPort card hanging from the antenna wires. Only remove the card’s retaining screw and slide the card to the right (direction of the antenna connectors) to separate it from the main board.
    Yishai Sered - Replica
  22. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 22, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 22, immagine 2 di 2
    • Disconnect the camera cable connector with the tip of a spudger.
    • Push first on one side of the connector, then on the other side to carefully "walk" it out of its socket.
    • Pull the camera cable parallel to the face of the I/O board toward the front edge of the Air to disconnect it from its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
    You’ve missed a whole section here on removing the fan. It’s still present in Step 19 pics, but gone by Step 23. It’s not that it’s difficult to work out how to do it. But, when reassembling and following the steps in reverse, it’s handy to know when to use which screws!
    Stuzzington Botulism - Replica
    Ah! –my bad. The steps for removing Fan etc. are there –up round Step 13. It’s just your photos that are slightly out of sync, as it’s back in place again by Step 19. So, while working in reverse, it looks like it’s not been covered.
    On getting it on — i feel it's implied by the word "push” you can walk it out with the spudger. I couldn't wanage that, and instead walked it out by taking the cord between my index and thumb and walking it out by pulling it to the right and then the left repeatedly in a
  23. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 23, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 23, immagine 2 di 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  24. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 24, immagine 1 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 24, immagine 2 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 24, immagine 3 di 3
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Use your spudger to gently pull the keyboard backlight ribbon cable out of its socket.
    Do you know where i can buy the retaining clip ?
    Jo (MemePasGame) - Replica
    Not sure you can. I’d just use some kapton tape to hold it in place and call it good.
    maccentric -
  25. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 25, immagine 1 di 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • It is recommended to pry up from beneath the cables.
    What is this cables for?
    great.ryankim - Replica
    It’s a speaker cable
    maccentric -
    This is the one that gave me the hardest time!!! It does pop up and out tho.
  26. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 26, immagine 1 di 1
    • Remove the six 6.3 mm T5 Torx screws securing the logic board to the upper case.
    • On some models these may be 4.1 mm T5 Torx screws.
    When re-assembling the motherboard, attach all 6 screws but do not completely tighten yet.
    First make sure the rubber gasket is sitting properly, that the 7th screw hole (from Step 18) is properly aligned, and the Airport wire is sitting properly and also not caught under the heat sink.
    Once everything is well aligned, start tightening the screws while watching out for the alignment. I found it useful to keep an eye on screw-hole from Step 18 as a reference.
    Rany - Replica
    Going in this order, there is a 7th screw securing the logic board to the frame; the heatsink is secured to the logic board with 4 screws, and secured to the frame with 1 more screw. Either take the heatsink off first, or remove that last screw underneath two small black wires, next to the left (as viewed when using the computer; if the computer is flipped over with the cover off and the monitor hinge end of the computer farthest from you, it is in the far right corner) set of three big torx screws that hold the hinge in place. The exact location of this screw is pictured in step 35's second picture; the screw goes through the loop visible below the rubber fan insulator. Scoot those 2 li'l wires out of the way and remove that screw, then the logic board comes right out. If this isn't clear, please let me know and I'll try to describe it better, or add a photo. If I'm posting this to the wrong instruction page, let me know; I was pretty sure I correctly identified my rig, but if not, sorry for the N00bage.
    Fox MacLeod - Replica
    I got an extra screw hiding under the rubber gasket holding the end of the heatsink to the chassis. Ended up bending the heatsink a little cause I wasn't looking for it.
    Corvallis Computer - Replica
    In the model I was working on, the 6th screw (in the middle) was hiding under the Samsung RAM module. Simply remove the one T5 screw holding it in, slide the RAM module out, and the 6th screw will be exposed.
    Tim - Replica
    “Samsung RAM module”… do you mean the SSD? That stick of NVRAM is totally your hard drive.
    FeRD - Replica
    Exactly, he means SSD (storage) the RAM (memory) is soldered to this 820-00165 logic board. Also on this model the 2015 MBA there is no logic board retaining screw under the SSD
    Peter Newman -
  27. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 27, immagine 1 di 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
    This is the same screws as step 17.
    Joseph Lee - Replica
    In both the online and the PDF version, Steps 17-18 and Steps 29-30 are identical. At which stage should you actually remove the display screws?
    adlerpe - Replica
    Good catch! We did some sleuthing and it looks like a couple guides did indeed have an extra section of steps! All better now =)
    Sam Goldheart - Replica
    In my computer these screws were the same size as the other side’s hinge screws. All 6 are the same size.
  28. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 28, immagine 1 di 1
    • Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
    This step is not needed
    mayer - Replica
    It’s not clear what you mean by “This step is not needed.” If you want to remove the logic board from the upper case in order to put it onto your replacement upper case, you will have to remove this screw.
