Introduzione
Usa questa guida per sostituire la tua batteria.
Nota: Se c'è un sottile strato di plastica sulla tua batteria nuova, non rimuoverlo. È incollato sulla stessa e protegge il pacco batterie quando è all'interno del MacBook.
Cosa ti serve
Usa un cacciavite P5 Pentalobe per rimuovere le dieci viti che tengono in posizione il case inferiore, delle seguenti lunghezze:
Due viti da 9 mm
Otto viti da 2,6 mm
Inserisci le tue dita tra il display e il case inferiore e tira verso l'alto per separare il case inferiore dal MacBook Air.
Rimuovi il case inferiore e mettilo da parte.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
nijafe -
So this is a legit back cover for MacBook Air?
I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
The driver for the screws inside the case are named, as "T5".
Afferra la linguetta di estrazione in plastica trasparente attaccata al connettore della batteria e tirala verso il lato frontale dell'Air per scollegare la batteria dalla scheda madre.
@&?! - pulled plastic tab on new battery to line up with logic board pins look to be coming out of male connector? Argh?!
Can expect anyone from ifixit to get back to me?
Hi James,
It may be that one of the pins did not lock in properly into the plastic housing. You can try pushing the corresponding wire into the connector housing to try to lock the pin in.
If that does not help, please respond to my email. Thanks!
The original battery plastic pull tab broke off when I tried to pull it towards the front of the Mac. How do I get to disconnect the battery connector now?
My connector would not release as shown, using reasonable force, so I unbolted the battery to slide it back, then was able to slide the connector back. Ultimately, it popped up on its own - suggest review of this process. No drama, nothing broken, all good.
Rimuovi le seguenti cinque viti che tengono ancorata la batteria alla parte superiore del case:
Tre viti Torx T5 da 6,3 mm
Due viti Torx T5 da 2,4 mm
When going in reverse, it's easier to do step 3 before 4.
Screw normal torx T-5
The center screw on my Macbook Air 6,1 is slightly longer than the 6.3 mm screws. John H. is right: when putting back together step 3 is easier and safer to do before step 4. In order of reassembly: Step 5, 3, 4, 2, and 1.
Alza la batteria dal bordo più vicino alla scheda logica e rimuovila dalla parte superiore del case.
Caricala al 100% e lasciala caricare per altre due ore. Poi, scollegala e lascia che si scarichi normalmente. Quando vedi il segnale di batteria scarica, salva tutto il tuo lavoro, e lascia che il portatile si spenga per via della batteria scarica. Aspetta almeno 5 ore, e poi ricarica il portatile ininterrottamente fino al 100%.
Se noti qualsiasi comportamento anomalo o problemi dopo l'installazione della nuova batteria, probabilmente dovrai resettare il SMC del MacBook.
Two Questions and a Comment:
1) “Allow the battery to drain overnight” - Should the computer shut down automatically (during the first drain, as well)? If not, what percentage should the battery reach before charging it to 100%?
2) While the battery is draining, can I use the computer?
When installing the new battery, I found it much easier to insert the battery connector before screwing in the battery.
When reinserting the battery, plug in the battery connector before screwing the battery into place. Some wiggle room is required to reconnect the batter and tweezers will help with the plugging in.
Check to ensure that all 5 holes in the battery enclosure are drilled through. One of mine wasn’t and needed a little push through before setting the battery in place.
Also, as noted above, definitely re-connect the cable before screwing in the battery!
agree on reconnecting before securing battery.
Followed this guide step by step for a successful battery swap thanks iFixit!
FYI, as someone else pointed out, if you try removing the battery connector after you have installed it for one reason or another the pins pull out of the plastic connector piece (the adhesive does not hold). You have to push the cable back into the plastic connector so the pins are all the way back in.
Really useful and simple instructions, done in 10 minutes. Many thanks! H
Merci pour ce super tuto.
L’opération c’est déroulée avec succès.
There is a plastic film across the new battery that wasn’t on the old one, should I remove the plastic film on the new battery?
Actual removal and installation was super easy. Just be sure to have a small container to put the screws in!
Going through calibration right now
As others note on step 4... For reassembly, place battery in area loosely, and reconnect. Then shift the battery fully into position. Eyeball it to roughly get it into the right place, but don't stop there. Take a tool like the spudger and place the pointed end in the screw holes one by one. Shift battery until line up looks good with a bright light. I put back the screw in middle of battery, then the others, etc.
Per riassemblare il dispositivo, segui la guida nell'ordine inverso.
Altre 337 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
36 Commenti
USB wird nach Batterie Wechsel nicht mehr erkannt!
Easy change, thank you so much iFixit.
My macbook air logic board damaged but reason has not addressed by service center. They are asking to pay 700 $ and i ca not afford this much amount what is the best solutions in India . i am being &&^&@@ up buying mac book on monthly EMI. sad
This was my first experience using iFixit to buy parts, tools and use the guide. I will be coming back here from now on, this guide was great and the kit arrived on time and with everything that I needed.
Perfect! You guys are the coolest…..thanks for your help….again!
That was pretty easy. Just be careful when you insert the connector into the logic board socket. You’ll have to give the wires an “S” bend, then insert the connector straight in, don’t lift on it or the socket might come off the board. As you push the connector in, use your other hand to support the socket.
Maybe it would be easier to first insert the connector while the battery is sitting a little out of position, and then second pushing the battery into position.
Excellent guide. It took all of 15 minutes start to finish, including cleaning out the dust inside my MBA. Thanks!
I was a bit nervous before replacing the battery on my own, but following this guide made it so easy. I finished it in 12 minutes including cleaning the interior. Thank you!!
