Introduzione
Use this guide to replace the I/O board cable.
Strumenti
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Altre 6 persone hanno completato questa guida.