    Richard Garella - Replica
    This step is only needed if you’re replacing the ENTIRE top case. Simply swapping out the trackpad unit does not make this step necessary. This entire tutorial assumes you’re replacing the entire top case which is an expensive mistake if you’re simply replacing the trackpad and/or keyboard. The keyboard is removable as well despite those many tiny rivets. Save money and time by not replacing the entire top case for a bad trackpad and/or keyboard. I needed to accomplish this step because I also removed and replaced the keyboard.
    airshack - Replica
    NOTE: There is a sort of clamp/washer attached to this screw that I didn’t know about until I flipped the laptop up on its side and it fell onto the desk. Also: you need to reset it *before* the motherboard
    In my computer this screw was not there, nor was a related washer. I got it used so perhaps someone has already been there and did not replace the screw.
    Also, the photo here shows how this end of the fan gasket is placed
  29. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 29, immagine 1 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 29, immagine 2 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 29, immagine 3 di 3
    • Slide the flat end of a spudger under the right speaker from the end nearest the hinge to the front edge of the Air to loosen the adhesive.
    • Remove the right speaker from the upper case.
    You don’t really *have* to remove the speaker, especially if your replacement upper case assembly already includes the speakers.
    Alexander Zub - Replica
    I found the same. If you already have speakers in your new upper case, you can leave them. When you put the logic board back in, it will be a tight fit. I had to start with the corner near the right hinge (the Thunderbolt port corner) and work it in to place.
    If your keyboard and/or trackpad need replacing you do not have to replace the entire top case.
    airshack - Replica
    If it is difficult to remove the speakers you can use Isopropyl Alcohol to loosen the adhesive holding the speakers in place. Make sure to keep the Isopropyl Alcohol away from the speaker itself.
    BluRepairs - Replica
  30. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 30, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 30, immagine 2 di 2
    • Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
    • During reassembly:
    • Keep loose cables clear of the board so they aren't caught under it.
    • Make sure the antenna cables are inserted into their respective notches, as highlighted in the second picture.
    It’s probably worth mentioning here that during reassembly you want to tuck the rubber gasket under the extension of the heat sink that the fan slots into.
    David Bonner - Replica
  31. MacBook Air 13" Mid 2013 Upper Case Replacement, Display Assembly: passo 31, immagine 1 di 1
    • Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
    • Leaving the third screw in place for now will aid in rest of the procedure.
    I did not remove the display assembly at all. I replaced both the trackpad and keyboard without removing the display assembly.
    airshack - Replica
    If you purchase the upper case with the keyboard as one unit you then have to remove the display assembly as the keyboard is part of the upper case
    jheller105 - Replica
  32. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 32, immagine 1 di 1
    • Open the display so that it is perpendicular to the upper case and place it on a table as shown.
  33. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 33, immagine 1 di 1
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the display bracket.
  34. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 34, immagine 1 di 1
    • Flip the computer over so the last display screw is more easily accesible.
    • Before removing the final display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  35. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 35, immagine 1 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 35, immagine 2 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 35, immagine 3 di 3
    • Open the Air slowly until the hinges slide out of their notches.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
  36. MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: passo 36, immagine 1 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: passo 36, immagine 2 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: passo 36, immagine 3 di 3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
    Not necessary to remove this. I was replacing a top case that included the speakers.
    Same as the speaker in Step 29, which seems like it can also be left in place.
    This step is required only if also replacing the keyboard.
    airshack - Replica
    Replacing the entire top case is not necessary with the common spilled beverage situations. You can purchase a trackpad as well as keyboard for much less than the cost of an entirely new top case. Why replace the expensive aluminum top case unless it is itself broken which is unlikely.
    airshack - Replica
    Airshack, this is not true for all models of the MacBook Air or the MacBook Pro
    phil3 - Replica
  37. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 37, immagine 1 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 37, immagine 2 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 37, immagine 3 di 3
    • Use the flat end of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
    • If needed, apply a little heat from an iOpener or hairdryer to soften the adhesive.
    • Remove the microphone from the upper case.
    If you’re replacing a top case with one provided by Apple, you won’t need to transfer the microphone to the new top case.
    Carroll Cadden - Replica
    Hot air really helps here.
    Steve DiDomenico - Replica
    I did not have an iOpener nor a blow dryer so I held it over a toaster for 15 seconds.
    phil3 - Replica
    I really sweated over removing the microphone, but as Carroll mentioned, it’s not necessary since it was supplied with the iFixit upper case. Thanks, because it was a b*tch to remove and I probably damaged it in the process. Even with heat.
    Chuck Hawley - Replica
    I did not have a mic in my Ifixit. Am I assuming I need to put it back? with adhesive
    Isaac Herold -
  38. MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: passo 38, immagine 1 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: passo 38, immagine 2 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement, Upper Case: passo 38, immagine 3 di 3
    • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
    Please note that if you are replacing the keyboard you must save this cable for the new one!
    In keyboard replacement, don’t need to take the cable off at all.
