Introduzione
Use this guide to upgrade or replace the solid-state drive in a MacBook Air 13” Mid 2013.
This MacBook Air uses a proprietary storage drive connector, and is therefore not compatible with most common M.2 and mSATA drives without the use of an adapter.
Before you perform this repair, make sure to back up your SSD. If you are upgrading to a brand-new SSD, familiarize yourself with network recovery, or create a bootable external drive to install macOS onto your new drive and restore your backup.
We strongly recommend installing macOS 10.13 High Sierra (or a later macOS) before replacing the original SSD from your MacBook Air. Most new SSDs require updated storage drivers not found in versions of macOS prior to High Sierra.
Strumenti
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Not sure what to do with your old SSD? Use this external SSD enclosure to turn it into a handy portable external drive!
Altre 85 persone hanno completato questa guida.
18 Commenti
I'm also looking for a 256HB SSD because 128GB isn't enough?
At the moment, the only source for this part is on eBay, at UpgradeMonkey shop (UK)
Link : http://www.ebay.fr/itm/NEW-haswell-MacBo...
It's high priced, but I didn't find anywhere else.
Regards.
JMM -
http://www.alelua.com/es/31-almacenamien... SDD for MacBook Air 11" and 13" (Mid 2013/Early 2014) 256 GB Drive
alelua -
