Salta al contenuto principale
Introduzione
Prereq for upper case (logic board is removed)
Ricambi
Nessuna parte specificata.
  1. Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
    • Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
    • Leaving the third screw in place for now will aid in rest of the procedure.
  2. Open the display so that it is perpendicular to the upper case and place it on a table as shown.
    • Open the display so that it is perpendicular to the upper case and place it on a table as shown.
  3. While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the display bracket.
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the display bracket.
  4. Flip the computer over so the last display screw is more easily accesible.
    • Flip the computer over so the last display screw is more easily accesible.
    • Before removing the final display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  5. Open the Air slowly until the hinges slide out of their notches. Once the two display hinges have cleared the upper case, remove the display and set it aside. Once the two display hinges have cleared the upper case, remove the display and set it aside.
    • Open the Air slowly until the hinges slide out of their notches.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 105