    Alex Vinyar - Replica
  39. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 39, immagine 1 di 2 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 39, immagine 2 di 2
    • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
    I could not figure this out from the description. I was concerned about pulling too hard, so I elected to leave the ribbon cable in place until I removed the trackpad. It became obvious what to do at the point. The fact that the retaining flap is entirely hidden under the ribbon cable, and is on the keyboard side of the connector, was lost on me.
  40. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 40, immagine 1 di 1
    • Remove the following seven screws:
    • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
    • One 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
    • During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the movable side of the trackpad has minimal play.
    On The MacBook I worked on. It was not necessary to remove the 1.4mm T5 torx set screw. Which I found out after I broke a T5 bit in it.
    Ken Dail - Replica
    BROKE my T5 bit on this “set screw” too. Correct, it isn’t necessary to remove, I recommend removing it from the steps.
    Broken bit is perhaps a novice move by me, perhaps a cheap Torx screwdriver. Certainly made the rest of the repair dicey.
    Tito Jankowski -
    Yep the replacement case I got had one already installed; you can remove the trackpad with this screw in place, so you may not need to remove it.
    John Noble - Replica
    I had trouble removing the 6 Phillips screws. Even though I have a Phillips size 00 screwdriver it is not engaging the screws properly — I cannot get them to turn without stripping. I ordered the philips 00 screwdriver from iFixit and am HOPING that solves it.
    Jonathan Healy - Replica
    Yes, make sure you have a good quality screwdriver that gets excellent purchase on these screws, and bear down to make sure you don’t strip them. I stripped one and had to drill it out with a 1/16” carbide drill bit. I’ll end up with only two screws on one side but I imagine it should be OK.
    I was able to cheaply replace the keyboard as well as the trackpad, both without replacing the expensive aluminum frame. I followed these steps and then added a few to the end. I was able to easily remove the keyboard black cover/film by lifting the adhesive edges from the case. Then I removed the white backlight layer. Unlike earlier Macbook Pros, this Air model has the keyboard both screwed AND riveted to the aluminum frame. No biggie! I removed the tiny black screws from the keyboard edges then used pliers to pull the keyboard away from the aluminum frame. With this method I removed about 80% of the rivets which left perfect holes for the screws that came with the keyboard. After seating the new keyboard unit I was able to fasten it to the aluminum frame with screws on the keyboard edges as well as in the popped rivet holes. This tutorial can be modified near the end to create a keyboard replacement tutorial. See Rivet-pop method on YouTube, 20min into this video:
    https://youtu.be/Yt8xZIDt3y4
    airshack - Replica
    All the steps went swimmingly, until I got to this step. As soon as I put in the Phillips 00 screw driver, I immediately knew that one of the Phillips screws was already partly stripped - probably during original assembly. Sure enough, no engagement. Does anyone know how to remove such a tiny stripped screw?
    Monica - Replica
    The Phillips #00 recommended in the “Tools” section did not work for me and almost stripped the screws. I tried a Phillips #000 and it worked perfectly.
    Scott Fritz - Replica
    I wish this guided told me I needed this tool, I ordered all the tools yet did not have this one. Forced me to stop my project and go get it.
    Gucci Jin - Replica
  41. MacBook Air 13" Mid 2013 Upper Case Replacement: passo 41, immagine 1 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 41, immagine 2 di 3 MacBook Air 13" Mid 2013 Upper Case Replacement: passo 41, immagine 3 di 3
    • Carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
    • Remove the trackpad from the upper case.
    • The upper case remains.
    I’m disappointed that you didn’t touch on the keyboard removal process, even if it was touching on it without images.
Conclusione
Altre 56 persone hanno completato questa guida.
9 Commenti
Hello all,
Could someone confirm if a upper case with keyboard from A1466 mid 2012 will fit well in A1466 mid 2013?
Thanks!
Nikolay Petrov - Replica
Wondering the same thing here, any luck?
Pedro Tinajero -
Very helpful. Step 29 seems to duplicate step 17.
Jason Buchanan - Replica
Step 29 is taking out the speakers. Step 17 is taking out the battery.
mel -
what type of adhesive do you need to reattach all of the stuff that was pried off? Or do you not need one?
Chi Nguyen - Replica
Awesome guide! A++. Swapped out the keyboard first try :)
Matt Hosburgh - Replica
Really great guide. Did keyboard and I/o boardreplacements without any problem. Highly recommend getting a good tool kit before starting any of these projects. The one ifixit sells worked great for me. Also be sure to get a pentalope driver for the case screws.
im not a tech, but if you proceed slowly and carefully the keyboard replacement isn’t very difficult.
After replacing the top case, only bottom left part of the trackpad is working and top right will not react to the finger. Also the hardware trackpad click does not work any more. it does the clicking sound but nothing happens. Is it possible to somehow damage the trackpad like this during the assembly?
Sergey Bondari - Replica
Awesome guide but wth the time it would take me to do this makes me consider an external keyboard
Emily Peters - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 83
Tutti i Tempi: 48,946