Great instructions. Everything seems to be working fine…minor problem was that I had to do SMC-reset because the Battery indicator showed red even though the battery was charged "100%” and OS X informed “Battery is empty and MacBook Air has to shut down”…but the problem was solved with SMC-reset. Have been using MacBook Air Middle 2013 since then (several weeks) with the new battery and everything seems to be working great. Battery was calibrated accordingly before the “red indicator 100% shut down”-thing appeared. Thank you.
Is it ok for the macbook to be disconnected by power during the installation process?
My MacBook Air Model A1466 2013 has label on the back which says 14.85 V. You replacement battery is rated at 7.6 V. Is this the correct battery?
Hi cybercurry,
Yes, this is the correct battery for your MacBook Air. The laptop’s power input is rated at 14.85V but apparently the battery packs are set up for 7.6V.
iFixed it! — everything went according to the guide. Read more: https://markkadams.wordpress.com/2019/08...
Only glitch was the plastic driver head has a slight bend in it, but nothing to effect the repair.
Very easy to do because nothing is glued. Only screws.
Great guide!
Quel service ! Tout reçu en 2 jours avec même un petit paquet de bonbons :). Et le tutoriel, très simple et compréhensible ! Super ! Bravo iFixit !!
What if you remove the thin plastic film? Should you put it back on? Or just leave it off? I didn’t see the “note” at the top of the installation instructions.
Comment ferait-on sans ces explications claires et détaillées?
Le faire soi-même devient un vrai plaisir!
Hello,
my MacBook Air is for some reason “not changing” when checked on the battery status.
I tried PRAM and SMC resets, which neither of them worked.
I think I messed up the battery calibration, and if I unplug the magsafe, it turns off.
Please help me. I need my MacBook to run without problems.
Thanks.
I have the exact same problem. Charging to 100% worked flawlessly, and then used the MacBook until it turned off. Plugged it in to let it charge. Now the MacBook Air does not recognize the battery. Any help would be very much appreciated.
mazedlx -
Thank you very much!
This saved us almost 60 dollars if we gave it to the Apple Service.
It is very easy if you combine it with the OWC tutorial.
Tip: To know if your battery is properly connected, there is a black dot on the connector. It holds the connector in place.
Was pretty certain that I would run into problems but not a single one. The screwdrivers were the right size; no issue with the back catch on the case (my mid-2013 Macbook Air did not have that catch it seems); battery disconnect and reconnect were no problem. Great job explaining. I did find it helpful to have a a couple of magnets nearby for holding the diff. screws. But, this was not hard, and I am notably unskilled at these sorts of things.
10/10 Straight-forward procedure : )
Trivial fix. Not even 10 minutes. Be very slow and gentle though when pulling the cable, don’t lift it or you’ll end up ripping the socket out like some did!
As others pointed out, when reassembling the battery, plug the cable in first before bolting the battery down, it’s easier this way. Also, the cells appear very soft so be super extra careful not to break them and not to slip your screwdriver! And take care of the old battery! You don’t want to tear or puncture it! Put it back in the plastic case and find a place to properly dispose it off.
Encore merci !!!
Arguably the easiest repair I've done. Once the screws are out, the hardest part is disconnecting the battery from the logic board.
The most time consuming part was calibrating the battery (which I highly recommend doing)
I also followed the SMC reset instructions due to the software giving me some grief.
Battery is probably 3 times longer lasting now
Merci beaucoup ! le tuto est très clair et j’ai pu réaliser le montage sans problème !!
Merci. Clair et synthétique, tout simplement parfait sur un MBA de mi-2013.
Super hilfreich. Danke für den Beitrag!
¡Muchísimas gracias! Un procedimiento sencillo explicado muy claramente. Excelente :)
Thanks for the instructions.
Be careful you don't disturb or dislodge the connector just below and to the left of the fan (see Step 4 photo). I must have accidentally hit it when removing the battery and it caused lots of problems (fan running full, not charging, etc.). I saw a post on iFixit that had the same diagnostic errors and mentioned possible loose cables. So I opened back up and voila!, reseated the cable and seems to be fine now.
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Replica
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Replica
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Replica
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Replica
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Replica
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Replica
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Replica
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Replica
P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
William Skinner - Replica
I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
eric -
Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
Dennis Eaton - Replica
My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
Pennny Beach - Replica
The supplied kit and instructions worked perfectly!
Nikolay Andreev - Replica
Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
joemoog - Replica
Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
Merci pour votre aide.
chicco33 - Replica
oui, vous aurez besoin d’un adaptateur, pour completez le changement.
Dan -
The tool kit should include tweezers for re-inserting the battery connector.
Andre Clement - Replica
P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
michaelquinnell - Replica
Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
Thomas Lewis - Replica
To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
Pentalobe 1.2(mm)
also
P4 = 0.8
P6 = 1.5
Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
nijafe -
I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
Sean Love - Replica
Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
John Brennand - Replica
Just installed on a MacBookAir6,2 (13-inch, Early 2014).
Was very easy.
New iFixit battery looks great so far:
Jonathan Cross - Replica
can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
hawk_lpc -
Screw P5 Pentalobe 1.2
Mario Verlent - Replica
Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
Joel Sebastian - Replica
Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
Donald Niamath - Replica
Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
Amir Zaidi - Replica
Thank you very much for the guilde. My MBA2011 had reborn !
Billy Wong - Replica
Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
See great advice: Electrostatic Discharge
Fletcher Cole - Replica
… und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
Blatt - Replica
Fot All People ha ing trouble finding their SSD
DONT PRESS CMD +R + POWER
instead press
OPTION+CMD+R +POWER
I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
Albert - Replica
IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
Good luck. - Eric J.
ECJohansen - Replica
On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
Rich Garella - Replica
shrhh - Replica
